I downloaded LVGL as described in the documentation, including lv_esp32_drivers, but unfortunately, when I try to build it, it gives me the following error:
'ledc_timer_config_t' has no member named 'bit_num' esp_lcd_backlight.c /lv/components/lvgl_esp32_drivers/lvgl_tft line 52 C/C++ Problem
'lv_disp_t' {aka 'struct _lv_disp_t'} has no member named 'driver' disp_spi.c /lv/components/lvgl_esp32_drivers/lvgl_tft line 316 C/C++ Problem
'LV_HOR_RES_MAX' undeclared (first use in this function); did you mean 'LV_HOR_RES'? lvgl_helpers.h /lv/components/lvgl_esp32_drivers line 66 C/C++ Problem
implicit declaration of function 'gpio_matrix_out'; did you mean 'gpio_iomux_out'? [-Werror=implicit-function-declaration] esp_lcd_backlight.c /lv/components/lvgl_esp32_drivers/lvgl_tft line 59 C/C++ Problem
unknown type name 'lv_disp_drv_t'; did you mean 'lv_fs_drv_t'? FT81x.c /lv/components/lvgl_esp32_drivers/lvgl_tft line 326 C/C++ Problem
ESP32
IDF v5.0
and after I tried
IDF v4.4
I made changes in the CMakeLists of lvgl_esp32_drivers to:
idf_component_register(SRCS ${SOURCES}
INCLUDE_DIRS ${LVGL_INCLUDE_DIRS}
REQUIRES lvgl driver esp_common log freertos esp_rom soc).
