Hi Team,
i am using containers in my code. when i click on container i am redirecting to other screen which contains small list. when i click on the container getting below error
Error: lv_obj_get_ext_attr (lv_obj.c #3174 lv_obj_get_ext_attr())
Error: NULL pointer (0x00000000) (lv_debug.c #127 lv_debug_log_error())
But when i run list screen individually i am not getting any errors
ARM
Version 7
containers file
* @file lv_iotgizmo_menu.c
* INCLUDES
#include "../../lv_examples.h"
#include "iotgizmo_menu.h"
#include "iotgizmo_dimmer_list.h"
#include "iotgizmo_thermostat_list.h"
#include "iotgizmo_switch_list.h"
#include <stdio.h>
#if LV_USE_IOTGIZMO
* DEFINES
* TYPEDEFS
* STATIC PROTOTYPES
* STATIC VARIABLES
static lv_style_t style_line;
static lv_style_t style_border;
static void dimmer_list(lv_obj_t * obj, lv_event_t event);
static void thermostat_list(lv_obj_t * obj, lv_event_t event);
static void switch_list(lv_obj_t * obj, lv_event_t event);
static void music_list(lv_obj_t * obj, lv_event_t event);
//msg box
static void mbox_event_cb(lv_obj_t *obj, lv_event_t evt);
static void opa_anim(void * bg, lv_anim_value_t v);
static lv_obj_t *mbox, *info;
static lv_style_t style_modal;
#if LV_IOTGIZMO_WALLPAPER
LV_IMG_DECLARE(bg)
LV_IMG_DECLARE(bulb)
LV_IMG_DECLARE(temperature)
LV_IMG_DECLARE(switch_icon)
LV_IMG_DECLARE(music)
LV_IMG_DECLARE(home)
LV_IMG_DECLARE(microphone)
LV_IMG_DECLARE(lock)
LV_IMG_DECLARE(settings)
* MACROS
* GLOBAL FUNCTIONS
void iotgizmo_menu(void)
lv_obj_t * wp = lv_img_create(lv_scr_act(), NULL);
lv_img_set_src(wp, &bg);
//style_model
lv_style_init(&style_modal);
lv_style_set_bg_color(&style_modal, LV_STATE_DEFAULT, LV_COLOR_BLACK);
//line
static lv_point_t line_points[] = {{0,0},{480,0}};
/*Create style*/
//static lv_style_t style_line;
lv_style_init(&style_line);
lv_style_set_line_width(&style_line, LV_STATE_DEFAULT, 2);
lv_style_set_line_color(&style_line, LV_STATE_DEFAULT, LV_COLOR_GRAY);
lv_style_set_line_rounded(&style_line, LV_STATE_DEFAULT, true);
lv_style_init(&style_border);
lv_style_set_bg_color(&style_border,LV_STATE_DEFAULT,LV_COLOR_BLACK);
lv_style_set_radius(&style_border, LV_STATE_DEFAULT, 30);
//bulb container
lv_obj_t * cont_bulb;
cont_bulb = lv_cont_create(lv_scr_act(), NULL);
lv_obj_set_auto_realign(cont_bulb, true);
lv_obj_align_origo(cont_bulb, NULL, LV_ALIGN_IN_TOP_LEFT, 120, 200);
lv_cont_set_fit(cont_bulb, LV_FIT_TIGHT);
lv_cont_set_layout(cont_bulb, LV_LAYOUT_COLUMN_MID);
lv_obj_add_style(cont_bulb,LV_OBJ_PART_MAIN,&style_border);
lv_obj_set_event_cb(cont_bulb, dimmer_list);
lv_obj_t * bulb_ic = lv_img_create(cont_bulb, NULL);
lv_img_set_src(bulb_ic, &bulb);
lv_obj_align(bulb_ic, NULL, LV_ALIGN_IN_TOP_LEFT, 50, 50);
lv_obj_t * label1;
label1 = lv_label_create(cont_bulb, NULL);
lv_label_set_recolor(label1, true);
lv_label_set_text(label1, "#FFFFFF BULB");
lv_obj_set_width(label1, 150);
//thermostat container
lv_obj_t * cont_thermo;
cont_thermo = lv_cont_create(lv_scr_act(), NULL);
lv_obj_set_auto_realign(cont_thermo, true);
lv_obj_align_origo(cont_thermo, NULL, LV_ALIGN_IN_TOP_RIGHT, -120, 200);
lv_cont_set_fit(cont_thermo, LV_FIT_TIGHT);
lv_cont_set_layout(cont_thermo, LV_LAYOUT_COLUMN_MID);
lv_obj_add_style(cont_thermo,LV_OBJ_PART_MAIN,&style_border);
lv_obj_set_event_cb(cont_thermo, thermostat_list);
lv_obj_t * thermostat_ic = lv_img_create(cont_thermo, NULL);
lv_img_set_src(thermostat_ic, &temperature);
lv_obj_align(thermostat_ic, NULL, LV_ALIGN_IN_TOP_RIGHT, -50, 50);
lv_obj_t * label2;
label2 = lv_label_create(cont_thermo, NULL);
lv_label_set_recolor(label2, true);
lv_label_set_text(label2, "#FFFFFF THERMOSTAT");
lv_obj_set_width(label2, 150);
//switch container
lv_obj_t * cont_switch;
cont_switch = lv_cont_create(lv_scr_act(), NULL);
lv_obj_set_auto_realign(cont_switch, true);
lv_obj_align_origo(cont_switch,cont_bulb, LV_ALIGN_CENTER, 0, 300);
lv_cont_set_fit(cont_switch, LV_FIT_TIGHT);
lv_cont_set_layout(cont_switch, LV_LAYOUT_COLUMN_MID);
lv_obj_add_style(cont_switch,LV_OBJ_PART_MAIN,&style_border);
lv_obj_set_event_cb(cont_switch, switch_list);
lv_obj_t * switch_ic = lv_img_create(cont_switch, NULL);
lv_img_set_src(switch_ic, &switch_icon);
lv_obj_t * label3;
label3 = lv_label_create(cont_switch, NULL);
lv_label_set_recolor(label3, true);
lv_label_set_text(label3, "#FFFFFF SWITCH");
lv_obj_set_width(label3, 150);
//music
lv_obj_t * cont_music;
cont_music = lv_cont_create(lv_scr_act(), NULL);
lv_obj_set_auto_realign(cont_music, true);
lv_obj_align_origo(cont_music, cont_thermo, LV_ALIGN_CENTER, 0, 300);
lv_cont_set_fit(cont_music, LV_FIT_TIGHT);
lv_cont_set_layout(cont_music, LV_LAYOUT_COLUMN_MID);
lv_obj_add_style(cont_music,LV_OBJ_PART_MAIN,&style_border);
lv_obj_set_event_cb(cont_music, music_list);
lv_obj_t * music_ic = lv_img_create(cont_music, NULL);
lv_img_set_src(music_ic, &music);
lv_obj_t * label4;
label4 = lv_label_create(cont_music, NULL);
lv_label_set_recolor(label4, true);
lv_label_set_text(label4, "#FFFFFF MUSIC");
lv_obj_set_width(label4, 150);
//menu bar
/*lv_obj_t * label5;
label5 = lv_label_create(lv_scr_act(), NULL);
lv_label_set_recolor(label5, true);
lv_label_set_text(label5, "#FFFFFF Home");
lv_obj_set_width(label5, 150);
lv_obj_align(label5, NULL, LV_ALIGN_IN_BOTTOM_LEFT, 40, -10);
lv_obj_t * home_ic = lv_img_create(lv_scr_act(), NULL);
lv_img_set_src(home_ic, &home);
lv_obj_align(home_ic, label5, LV_ALIGN_OUT_TOP_MID, 0, -10);
//line object
lv_obj_t * line1;
line1 = lv_line_create(lv_scr_act(), NULL);
lv_line_set_points(line1, line_points, 2);
lv_obj_add_style(line1, LV_LINE_PART_MAIN, &style_line);
lv_obj_align(line1, home_ic, LV_ALIGN_OUT_TOP_MID, 180, -30);
lv_obj_t * microphone_ic = lv_img_create(lv_scr_act(), NULL);
lv_img_set_src(microphone_ic, µphone);
lv_obj_align(microphone_ic, home_ic, LV_ALIGN_CENTER, 120, 0);
lv_obj_t * label6;
label6 = lv_label_create(lv_scr_act(), NULL);
lv_label_set_recolor(label6, true);
lv_label_set_text(label6, "#FFFFFF Alexa ON");
lv_obj_set_width(label6, 150);
lv_obj_align(label6, microphone_ic, LV_ALIGN_OUT_BOTTOM_MID, 0, 10);
lv_obj_t * settings_ic = lv_img_create(lv_scr_act(), NULL);
lv_img_set_src(settings_ic, &settings);
lv_obj_align(settings_ic, microphone_ic, LV_ALIGN_CENTER, 120, 0);
lv_obj_t * label7;
label7 = lv_label_create(lv_scr_act(), NULL);
lv_label_set_recolor(label7, true);
lv_label_set_text(label7, "#FFFFFF Settings");
lv_obj_set_width(label7, 150);
lv_obj_align(label7, settings_ic, LV_ALIGN_OUT_BOTTOM_MID, 0, 10);
lv_obj_t * label8;
label8 = lv_label_create(lv_scr_act(), NULL);
lv_label_set_recolor(label8, true);
lv_label_set_text(label8, "#FFFFFF Lock");
lv_obj_set_width(label8, 150);
lv_obj_align(label8, NULL, LV_ALIGN_IN_BOTTOM_RIGHT, -40, -10);
lv_obj_t * lock_ic = lv_img_create(lv_scr_act(), NULL);
lv_img_set_src(lock_ic, &lock);
lv_obj_align(lock_ic, label8, LV_ALIGN_OUT_TOP_MID, 0, -10);*/
* STATIC FUNCTIONS
printf("### Switch List\n");
iotgizmo_switch_list();
list file
* @file iotgizmo_switch_list.c
* INCLUDES
#include <lv_examples/src/iotGizmo/iotgizmo_switch_list.h>
#include <stdio.h>
#if LV_USE_IOTGIZMO
* DEFINES
* TYPEDEFS
* STATIC PROTOTYPES
static void event_handler(lv_obj_t * obj, lv_event_t event);
* STATIC VARIABLES
lv_obj_t * button;
static lv_style_t style_label;
LV_IMG_DECLARE(bg)
* MACROS
* GLOBAL FUNCTIONS
void iotgizmo_switch_list(void)
//line
/*Create style*/
lv_obj_t * label1;
label1 = lv_label_create(lv_scr_act(), NULL);
lv_label_set_text(label1, "#FFFFFF Device List");
lv_obj_align(label1, NULL, LV_ALIGN_IN_TOP_MID, 0, 30);
//line object
lv_obj_t * line1;
lv_obj_align(line1, label1, LV_ALIGN_OUT_BOTTOM_MID, 0, 20);
//page
lv_obj_t * page = lv_page_create(lv_scr_act(), NULL);
lv_obj_set_size(page, 480, 780);
lv_obj_align(page, NULL, LV_ALIGN_OUT_BOTTOM_MID, 0, 20);
//style_list
static lv_style_t style_list;
lv_style_init(&style_list);
//list
lv_obj_t * list1 = lv_list_create(lv_scr_act(), NULL);
lv_obj_set_size(list1, 480, 780);
lv_list_set_scroll_propagation(list1, true);
lv_obj_set_width(list1, lv_page_get_width_fit(page));
lv_obj_set_height(list1, lv_page_get_height_fit(page));
lv_obj_align(list1, line1, LV_ALIGN_OUT_BOTTOM_MID, 0, 20);
const char * txts[] = {LV_SYMBOL_EYE_OPEN,"04e4cc",LV_SYMBOL_EYE_OPEN,"04e4db",NULL};
uint32_t i;
for(i=0;txts[i]!=NULL;i+=2){
button=lv_list_add_btn(list1,txts[i],txts[i+1]);
lv_obj_set_event_cb(button, event_handler);
* STATIC FUNCTIONS
printf("Clicked: %s\n", lv_list_get_btn_text(obj));
Please help me with this.
Thanks in Advance.
