I am trying to set up a simple example on an esp32-s3. I am using tft_espi lib for driving the display and for resistive touch. I am getting about 33fps but the cpu is at about 50% just sitting there and goes up to 90% if I do anything. My example has only 2 buttons but The widget example also exhibits this behavior except the cpu goes up to 99% if I scroll or do anything with it. Here is the info on the gear.
display: random Chinese ILI9486 driven display with resistive touch at 480x320
libs: bodmer/TFT_eSPI@^2.4.70 and lvgl/lvgl@^8.2.0
framework: arduino
I have tried other drivers and ways of getting better CPU including the native esp32 idf version and drivers but have had no luck. I also tried pinning the gui to cpu 1 but that made things worse. The only thing that has help is to increase the delay from 5 to 100 in the loop function. That got me to about 20% CPU idle but I do notice a pretty noticeable lag with touch and other things.
Here is my code.
#include <Arduino.h>
#include "FS.h"
#include <SPI.h>
#include <TFT_eSPI.h> // Hardware-specific library
#include "lvgl.h"
lv_disp_drv_t disp_drv;
lv_indev_drv_t indev_drv;
lv_obj_t *btn1;
lv_obj_t *btn2;
lv_obj_t *screenMain;
lv_obj_t *label;
char txt[100];
lv_obj_t *tlabel; // touch x,y label
/*Change to your screen resolution*/
static const uint16_t screenWidth = 480;
static const uint16_t screenHeight = 320;
static lv_color_t* buf1 = (lv_color_t*) heap_caps_malloc(LV_HOR_RES_MAX * 40 * sizeof(lv_color_t), 1<<3);
static lv_color_t* buf2 = (lv_color_t*) heap_caps_malloc(LV_HOR_RES_MAX * 40 * sizeof(lv_color_t), 1<<3);
/* Display flushing */
tft.startWrite();
tft.pushColors((uint16_t *)&color_p->full, w * h, true);
tft.endWrite();
lv_disp_flush_ready(disp);
/*Read the touchpad*/
void my_touchpad_read(lv_indev_drv_t *indev_driver, lv_indev_data_t *data)
uint16_t touchX, touchY;
bool touched = tft.getTouch(&touchX, &touchY, 600);
if (!touched)
/*Set the coordinates*/
data->point.x = touchX;
data->point.y = touchY;
sprintf(txt, "Touch:(%03d,%03d)", touchX, touchY);
lv_label_set_text(tlabel, txt); // set label text
static void event_handler_btn(lv_event_t *event)
/*The original target of the event. Can be the buttons or the container*/
lv_obj_t *target = lv_event_get_target(event);
if (target == btn1)
lv_label_set_text(label, "Hello");
else if (target == btn2)
lv_label_set_text(label, "Goodbye");
void setup()
tft.init();
tft.initDMA();
// Set the rotation before we calibrate
tft.setRotation(1);
lv_disp_draw_buf_init(&draw_buf, buf1, buf2, LV_HOR_RES_MAX * 40);
/*Initialize the display*/
lv_disp_drv_init(&disp_drv);
/*Change the following line to your display resolution*/
screenMain = lv_obj_create(NULL);
tlabel = lv_label_create(screenMain); // full screen as the parent
lv_label_set_text(tlabel, "Touch:(000,000)"); // set label text
lv_obj_align(tlabel, LV_ALIGN_TOP_RIGHT, 0, 0); // Center but 20 from the top
lv_label_set_long_mode(label, LV_LABEL_LONG_WRAP);
lv_label_set_text(label, "Press a button");
lv_obj_set_size(label, 240, 40);
lv_obj_set_pos(label, 0, 35);
btn1 = lv_btn_create(screenMain);
lv_obj_add_event_cb(btn1, event_handler_btn, LV_EVENT_CLICKED, NULL);
lv_obj_set_pos(btn1, 32, 100);;
lv_obj_t *label1 = lv_label_create(btn1);
lv_label_set_text(label1, "Hello");
btn2 = lv_btn_create(screenMain);
lv_obj_add_event_cb(btn2, event_handler_btn, LV_EVENT_CLICKED, NULL);
lv_obj_set_pos(btn2, 142, 100);
lv_obj_t *label2 = lv_label_create(btn2);
lv_label_set_text(label2, "Goodbye");
lv_scr_load(screenMain);
void loop()
lv_task_handler();
delay(5);
If anyone has any ideas on how to get this to decent cpu levels please chime in.
Thank you
