Getting started, I followed the tutorial https://docs.lvgl.io/8.1/get-started/arduino.html and tried to compile the example (without button, widget, …)
/*Using LVGL with Arduino requires some extra steps:
*Be sure to read the docs here: https://docs.lvgl.io/master/integration/framework/arduino.html */
#include <lvgl.h>
#if LV_USE_TFT_ESPI
#include <TFT_eSPI.h>
/*To use the built-in examples and demos of LVGL uncomment the includes below respectively.
*You also need to copy `lvgl/examples` to `lvgl/src/examples`. Similarly for the demos `lvgl/demos` to `lvgl/src/demos`.
*Note that the `lv_examples` library is for LVGL v7 and you shouldn't install it for this version (since LVGL v8)
*as the examples and demos are now part of the main LVGL library. */
//#include <examples/lv_examples.h>
//#include <demos/lv_demos.h>
/*Set to your screen resolution and rotation*/
#define TFT_HOR_RES 320
#define TFT_VER_RES 240
#define TFT_ROTATION LV_DISPLAY_ROTATION_0
/*LVGL draw into this buffer, 1/10 screen size usually works well. The size is in bytes*/
#define DRAW_BUF_SIZE (TFT_HOR_RES * TFT_VER_RES / 10 * (LV_COLOR_DEPTH / 8))
uint32_t draw_buf[DRAW_BUF_SIZE / 4];
#if LV_USE_LOG != 0
void my_print( lv_log_level_t level, const char * buf )
LV_UNUSED(level);
Serial.println(buf);
Serial.flush();
/* LVGL calls it when a rendered image needs to copied to the display*/
void my_disp_flush( lv_display_t *disp, const lv_area_t *area, uint8_t * px_map)
/*Copy `px map` to the `area`*/
/*For example ("my_..." functions needs to be implemented by you)
uint32_t w = lv_area_get_width(area);
uint32_t h = lv_area_get_height(area);
my_set_window(area->x1, area->y1, w, h);
my_draw_bitmaps(px_map, w * h);
/*Call it to tell LVGL you are ready*/
lv_display_flush_ready(disp);
/*Read the touchpad*/
void my_touchpad_read( lv_indev_t * indev, lv_indev_data_t * data )
int32_t x, y;
bool touched = my_get_touch( &x, &y );
if(!touched) {
} else {
data->point.x = x;
data->point.y = y;
/*use Arduinos millis() as tick source*/
static uint32_t my_tick(void)
return millis();
void setup()
LVGL_Arduino += String('V') + lv_version_major() + "." + lv_version_minor() + "." + lv_version_patch();
Serial.begin( 115200 );
Serial.println( LVGL_Arduino );
/*Set a tick source so that LVGL will know how much time elapsed. */
lv_tick_set_cb(my_tick);
/* register print function for debugging */
#if LV_USE_LOG != 0
lv_log_register_print_cb( my_print );
lv_display_t * disp;
#if LV_USE_TFT_ESPI
/*TFT_eSPI can be enabled lv_conf.h to initialize the display in a simple way*/
disp = lv_tft_espi_create(TFT_HOR_RES, TFT_VER_RES, draw_buf, sizeof(draw_buf));
lv_display_set_rotation(disp, TFT_ROTATION);
#else
/*Else create a display yourself*/
disp = lv_display_create(TFT_HOR_RES, TFT_VER_RES);
lv_display_set_buffers(disp, draw_buf, NULL, sizeof(draw_buf), LV_DISPLAY_RENDER_MODE_PARTIAL);
lv_indev_t * indev = lv_indev_create();
lv_indev_set_type(indev, LV_INDEV_TYPE_POINTER); /*Touchpad should have POINTER type*/
lv_indev_set_read_cb(indev, my_touchpad_read);
/* Create a simple label
lv_obj_t *label = lv_label_create( lv_screen_active() );
lv_label_set_text( label, "Hello Arduino, I'm LVGL!" );
lv_obj_align( label, LV_ALIGN_CENTER, 0, 0 );
* Try an example. See all the examples
* - Online: https://docs.lvgl.io/master/examples.html
* - Source codes: https://github.com/lvgl/lvgl/tree/master/examples
lv_example_btn_1();
* Or try out a demo. Don't forget to enable the demos in lv_conf.h. E.g. LV_USE_DEMO_WIDGETS
lv_demo_widgets();
void loop()
delay(5); /* let this time pass */
I’m than faced to the linking error: LVGL_Arduino.ino.elf section .bss' is not within region dram0_0_seg’ as described in https://forum.lvgl.io/t/compile-error-dram0-bss-will-not-fit-in-region-dram0-0-seg-with-ili9488-esp32-arduino-core/10259/4
If I agree that it’s a memory issue, I guess from what I see that it should be possible to make LVGL running on an ESP12, or am I wrong?
Where are the minimal hardware requirements definitions?
In case it is possible, suspecting that this issue was link to the size of the drawing buffer:
I tested to drastically reduce this size, but I have the same issue when linking…
I than suspect a wrong board configuration, but based on the nodeMCU specification https://components101.com/development-boards/nodemcu-esp8266-pinout-features-and-datasheet, I set up the memory configuration as follow, and compiling with the Arduino IDE 2.3.4:
Any idea how to fix that, or should I switch to another microcontroller / another IDE ?
Samuel
