I am trying to get LVGL running with my ESP32S3 along with the 2.8 capacitive touchscreen from Adafruit: Adafruit Capacitive Touchscreen. Since this screen uses the FT6206 driver, I have modified the LVGL_Arduino.ino file to take into account the touchpoints from the Adafruit FT6206 driver. So far, I have tried running some very simple examples. As referenced in the below code, I have tried running the lv_example_btn_1. The screen renders perfectly. I am getting touch accurately mapped to my display, however, it seems like the coordinates for the rendered buttons don’t align. i.e. I touch a button centered on the screen, my logging shows correct touch at ~160, 120 but I don’t get the button click event. It seems as thought the touch event coordinates are located elsewhere on the screen. Fairly new with lvgl and display drivers in general but hoping someone may have seen/fixed this in the past.
ESP32-S3-DevKitC-1-N32R8V with Adafruit Cap Touch ILI9341 with FT6206
I want the the click event touchpoints to be mapped to the rendered button on screen so that when I touch the button (or whatever element on screen), it recognizes it.
Messing around with screen rotation settings, button offsets in the arduino widget examples.
#include "/Users/Documents/Arduino/libraries/lvgl/examples/lv_examples.h"
#include <SPI.h>
#include <Wire.h>
#include <Adafruit_GFX.h>
#include "lvgl.h"
#include <TFT_eSPI.h>
#include <Adafruit_FT6206.h>
/*Change to your screen resolution*/
static const uint16_t screenWidth = 320;
static const uint16_t screenHeight = 240;
static lv_color_t buf[ screenWidth * screenHeight / 10 ];
// The FT6206 uses hardware I2C (SCL/SDA)
Adafruit_FT6206 touch = Adafruit_FT6206();
TFT_eSPI tft = TFT_eSPI(screenWidth,screenHeight); /* TFT instance */
void my_disp_flush( lv_disp_drv_t *disp_drv, const lv_area_t *area, lv_color_t *color_p )
uint32_t w = ( area->x2 - area->x1 + 1 );
uint32_t h = ( area->y2 - area->y1 + 1 );
tft.startWrite();
tft.setAddrWindow( area->x1, area->y1, w, h );
tft.pushColors( ( uint16_t * )&color_p->full, w * h, true );
tft.endWrite();
lv_disp_flush_ready( disp_drv );
void my_touchpad_read(lv_indev_drv_t * drv, lv_indev_data_t * data)
bool touched = touch.touched();
if (touched)
TS_Point point = touch.getPoint();
// Print raw touch coordinates
Serial.print("Raw X: ");
Serial.print(point.x);
Serial.print(", Y: ");
Serial.println(point.y);
// Map the touch coordinates to match the screen resolution and orientation
uint16_t touchX = point.x;
uint16_t touchY = point.y;
//uint16_t touchX = map(point.x, 0, 320, 0, 320);
//uint16_t touchY = map(point.y, 0, 240, 0, 240);
data->point.x = touchX;
data->point.y = touchY;
Serial.print("Touched at X: ");
Serial.print(touchX);
Serial.println(touchY);
if (!touched)
void setup()
tft.begin();
tft.setRotation(3);
if (!touch.begin(40)) { // pass in 'sensitivity' coefficient
Serial.println("Couldn't start FT6206 touchscreen controller");
} else {
Serial.println("FT6206 touchscreen controller CONNECTED!");
lv_disp_draw_buf_init(&disp_buf, buf, NULL, screenWidth*10);
//lv_disp_draw_buf_init(&disp_buf, buf, NULL, screenWidth * screenHeight / 10);
static lv_disp_drv_t disp_drv; /*A variable to hold the drivers. Must be static or global.*/
disp_drv.draw_buf = &disp_buf; /*Set an initialized buffer*/
disp_drv.flush_cb = my_disp_flush; /*Set a flush callback to draw to the display*/
disp_drv.hor_res = screenWidth; /*Set the horizontal resolution in pixels*/
disp_drv.ver_res = screenHeight; /*Set the vertical resolution in pixels*/
lv_disp_t * disp;
disp = lv_disp_drv_register(&disp_drv); /*Register the driver and save the created display objects*/
lv_indev_drv_init(&indev_drv); /*Basic initialization*/
indev_drv.type = LV_INDEV_TYPE_POINTER; /*See below.*/
indev_drv.read_cb = my_touchpad_read; /*See below.*/
/*Register the driver in LVGL and save the created input device object*/
lv_indev_t * my_indev = lv_indev_drv_register(&indev_drv);
//Check vertical and horizontal resolution of what lvgl sees
lv_coord_t hor_res = lv_disp_get_hor_res(NULL);
Serial.print("LVGL Horizontal Resolution: ");
Serial.println(hor_res);
lv_coord_t ver_res = lv_disp_get_ver_res(NULL);
Serial.print("LVGL Vertical Resolution: ");
Serial.println(ver_res);
lv_coord_t disp_dpi = lv_disp_get_dpi(NULL);
Serial.print("LVGL Display DPI: ");
Serial.println(disp_dpi);
lv_example_btn_1();
void loop()
delay( 5 );
the pictures below show where the touch events are getting recognized for both the btn_1 and btn_2 examples:
