kumekay
September 6, 2021, 8:34pm
1
I’m new to lvgl and would like to try it with micropython on esp-wrover-kit v4.1
I’ve tried different versions of both lv_micropython and esp-idf,
and it looks like only some versions can work together, for example, I only managed to compile and flash lv_micropython master with esp-idf v4.2.
However then I didn’t manage to find any working example.
Could you suggest a commit ID of lv_micropython
, commit of esp-idf, and some ili9341 example that are known to work together?
kumekay
September 6, 2021, 8:59pm
2
Here is an example that doesn’t even try to print anything but still crashes:
import sys
sys.path.append("")
# Imports
import gc
import lvgl as lv
lv.init()
gc.collect()
from ili9XXX import ili9341
disp = ili9341(miso=25, mosi=23, clk=19, cs=22, dc=21, rst=18, backlight=5, power=-1)
disp.init()
print("init done")
disp_buf1 = lv.disp_draw_buf_t()
buf1_1 = bytearray(240 * 10)
disp_buf1.init(buf1_1, None, len(buf1_1) // lv.color_t.__SIZE__)
disp_drv = lv.disp_drv_t()
disp_drv.init()
print("disp_drv init done")
disp_drv.draw_buf = disp_buf1
disp_drv.flush_cb = disp.flush
disp_drv.hor_res = 240
disp_drv.ver_res = 320
disp_drv.register()
print("disp_drv.register()")
Example output:
cp main.py :main.py
Connected to MicroPython at /dev/ttyUSB1
Use Ctrl-] to exit this shell
ets Jun 8 2016 00:22:57
rst:0x1 (POWERON_RESET),boot:0x1e (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
mode:DIO, clock div:2
load:0x3fff0030,len:5572
load:0x40078000,len:13136
ho 0 tail 12 room 4
load:0x40080400,len:4356
entry 0x400806b0
Double buffer
ILI9341 initialization completed
Enable backlight
Enable backlight
init done
disp_drv init done
disp_drv.register()
MicroPython v1.15-836-ge71a9729c-dirty on 2021-09-06; ESP32 module (spiram) with ESP32
Type "help()" for more information.
>>> Guru Meditation Error: Core 0 panic'ed (StoreProhibited). Exception was unhandled.
Core 0 register dump:
PC : 0x40243e4a PS : 0x00060031 A0 : 0x80128f59 A1 : 0x3ffbe400
A2 : 0x3f81a160 A3 : 0x00060023 A4 : 0x00060021 A5 : 0x3ffd30f0
A6 : 0x00000006 A7 : 0x00000003 A8 : 0x00000000 A9 : 0x00000000
A10 : 0x3ffc5624 A11 : 0x3ff0017c A12 : 0x00000006 A13 : 0x00060021
A14 : 0x000000fe A15 : 0x00000001 SAR : 0x0000001e EXCCAUSE: 0x0000001d
EXCVADDR: 0x00000018 LBEG : 0x400935ac LEND : 0x400935c8 LCOUNT : 0xffffffff
Backtrace:0x40243e47:0x3ffbe400 0x40128f56:0x3ffbe420 0x4008e083:0x3ffbe440 0x4008e250:0x3ffbe460 0x40084532:0x3ffbe4a0 0x0004001e:0x00000000 |<-CORRUPTED
ELF file SHA256: d7c75ab00fca8dd7
Rebooting...
kumekay
September 6, 2021, 9:05pm
3
Finally, I’ve managed to get async example to work, here is mine from the master with updated pin numbers https://gist.github.com/kumekay/11f1a3afa0fbafe8df2ac741a95ecc44
However, it’s still not clear to me what is wrong with the original one.
amirgon
September 6, 2021, 9:43pm
4
Hi @kumekay !
lv_micropython on esp-wrover + ili9341 is well supported.
Latest lv_micropython works with esp-idf v4.3 and should also work with v4.0.2 and possibly other versions. The CI checks these versions .
When you create an instance of ili9341
you are not supposed to register display driver, this is already done in ili9341
If you are looking for an example to run, I recommend advanced_demo.py .
ili9341
is initialized there like this:
def init_gui_esp32(self):
# Initialize ILI9341 display
self.disp = ili9341(dc=32, cs=33, power=-1, backlight=-1)
kumekay
September 12, 2021, 1:11pm
5
@amirgon Thank you so much, it works just fine
