ESP32 Micropython build errors... LOTS
The answer is simple : different esp-idf version. In an older version one had the warning you see. In newer versions, the warning becomes an info:
I (xxxx) This chip is revision 1 but project was configured for minimum revision 0. Suggest setting project minimum revision to 1 if safe to do so.
And this info is only shown if the log verbosity is sufficient. One can set it using esp.osdebug:
import esp
esp.osdebug("*", esp.LOG_INFO)
osdebug's first argument is ignored unless it is None, in which case the verbosity is set to LOG_ERROR
No, but in most cases, we can semi-automatically update lv_micropython by running a single command.
As @amirgon mentioned…
The last major release of Micropython was in December 2019. As such, the latest merge with MicroPython occured on Jan 17th.
If you’d like to update lv_micropython manually, you should be able to clone it and then run the following commands:
git remote add micropython https://github.com/micropython/micropython.git
git fetch micropython
git merge micropython/master
It’s quite possible you’ll have to resolve some merge conflicts but that will give you all of the latest changes in Micropython.
GETTING ERROR…
rich@RG-x360:/mnt/c/tpi-dev/lvgl/lv_micropython$ git merge micropython/master
*** Please tell me who you are.
Run
git config --global user.email "you@example.com"
git config --global user.name “Your Name”
to set your account’s default identity.
Omit --global to set the identity only in this repository.
Follow it’s instructions. This must be the first time you’ve tried to commit on this machine.
got it…
on to next learning class
now what…
what does it want?
You need to open these files (VSCode is a good editor to use for this) and resolve the merge conflicts. Essentially, git couldn’t figure out how to apply some of the new changes on top of the underlying code.
Once you’re done that, you can run git status on the command line. It will list the “unmerged paths”; you should add these to the commit with git add <file paths>. Then you can run git commit to actually do the merge.
If you’d prefer, I can do this for you and leave the result on a branch of lv_micropython.
I really appreciate your help !!!
You’ve probably read my RANTS and now you know why.
Before I waste too much of your valuable time I should learn how to fix these errors on my own.
I am using VSC…
What am I resolving exactly??
Here’s a good tutorial:
https://help.github.com/en/github/collaborating-with-issues-and-pull-requests/resolving-a-merge-conflict-using-the-command-line
Got this far…
I try to …
git add lib/lv_bindings
but does not take
It looks like you merged it successfully. See if you can compile MicroPython; sometimes git complains about lib/lv_bindings but the build works without problems. If it doesn’t work I can give you the steps to fix lib/lv_bindings.
MAKE STOPPED HERE… any ideas
CC ../../lib/lv_bindings/driver/generic/modlvindev.c
In file included from ../../lib/lv_bindings/driver/generic/../include/common.h:4,
                 from ../../lib/lv_bindings/driver/generic/modlvindev.c:5:
../../lib/lv_bindings/driver/generic/modlvindev.c: In function 'indev_read':
../../lib/lv_bindings/driver/generic/modlvindev.c:131:40: error: passing argument 2 of 'mp_obj_new_exception_msg' from incompatible pointer type [-Werror=incompatible-pointer-types]
                 &mp_type_RuntimeError, "indev instance needs to be created before callback is called!"));
../../py/obj.h:275:35: note: in definition of macro 'MP_OBJ_TO_PTR'
 #define MP_OBJ_TO_PTR(o) ((void *)o)
../../lib/lv_bindings/driver/generic/modlvindev.c:129:37: note: in expansion of macro 'nlr_raise'
     if (!self || (!self->callback)) nlr_raise(
../../py/obj.h:734:86: note: expected 'mp_rom_error_text_t' {aka 'struct <anonymous> *'} but argument is of type 'char *'
 mp_obj_t mp_obj_new_exception_msg(const mp_obj_type_t *exc_type, mp_rom_error_text_t msg);
cc1: all warnings being treated as errors
../../py/mkrules.mk:64: recipe for target 'build-GENERIC_SPIRAM/lib/lv_bindings/driver/generic/modlvindev.o' failed
make: *** [build-GENERIC_SPIRAM/lib/lv_bindings/driver/generic/modlvindev.o] Error 1
make: Leaving directory '/mnt/c/tpi-dev/lvgl/lv_micropython/ports/esp32'
(bld-lvgl) rich@RG-x360:/mnt/c/tpi-dev/lvgl/lv_micropython$
Try running git submodule update --recursive in the base lv_micropython directory. Then run the build again.
Unfortunately… same error as above
What is modlvindev.c code for ???
As far as I know, it’s the glue code that lets you register an input device using MicroPython.
Unfortunately I’m not very familiar with the MicroPython internals so I think @amirgon will have to help you here.
Anyone ???
