I bought ESP32-8048S070 7inch and as a first step I wanted to use Arduino framework to make it running (My goal is to use ESP-IDF + LVGL - but this is next step). To do it I configured PlatformIO in VSC and I created a simple project that compiles without any problems. I used some Get-started examples from LVGL page - it works, but…
I have a big problem with flickering. Sometimes it’s more visible, sometimes less. I see that the biggest problem is just after programming the board.
No flickering.
- Power Supply - it’s not the problem.
- Buffer created with static and dynamic allocation.
#include <Arduino.h>
#include "Arduino_GFX_Library.h"
#include <lvgl.h>
Arduino_ESP32RGBPanel *bus = new Arduino_ESP32RGBPanel(
41, 40, 39, 42,
14, 21, 47, 48, 45,
9, 46, 3, 8, 16, 1,
15, 7, 6, 5, 4,
0, 210, 30, 16, //0, 8, 2, 43,
0, 22, 13, 10, //0, 8, 2, 12,
1, 9000000
Arduino_GFX *gfx = new Arduino_RGB_Display(
800, 480, bus
void my_disp_flush( lv_display_t *disp, const lv_area_t *area, uint8_t * px_map)
uint32_t w = lv_area_get_width(area);
uint32_t h = lv_area_get_height(area);
gfx->draw16bitRGBBitmap(area->x1, area->y1, (uint16_t *)px_map, w, h);
lv_disp_flush_ready(disp);
uint32_t mtick()
return millis();
#define TFT_HOR_RES 800
#define TFT_VER_RES 480
#define DRAW_BUF_SIZE (TFT_HOR_RES * TFT_VER_RES / 4)
static uint32_t draw_buf[DRAW_BUF_SIZE / 4];
// uint32_t * draw_buf;
static lv_display_t * disp;
void setup()
gfx->begin();
gfx->fillScreen(BLACK);
delay(1000);
pinMode(2, OUTPUT);
digitalWrite(2, HIGH);
delay(1000);
Serial.begin(115200);
lv_tick_set_cb(mtick);
disp = lv_display_create(gfx->width(), gfx->height());
lv_display_set_buffers(disp, draw_buf, NULL, DRAW_BUF_SIZE, LV_DISPLAY_RENDER_MODE_PARTIAL);
// draw_buf = (uint32_t *)heap_caps_malloc(DRAW_BUF_SIZE, MALLOC_CAP_INTERNAL | MALLOC_CAP_32BIT);
/*Change the active screen's background color*/
lv_obj_set_style_bg_color(lv_screen_active(), lv_color_hex(0x003a57), LV_PART_MAIN);
// lv_obj_set_style_bg_color(lv_screen_active(), lv_color_hex(0xffffff), LV_PART_MAIN);
// lv_obj_set_style_bg_color(lv_screen_active(), lv_color_hex(0), LV_PART_MAIN);
/*Create a white label, set its text and align it to the center*/
lv_obj_t * label = lv_label_create(lv_screen_active());
lv_label_set_text(label, "Hello world");
// lv_obj_set_style_text_color(lv_screen_active(), lv_color_hex(0), LV_PART_MAIN);
lv_obj_set_style_text_color(lv_screen_active(), lv_color_hex(0x00ff00), LV_PART_MAIN);
lv_obj_set_style_text_font(label, &lv_font_montserrat_20, 0);
lv_obj_t * btn = lv_button_create(lv_screen_active()); /*Add a button the current screen*/
lv_obj_set_pos(btn, 10, 10); /*Set its position*/
lv_obj_set_size(btn, 120, 50); /*Set its size*/
// lv_obj_add_event_cb(btn, btn_event_cb, LV_EVENT_ALL, NULL); /*Assign a callback to the button*/
lv_obj_t * label2 = lv_label_create(btn); /*Add a label to the button*/
lv_label_set_text(label2, "Button"); /*Set the labels text*/
lv_obj_center(label2);
static lv_style_t style;
lv_style_init(&style);
lv_style_set_arc_color(&style, lv_palette_main(LV_PALETTE_RED));
lv_style_set_arc_width(&style, 4);
lv_obj_t * obj = lv_arc_create(lv_screen_active());
lv_obj_add_style(obj, &style, 0);
lv_obj_set_pos(obj, 200, 10);
void loop()
lv_timer_handler();
delay(5);
platformie.ini file
[env:esp32-s3-devkitc-1]
platform = espressif32
board = esp32-s3-devkitc-1
framework = arduino
monitor_speed = 115200
board_build.f_cpu = 240000000L
board_build.f_flash = 80000000L
board_build.arduino.memory_type = qio_opi
board_build.flash_mode = qio
board_build.psram_type = opi
board_upload.flash_size = 16MB
board_upload.maximum_size = 16777216
board_build.partitions = default_16MB.csv
board_build.extra_flags =
-DBOARD_HAS_PSRAM
-DPSRAM_CLK=80000000
lib_deps =
moononournation/GFX Library for Arduino@1.6.0
lvgl/lvgl@^9.3.0
Video on YouTube - recorded also in slow-motion. It shows the problem.
- MCU/MPU/Board: ESP32-8048S070 7inch display: ESP32-S3 HMI 8M PSRAM 16M Flash Arduino LVGL WIFI & Bluetooth 7
- LVGL version: v9.3.0
- Arduino framework + PlatformIO + oononournation/GFX Library for Arduino
