Error with function "lv_obj_remove_event_cb"?
  • I may have found a “lv_obj_remove_event_cb” problem and tested it
  • It may be missing a line of code:
    obj->spec_attr->event_dsc[i].filter = obj->spec_attr->event_dsc[i+1].filter;
  • The “lv_obj_remove_event_dsc” function is the same
bool lv_obj_remove_event_cb(lv_obj_t * obj, lv_event_cb_t event_cb)
    LV_ASSERT_OBJ(obj, MY_CLASS);
    if(obj->spec_attr == NULL) return false;
    int32_t i = 0;
    for(i = 0; i < obj->spec_attr->event_dsc_cnt; i++) {
        if(obj->spec_attr->event_dsc[i].cb == event_cb) {
            /*Shift the remaining event handlers forward*/
            for(; i < (obj->spec_attr->event_dsc_cnt-1); i++) {
                obj->spec_attr->event_dsc[i].cb = obj->spec_attr->event_dsc[i+1].cb;
                obj->spec_attr->event_dsc[i].user_data = obj->spec_attr->event_dsc[i+1].user_data;
            obj->spec_attr->event_dsc_cnt--;
            obj->spec_attr->event_dsc = lv_mem_realloc(obj->spec_attr->event_dsc, obj->spec_attr->event_dsc_cnt * sizeof(lv_event_dsc_t));
            LV_ASSERT_MALLOC(obj->spec_attr->event_dsc);
            return true;
    /*No event handler found*/
    return false;
    int32_t i = 0;
            return true;
    return false;
  • were my findings correct?
I think the fix is correct. Do you want to send a PR?
Of course, I’m going to do that.
