hello
esp32s3
model - 8048S043C_I
resolution : 800 * 480
i see not error but i cant load the screen i see a its turn on but black screen
maybe pinout but i cant file any scheme .
adding my code
- SPDX-FileCopyrightText: 2022-2023 Espressif Systems (Shanghai) CO LTD
- SPDX-License-Identifier: CC0-1.0
#include <stdio.h>
#include “sdkconfig.h”
#include “freertos/FreeRTOS.h”
#include “freertos/task.h”
#include “freertos/semphr.h”
#include “esp_timer.h”
#include “esp_lcd_panel_ops.h”
#include “esp_lcd_panel_rgb.h”
#include “driver/gpio.h”
#include “esp_err.h”
#include “esp_log.h”
#include “lvgl.h”
static const char *TAG = “example”;
//////////////////// Please update the following configuration according to your LCD spec //////////////////////////////
#define EXAMPLE_LCD_PIXEL_CLOCK_HZ (16 * 1000 * 1000)
#define EXAMPLE_LCD_BK_LIGHT_ON_LEVEL 1
#define EXAMPLE_LCD_BK_LIGHT_OFF_LEVEL !EXAMPLE_LCD_BK_LIGHT_ON_LEVEL
#define EXAMPLE_PIN_NUM_BK_LIGHT 4 //
#define EXAMPLE_PIN_NUM_HSYNC 39 // V
#define EXAMPLE_PIN_NUM_VSYNC 41 // V
#define EXAMPLE_PIN_NUM_DE 40 // V
#define EXAMPLE_PIN_NUM_PCLK 42 // V
#define EXAMPLE_PIN_NUM_DATA0 8 // B0
#define EXAMPLE_PIN_NUM_DATA1 3 // B1
#define EXAMPLE_PIN_NUM_DATA2 46 // B2
#define EXAMPLE_PIN_NUM_DATA3 9 // B3 V
#define EXAMPLE_PIN_NUM_DATA4 1 // B4 V
#define EXAMPLE_PIN_NUM_DATA5 5 // G0
#define EXAMPLE_PIN_NUM_DATA6 6 // G1
#define EXAMPLE_PIN_NUM_DATA7 7// G2 V
#define EXAMPLE_PIN_NUM_DATA8 15 // G3 V
#define EXAMPLE_PIN_NUM_DATA9 16 // G4 V
#define EXAMPLE_PIN_NUM_DATA10 4 // G5 V
#define EXAMPLE_PIN_NUM_DATA11 45 // R0
#define EXAMPLE_PIN_NUM_DATA12 48 // R1
#define EXAMPLE_PIN_NUM_DATA13 47 // R2
#define EXAMPLE_PIN_NUM_DATA14 21 // R3 V
#define EXAMPLE_PIN_NUM_DATA15 14 // R4 V
#define EXAMPLE_PIN_NUM_DISP_EN -1
// The pixel number in horizontal and vertical
#define EXAMPLE_LCD_H_RES 800
#define EXAMPLE_LCD_V_RES 480
#if CONFIG_EXAMPLE_DOUBLE_FB
#define EXAMPLE_LCD_NUM_FB 2
#else
#define EXAMPLE_LCD_NUM_FB 1
#endif // CONFIG_EXAMPLE_DOUBLE_FB
#define EXAMPLE_LVGL_TICK_PERIOD_MS 2
#define EXAMPLE_LVGL_TASK_MAX_DELAY_MS 500
#define EXAMPLE_LVGL_TASK_MIN_DELAY_MS 1
#define EXAMPLE_LVGL_TASK_STACK_SIZE (4 * 1024)
#define EXAMPLE_LVGL_TASK_PRIORITY 2
static SemaphoreHandle_t lvgl_mux = NULL;
// we use two semaphores to sync the VSYNC event and the LVGL task, to avoid potential tearing effect
#if CONFIG_EXAMPLE_AVOID_TEAR_EFFECT_WITH_SEM
SemaphoreHandle_t sem_vsync_end;
SemaphoreHandle_t sem_gui_ready;
//extern void example_lvgl_demo_ui(lv_disp_t *disp);
static bool example_on_vsync_event(esp_lcd_panel_handle_t panel, const esp_lcd_rgb_panel_event_data_t *event_data, void *user_data)
BaseType_t high_task_awoken = pdFALSE;
if (xSemaphoreTakeFromISR(sem_gui_ready, &high_task_awoken) == pdTRUE) {
xSemaphoreGiveFromISR(sem_vsync_end, &high_task_awoken);
return high_task_awoken == pdTRUE;
static void example_lvgl_flush_cb(lv_disp_drv_t *drv, const lv_area_t *area, lv_color_t *color_map)
esp_lcd_panel_handle_t panel_handle = (esp_lcd_panel_handle_t) drv->user_data;
int offsetx1 = area->x1;
int offsetx2 = area->x2;
int offsety1 = area->y1;
int offsety2 = area->y2;
xSemaphoreGive(sem_gui_ready);
xSemaphoreTake(sem_vsync_end, portMAX_DELAY);
// pass the draw buffer to the driver
esp_lcd_panel_draw_bitmap(panel_handle, offsetx1, offsety1, offsetx2 + 1, offsety2 + 1, color_map);
lv_disp_flush_ready(drv);
static void example_increase_lvgl_tick(void arg)
/ Tell LVGL how many milliseconds has elapsed */
lv_tick_inc(EXAMPLE_LVGL_TICK_PERIOD_MS);
bool example_lvgl_lock(int timeout_ms)
// Convert timeout in milliseconds to FreeRTOS ticks
// If timeout_ms is set to -1, the program will block until the condition is met
const TickType_t timeout_ticks = (timeout_ms == -1) ? portMAX_DELAY : pdMS_TO_TICKS(timeout_ms);
return xSemaphoreTakeRecursive(lvgl_mux, timeout_ticks) == pdTRUE;
void example_lvgl_unlock(void)
xSemaphoreGiveRecursive(lvgl_mux);
static void example_lvgl_port_task(void *arg)
ESP_LOGI(TAG, “Starting LVGL task”);
uint32_t task_delay_ms = EXAMPLE_LVGL_TASK_MAX_DELAY_MS;
while (1) {
// Lock the mutex due to the LVGL APIs are not thread-safe
if (example_lvgl_lock(-1)) {
task_delay_ms = lv_timer_handler();
// Release the mutex
example_lvgl_unlock();
if (task_delay_ms > EXAMPLE_LVGL_TASK_MAX_DELAY_MS) {
} else if (task_delay_ms < EXAMPLE_LVGL_TASK_MIN_DELAY_MS) {
task_delay_ms = EXAMPLE_LVGL_TASK_MIN_DELAY_MS;
vTaskDelay(pdMS_TO_TICKS(task_delay_ms));
void app_main(void)
static lv_disp_draw_buf_t disp_buf; // contains internal graphic buffer(s) called draw buffer(s)
static lv_disp_drv_t disp_drv; // contains callback functions
ESP_LOGI(TAG, “Create semaphores”);
sem_vsync_end = xSemaphoreCreateBinary();
assert(sem_vsync_end);
sem_gui_ready = xSemaphoreCreateBinary();
assert(sem_gui_ready);
#if EXAMPLE_PIN_NUM_BK_LIGHT >= 0
ESP_LOGI(TAG, “Turn off LCD backlight”);
gpio_config_t bk_gpio_config = {
.mode = GPIO_MODE_OUTPUT,
.pin_bit_mask = 1ULL << EXAMPLE_PIN_NUM_BK_LIGHT
ESP_ERROR_CHECK(gpio_config(&bk_gpio_config));
ESP_LOGI(TAG, "Install RGB LCD panel driver");
esp_lcd_panel_handle_t panel_handle = NULL;
esp_lcd_rgb_panel_config_t panel_config = {
.data_width = 16, // RGB565 in parallel mode, thus 16bit in width
.dma_burst_size = 64,
.num_fbs = EXAMPLE_LCD_NUM_FB,
#if CONFIG_EXAMPLE_USE_BOUNCE_BUFFER
.bounce_buffer_size_px = 10 * EXAMPLE_LCD_H_RES,
.clk_src = LCD_CLK_SRC_DEFAULT,
.disp_gpio_num = EXAMPLE_PIN_NUM_DISP_EN,
.pclk_gpio_num = EXAMPLE_PIN_NUM_PCLK,
.vsync_gpio_num = EXAMPLE_PIN_NUM_VSYNC,
.hsync_gpio_num = EXAMPLE_PIN_NUM_HSYNC,
.de_gpio_num = EXAMPLE_PIN_NUM_DE,
.data_gpio_nums = {
EXAMPLE_PIN_NUM_DATA0,
EXAMPLE_PIN_NUM_DATA1,
EXAMPLE_PIN_NUM_DATA2,
EXAMPLE_PIN_NUM_DATA3,
EXAMPLE_PIN_NUM_DATA4,
EXAMPLE_PIN_NUM_DATA5,
EXAMPLE_PIN_NUM_DATA6,
EXAMPLE_PIN_NUM_DATA7,
EXAMPLE_PIN_NUM_DATA8,
EXAMPLE_PIN_NUM_DATA9,
EXAMPLE_PIN_NUM_DATA10,
EXAMPLE_PIN_NUM_DATA11,
EXAMPLE_PIN_NUM_DATA12,
EXAMPLE_PIN_NUM_DATA13,
EXAMPLE_PIN_NUM_DATA14,
EXAMPLE_PIN_NUM_DATA15,
.timings = {
.pclk_hz = EXAMPLE_LCD_PIXEL_CLOCK_HZ,
.h_res = EXAMPLE_LCD_H_RES,
.v_res = EXAMPLE_LCD_V_RES,
// The following parameters should refer to LCD spec
.hsync_back_porch = 40,
.hsync_front_porch = 20,
.hsync_pulse_width = 1,
.vsync_back_porch = 8,
.vsync_front_porch = 4,
.vsync_pulse_width = 1,
.flags.pclk_active_neg = true,
.flags.fb_in_psram = true, // allocate frame buffer in PSRAM
ESP_ERROR_CHECK(esp_lcd_new_rgb_panel(&panel_config, &panel_handle));
ESP_LOGI(TAG, "Register event callbacks");
esp_lcd_rgb_panel_event_callbacks_t cbs = {
.on_vsync = example_on_vsync_event,
ESP_ERROR_CHECK(esp_lcd_rgb_panel_register_event_callbacks(panel_handle, &cbs, &disp_drv));
ESP_LOGI(TAG, "Initialize RGB LCD panel");
ESP_ERROR_CHECK(esp_lcd_panel_reset(panel_handle));
ESP_ERROR_CHECK(esp_lcd_panel_init(panel_handle));
ESP_LOGI(TAG, “Turn on LCD backlight”);
gpio_set_level(EXAMPLE_PIN_NUM_BK_LIGHT, EXAMPLE_LCD_BK_LIGHT_ON_LEVEL);
ESP_LOGI(TAG, "Initialize LVGL library");
void *buf1 = NULL;
void *buf2 = NULL;
ESP_LOGI(TAG, “Use frame buffers as LVGL draw buffers”);
ESP_ERROR_CHECK(esp_lcd_rgb_panel_get_frame_buffer(panel_handle, 2, &buf1, &buf2));
// initialize LVGL draw buffers
lv_disp_draw_buf_init(&disp_buf, buf1, buf2, EXAMPLE_LCD_H_RES * EXAMPLE_LCD_V_RES);
#else
ESP_LOGI(TAG, “Allocate separate LVGL draw buffers from PSRAM”);
buf1 = heap_caps_malloc(EXAMPLE_LCD_H_RES * 100 * sizeof(lv_color_t), MALLOC_CAP_SPIRAM);
assert(buf1);
lv_disp_draw_buf_init(&disp_buf, buf1, buf2, EXAMPLE_LCD_H_RES * 100);
ESP_LOGI(TAG, "Register display driver to LVGL");
lv_disp_drv_init(&disp_drv);
disp_drv.hor_res = EXAMPLE_LCD_H_RES;
disp_drv.ver_res = EXAMPLE_LCD_V_RES;
disp_drv.flush_cb = example_lvgl_flush_cb;
disp_drv.user_data = panel_handle;
disp_drv.full_refresh = true; // the full_refresh mode can maintain the synchronization between the two frame buffers
lv_disp_t *disp = lv_disp_drv_register(&disp_drv);
ESP_LOGI(TAG, "Install LVGL tick timer");
// Tick interface for LVGL (using esp_timer to generate 2ms periodic event)
const esp_timer_create_args_t lvgl_tick_timer_args = {
.callback = &example_increase_lvgl_tick,
.name = "lvgl_tick"
esp_timer_handle_t lvgl_tick_timer = NULL;
ESP_ERROR_CHECK(esp_timer_create(&lvgl_tick_timer_args, &lvgl_tick_timer));
ESP_ERROR_CHECK(esp_timer_start_periodic(lvgl_tick_timer, EXAMPLE_LVGL_TICK_PERIOD_MS * 1000));
lvgl_mux = xSemaphoreCreateRecursiveMutex();
assert(lvgl_mux);
ESP_LOGI(TAG, "Create LVGL task");
xTaskCreate(example_lvgl_port_task, "LVGL", EXAMPLE_LVGL_TASK_STACK_SIZE, NULL, EXAMPLE_LVGL_TASK_PRIORITY, NULL);
ESP_LOGI(TAG, "Display LVGL Scatter Chart");
lv_label_set_text(label, "Hello, LCD!");
tnx alot
