I have read various discussions about it, and I apologize, but I did not understand anything. I use an esp32 with esp-idf. The library works correctly. Now I would need to use the screen oriented 90 ° ie vertically.
I exchanged the definitions: #define LV_HOR_RES_MAX (240) #define LV_VER_RES_MAX (320)
driver->rotated = 1;
But nothing happens, continue to write me the text of a label horizontally. I need to hold the display vertically and write the labels in this orientation.
How can I do?
Thank you very much
Note: I removed your other topic since you reposted it here in a more appropriate category. Thanks!
Please note that you’ll need to fill out the template (rather than removing it).
> ## Important: posts that do not use this template will be ignored or closed.
> ## Before posting
> - Get familiar with [Markdown](https://forum.lvgl.io/t/get-familiar-with-markdown/403) to format and structure your post
> - Be sure to update [lvgl](https://github.com/littlevgl/lvgl) from the latest version from the `master` branch.
> - Be sure you have checked the relevant part of the [documentation](https://docs.littlevgl.com/en/html/index.html). **We will not respond in detail to posts where you haven't read the relevant documentation.**
> - If applicable use the [Simulator](https://docs.littlevgl.com/en/html/get-started/pc-simulator.html) to eliminate hardware related issues.
> *Delete this section if you read and applied the mentioned points.*
## Description
### What MCU/Processor/Board and compiler are you using?
### What do you want to achieve?
### What have you tried so far?
## Code to reproduce
```c
You are unlikely to receive further help until you fill out the template. And @jeremyjh is correct, you would have to add rotation support to the driver.
