I am making a project where a raspberry sends sensor data over MQTT to my ESP32S3 (with screen integrated from china). This works fine except for the line graph widget. This fails to render correct sometimes. I am using Squareline studio generated code.
I am a programmer but am not that familiar with C.
ESP32S3 - ESPTool programmer.
A non-distorted graph. Sometimes it runs fine for a while but at other times it will never show a good graph. So its quite an inconsistent thing I guess…
Improving my code to support looping mqtt and gui tasks in seperate loops by using xTaskCreatePinnedToCore.
Setup apart from lvgl init code:
client.setServer(WiFi.gatewayIP(), mqtt_port);
client.setCallback(callback);
client.subscribe(mqtt_topic);
xTaskCreatePinnedToCore(guiTask, "guiTask", 4096, NULL, 1, NULL, 1);
set_main_screen();
Loop of GUI:
void guiTask(void* parameter) {
while (1) {
lv_task_handler(); // Update LVGL widgets
vTaskDelay(5 / portTICK_PERIOD_MS);
Main loop:
void loop()
while(1){
if (!client.connected()) {
reconnect();
client.loop();
Mqtt Callback:
int previous_leds = 0;
StaticJsonDocument<1024> doc;
#define MAX_ARRAY_SIZE 40
void callback(char* topic, byte* payload, unsigned int length) {
char msg[1024];
memcpy(msg, payload, length);
msg[length] = '\0'; // Null-terminate the string
// Deserialize the JSON document
DeserializationError error = deserializeJson(doc, msg);
if (error) {
// Log the specific error
set_start_text("ERROR");
return;
// Check if 'leds' field has changed
if (doc["leds"] != previous_leds) {
leds(doc["leds"]);
// Process the 'status' array
JsonArray array = doc["status"].as<JsonArray>();
const size_t maxArraySize = MAX_ARRAY_SIZE;
int data_array[maxArraySize];
size_t i = 0;
for (JsonVariant j : array) {
if (i < maxArraySize) {
data_array[i] = j.as<int>();
i++;
} else {
// Handle array overflow
break;
add_chart(data_array);
Add_chart function:
void add_chart(int* list){
lv_coord_t* ui_Chart1_series_1_array = (lv_coord_t*)malloc(20 * sizeof(lv_coord_t));
lv_coord_t* ui_Chart1_series_2_array = (lv_coord_t*)malloc(20 * sizeof(lv_coord_t));
// Copy elements from 'list' to the dynamically allocated array
for (int i = 0; i < 40; i++) {
if(i < 20){
ui_Chart1_series_1_array[i] = list[i];
//ui_Chart1_series_1_array[i] = -50;
}else{
ui_Chart1_series_2_array[(i - 20)] = list[i];
//ui_Chart1_series_2_array[i] = -50;
lv_chart_set_ext_y_array(ui_Chart1, ui_Chart1_series_1, ui_Chart1_series_1_array);
lv_chart_set_ext_y_array(ui_Chart1, ui_Chart1_series_2, ui_Chart1_series_2_array);
free(ui_Chart1_series_1_array);
free(ui_Chart1_series_2_array);
