A this is Super Odd
The Text file is
“Hallo ich bin es der
Martin Michael”
This sucks if I do this with Arduino SD it work properbly
Anyway great Project !!!
buffer = (uint8_t*)malloc(100);
char file_path[] ={"S:Text/noop.txt"};
res = lv_fs_open(&f, file_path, LV_FS_MODE_RD);
if (res != LV_FS_RES_OK)
Serial.println("LV Failed to open SD File!");
Serial.println("LV Opened SD File!");
uint32_t read_num;
uint32_t charTOread = 20;
res = lv_fs_read(&f, buffer, charTOread, &read_num);
Serial.println("LV did a SD File Read!");
for (int a = 0; a < 50; a++)
Serial.printf("0x%x ", buffer[a]);
LV_LOG_WARN(" After Hex Output\n");
char ch = (char)buffer[a];
Serial.printf("%c", ch);
LV_LOG_WARN("\n AfterChar Output");
Serial.println("");
res = LV_FS_RES_OK;
Serial.println("LV Couldn't Read!");
Serial.println("LV Read DATA!");
Serial.print("LV File Pointer before close: ");
Serial.println((int)&f);
lv_fs_close(&f);
Serial.print("LV File Pointer after close: ");
Serial.println("closed file");
free(buffer);
