I am trying to setup a super simple esp-idf project with lvgl, the project was created with idf.py create-project and both lvgl and lvgl_esp32_drivers are added with git add submodules.
However I am getting the following errors:
any idea what went wrong?
here is my project structure (only printed first 3 levels)
├── CMakeLists.txt
├── build
│ ├── CMakeCache.txt
│ ├── CMakeFiles
│ ├── app-flash_args
│ ├── bootloader
│ ├── bootloader-flash_args
│ ├── bootloader-prefix
│ ├── build.ninja
│ ├── cmake_install.cmake
│ ├── compile_commands.json
│ ├── config
│ ├── config.env
│ ├── esp-idf
│ ├── flash_app_args
│ ├── flash_args
│ ├── flash_args.in
│ ├── flash_bootloader_args
│ ├── flash_project_args
│ ├── flasher_args.json
│ ├── kconfigs.in
│ ├── kconfigs_projbuild.in
│ ├── ldgen_libraries
│ ├── ldgen_libraries.in
│ ├── partition-table-flash_args
│ ├── partition_table
│ ├── project_description.json
│ ├── project_elf_src_esp32.c
│ └── x509_crt_bundle.S
├── components
│ ├── lv_conf.h
│ ├── lvgl
│ └── lvgl_esp32_drivers
├── dependencies.lock
├── main
│ ├── CMakeLists.txt
│ └── hi_lvgl.c
├── sdkconfig
└── sdkconfig.old
