My project is working but really limit with internal memory.
I thought PSRAM was used by default but no so i configured it and interessting problems pop up
Custom board
ESP32S3-Wroom1-N16R8
320*240 rgb
lvgl 8.x
Esp-IDF in vs code
wifi+ble so finally short in ram usage…
Use external psram properly detected to export the maximum of ram usage in it, and save internal memory for ble and wifi.
- I took inspiration from the few related topics on the forum but can’t make mine to work.
- I add MALLOC_CAP_SPIRAM but each time i do, the program stuck on these two line, as if it was not able to allocate the buffer in the psram:
lv_color_t *buf1 = heap_caps_malloc(EXAMPLE_LCD_H_RES * 40* sizeof(lv_color_t), MALLOC_CAP_DMA | MALLOC_CAP_SPIRAM);
assert(buf1);
lv_color_t *buf2 = heap_caps_malloc(EXAMPLE_LCD_H_RES * 40 * sizeof(lv_color_t), MALLOC_CAP_DMA | MALLOC_CAP_SPIRAM);
assert(buf2);
- I also tried to adjust the lv_conf.h
#define LV_MEM_CUSTOM 1
#if LV_MEM_CUSTOM == 0
#define LV_MEM_SIZE (48U * 1024U) /*[bytes]*/
#if LV_MEM_ADR == 0
#undef LV_MEM_POOL_INCLUDE
#undef LV_MEM_POOL_ALLOC
#else /*LV_MEM_CUSTOM*/
#define LV_MEM_POOL_INCLUDE "esp_heap_caps.h"
#define LV_MEM_POOL_ALLOC(size) heap_caps_malloc(size, MALLOC_CAP_SPIRAM)
Here is menuconfig for psram.
I have mounted a 8MB on the board because i thought my 2MB was not suffisant as i was still overflowed the ram ( that was in reallity the internal ram, but i didn’t know at this time).
But i can still see in the log console the presence of my psram but it seems to not save internal ram space. The confuguration is not good i think.
If you have a better idea of the lines to add here and there :).
I also checked the spiram usage for wifi and i can see that it is effective via heap_size_free functions.
Thanks a lot !
