I want to make a simple car engine coolant temperature gauge. I’m utilizing Elmdunio library . It uses elm327 to communicate with car canbus system and transfers data to esp32 via bluetooth.
I have tested it and I get correct values and communication is ok.
Now the issues.
I’ve designed the UI - and that part works perfectly on my ESP32 and TFT lcd display.
- Now the issue is when I join the Elmduino library into my UI.
- I get stuck in boot loop
-I get screen corruption.
This is the UI code ( works without no issues)
#include <lvgl.h>
#include <TFT_eSPI.h>
#include <ui.h>
extern lv_obj_t *ui_Arc2;
extern lv_obj_t *ui_Temp;
/*Don't forget to set Sketchbook location in File/Preferencesto the path of your UI project (the parent foder of this INO file)*/
/*Change to your screen resolution*/
static const uint16_t screenWidth = 320;
static const uint16_t screenHeight = 240;
static lv_color_t buf[ screenWidth * screenHeight / 10 ];
TFT_eSPI tft = TFT_eSPI(screenWidth, screenHeight); /* TFT instance */
#if LV_USE_LOG != 0
/* Serial debugging */
void my_print(const char * buf)
Serial.printf(buf);
Serial.flush();
/* Display flushing */
void my_disp_flush( lv_disp_drv_t *disp, const lv_area_t *area, lv_color_t *color_p )
uint32_t w = ( area->x2 - area->x1 + 1 );
uint32_t h = ( area->y2 - area->y1 + 1 );
tft.startWrite();
tft.setAddrWindow( area->x1, area->y1, w, h );
tft.pushColors( ( uint16_t * )&color_p->full, w * h, true );
tft.endWrite();
lv_disp_flush_ready( disp );
void setup()
Serial.begin( 115200 ); /* prepare for possible serial debug */
LVGL_Arduino += String('V') + lv_version_major() + "." + lv_version_minor() + "." + lv_version_patch();
Serial.println( LVGL_Arduino );
Serial.println( "I am LVGL_Arduino" );
#if LV_USE_LOG != 0
lv_log_register_print_cb( my_print ); /* register print function for debugging */
tft.begin(); /* TFT init */
tft.setRotation( 3 ); /* Landscape orientation, flipped */
lv_disp_draw_buf_init( &draw_buf, buf, NULL, screenWidth * screenHeight / 10 );
/*Initialize the display*/
/*Change the following line to your display resolution*/
lv_disp_drv_register( &disp_drv );
lv_indev_drv_init( &indev_drv );
lv_indev_drv_register( &indev_drv );
ui_init();
void loop()
// Let the LVGL GUI do its work
lv_timer_handler();
delay(5); // Small delay for stability
This is the Elmduino code that i need to merge into my UI.
#include "BluetoothSerial.h"
#include "ELMduino.h"
BluetoothSerial SerialBT;
#define ELM_PORT SerialBT
#define DEBUG_PORT Serial
ELM327 myELM327;
uint32_t rpm = 0;
void setup()
#if LED_BUILTIN
pinMode(LED_BUILTIN, OUTPUT);
digitalWrite(LED_BUILTIN, LOW);
DEBUG_PORT.begin(115200);
//SerialBT.setPin("1234");
ELM_PORT.begin("ArduHUD", true);
if (!ELM_PORT.connect("OBDII"))
DEBUG_PORT.println("Couldn't connect to OBD scanner - Phase 1");
while(1);
if (!myELM327.begin(ELM_PORT, true, 2000))
Serial.println("Couldn't connect to OBD scanner - Phase 2");
while (1);
Serial.println("Connected to ELM327");
void loop()
float tempRPM = myELM327.rpm();
if (myELM327.nb_rx_state == ELM_SUCCESS)
rpm = (uint32_t)tempRPM;
Serial.print("RPM: "); Serial.println(rpm);
else if (myELM327.nb_rx_state != ELM_GETTING_MSG)
myELM327.printError();
-Note My goal it’s to pull engineCoolantTemperature so the code looks like this.
#include <lvgl.h>
#include <ui.h>
ELM327 myELM327;
uint32_t rpm = 0;
/* Screen resolution */
/* Display buffer */
#if LV_USE_LOG != 0
Serial.printf(buf);
Serial.flush();
tft.startWrite();
tft.endWrite();
void setup()
Serial.begin(115200); /* Serial initialization */
Serial.println(LVGL_Arduino);
Serial.println("I am LVGL_Arduino");
tft.setRotation(3); /* Landscape orientation, flipped */
lv_disp_draw_buf_init(&draw_buf, buf, NULL, screenWidth * screenHeight / 10 );
/* Initialize the display */
lv_disp_drv_init(&disp_drv);
/* Initialize the (dummy) input device driver */
ui_init(); /* Initialize UI */
SerialBT.begin("ArduHUD", true); /* Bluetooth initialization */
if (!SerialBT.connect("OBDII"))
Serial.println("Couldn't connect to OBD scanner - Phase 1");
while(1);
while (1);
Serial.println("Setup done");
void loop()
float coolantTemp = myELM327.engineCoolantTemp(); // Read Oil Temperature
if (myELM327.nb_rx_state == ELM_SUCCESS) {
// Round the coolant temperature to the nearest whole number
int roundedCoolantTemp = round(coolantTemp);
// Update the UI elements with the rounded coolant temperature
lv_arc_set_value(ui_Arc2, roundedCoolantTemp); // Update the arc
lv_label_set_text_fmt(ui_Temp, "%d°C", roundedCoolantTemp); // Update the temperature label
} else if (myELM327.nb_rx_state != ELM_GETTING_MSG) {
lv_timer_handler(); // Let the LVGL GUI do its work
I’ve tried many thing but everything leads to boot loop, or corrupted screen.
ui.zip (42.1 KB)
Does someone know why I get into the boot loop. I tried many thing but same issue I posted the issue on SquareLine studio forum topic ( Esp32 rebooting - debugging - #9 by Amer7 - How to - Forum - SquareLine Studio) But maybe here i get a better reach?
Just to add The code works great, and display works … Until I power off the ESP32, when I power it ON i get corrupted screen.
After If i compile and upload the same sketch- Still Corrupted screen image.
