Hello!
I got an error when making the files using ESP-IDF v4.4 and the default branch of lv_micropyhton.
First, I open my terminal and active the ESP-IDF with the command:
. $HOME/esp/esp-idf/export.sh
After that, I go to my lv_micropyhton folder, open the ports/esp32 directory and run the following command:
make submodules
And when a run:
make LV_CFLAGS="-DLV_COLOR_DEPTH=32"
This problem shows up:
I got a different problem when using the LTS version of ESP_IDF too, and instead of using the make command I also tried running “idf.py build” direct and I got the same problem above.
I don’t think that this matters now, but I’m working on an esp32, with an ili9488 display driver and the ft6x36 touch driver from MAKERFABS.
Someone could show me what I can try to this simple step??
Thanks.
