Hellow
I have encounterd a porblem when I am using mask library.
|Error: lv_obj_del |(lv_obj.c #473 lv_obj_del())|
|Error: Invalid object (0x00005648064D6448) |(lv_debug.c #127 lv_debug_log_error())|
my simulation window size 800x480
#define LV_HOR_RES_MAX (800)
#define LV_VER_RES_MAX (480)
Ubuntu20.04 / Eclipse C/C++
7.10.0
A line which’s color from White to Green to White
I tried 2 canvas,one for color from green to white , another for color from white to green.
* @file test.c
* INCLUDES
#include "../../lv_examples.h"
#define MASK_WIDTH 800
#define MASK_HEIGHT 10
static uint32_t t;
static lv_obj_t * canvas ;
static lv_obj_t * canvas2 ;
static lv_obj_t * om1 ;
static lv_obj_t * om2 ;
static lv_obj_t * bg1 ;
static lv_obj_t * bg2 ;
static lv_point_t line_points_bg[] = { {0, 5}, {800,5 }};
static lv_opa_t mask_map[MASK_WIDTH * MASK_HEIGHT];
static lv_style_t style_bg1;
static lv_style_t style_bg2;
void aaa();
void plot_(int x);
void test()
//plot_(400);
aaa();
void aaa()
for (int i=0 ;i<=800 ;i=i+10)
//plot_bar_GtoW(i);
//plot_bar_WtoG(i);
plot_(i);
lv_refr_now(NULL);
t = lv_tick_get();
while(lv_tick_elaps(t) < 2);
void plot_(int x)
int y=800-x;
if (canvas!=NULL)
lv_obj_del(canvas);
canvas = lv_canvas_create(lv_scr_act(), NULL);
lv_obj_align(canvas, NULL, LV_ALIGN_IN_TOP_LEFT, 0, -1);
lv_canvas_set_buffer(canvas, mask_map, x, MASK_HEIGHT, LV_IMG_CF_ALPHA_8BIT);
lv_canvas_fill_bg(canvas, LV_COLOR_BLACK, LV_OPA_TRANSP);
if (canvas2!=NULL)
lv_obj_del(canvas2);
canvas2 = lv_canvas_create(lv_scr_act(), NULL);
lv_obj_align(canvas2, NULL, LV_ALIGN_IN_TOP_RIGHT, 0, -1);
lv_canvas_set_buffer(canvas2, mask_map, y, MASK_HEIGHT, LV_IMG_CF_ALPHA_8BIT);
lv_canvas_fill_bg(canvas2, LV_COLOR_BLACK, LV_OPA_TRANSP);
/*Draw a label to the canvas. The result "image" will be used as mask*/
lv_draw_line_dsc_t line_dsc;
lv_draw_line_dsc_init(&line_dsc);
line_dsc.color = LV_COLOR_WHITE;
line_dsc.width = 9;
//line_points_bg->x=x;
lv_canvas_draw_line(canvas,line_points_bg,2,&line_dsc);
lv_canvas_draw_line(canvas2,line_points_bg,2,&line_dsc);
/*The mask is reads the canvas is not required anymore*/
lv_obj_del(canvas);
/*Create an object mask which will use the created mask*/
om1 = lv_objmask_create(lv_scr_act(), NULL);
lv_obj_set_size(om1, x, MASK_HEIGHT);
lv_obj_align(om1, NULL, LV_ALIGN_IN_TOP_LEFT,0 , -1);
om2 = lv_objmask_create(lv_scr_act(), NULL);
lv_obj_set_size(om2, y, MASK_HEIGHT);
lv_obj_align(om2, NULL, LV_ALIGN_IN_TOP_RIGHT,0 , -1);
lv_draw_mask_map_param_t m1,m2;
lv_area_t a1,a2;
a1.x1 = 0;
a1.y1 = 0;
a1.x2 = x -1 ;
a1.y2 = MASK_HEIGHT-1 ;
a2.x1 = 0;
a2.y1 = 0;
a2.x2 = y -1 ;
a2.y2 = MASK_HEIGHT-1 ;
lv_draw_mask_map_init(&m1, &a1, mask_map);
lv_objmask_add_mask(om1, &m1);
lv_draw_mask_map_init(&m2, &a2, mask_map);
lv_objmask_add_mask(om2, &m2);
lv_style_init(&style_bg1);
lv_style_set_bg_opa(&style_bg1, LV_STATE_DEFAULT, LV_OPA_COVER);
lv_style_set_bg_color(&style_bg1, LV_STATE_DEFAULT, LV_COLOR_GREEN);
lv_style_set_bg_grad_color(&style_bg1, LV_STATE_DEFAULT, LV_COLOR_WHITE);
lv_style_set_bg_grad_dir(&style_bg1, LV_STATE_DEFAULT, LV_GRAD_DIR_HOR);
lv_style_init(&style_bg2);
lv_style_set_bg_opa(&style_bg2, LV_STATE_DEFAULT, LV_OPA_COVER);
lv_style_set_bg_color(&style_bg2, LV_STATE_DEFAULT, LV_COLOR_WHITE);
lv_style_set_bg_grad_color(&style_bg2, LV_STATE_DEFAULT, LV_COLOR_GREEN);
lv_style_set_bg_grad_dir(&style_bg2, LV_STATE_DEFAULT, LV_GRAD_DIR_HOR);
bg1 = lv_obj_create(om1, NULL);
lv_obj_reset_style_list(bg1, LV_OBJ_PART_MAIN);
lv_obj_add_style(bg1, LV_OBJ_PART_MAIN, &style_bg1);
lv_obj_set_size(bg1, x, MASK_HEIGHT);
bg2 = lv_obj_create(om2, NULL);
lv_obj_reset_style_list(bg2, LV_OBJ_PART_MAIN);
lv_obj_add_style(bg2, LV_OBJ_PART_MAIN, &style_bg2);
lv_obj_set_size(bg2, y, MASK_HEIGHT);
