Error: invalid conversion from 'void*' to 'lv_obj_t*' [-fpermissive]
Hello I fiddle with this awesome Project.
I Use the Cheap Yellow Display and PlatformIO
My C++ skills are limited
static void anim_x_cb(void * var, int32_t v)
    lv_obj_set_x(var, v);
static void anim_size_cb(void * var, int32_t v)
    lv_obj_set_size(var, v, v);
 * Create a playback animation
void lv_example_anim_2(void)
    lv_obj_t * obj = lv_obj_create(lv_screen_active());
    lv_obj_set_style_bg_color(obj, lv_palette_main(LV_PALETTE_RED), 0);
    lv_obj_set_style_radius(obj, LV_RADIUS_CIRCLE, 0);
    lv_obj_align(obj, LV_ALIGN_LEFT_MID, 10, 0);
    lv_anim_t a;
    lv_anim_init(&a);
    lv_anim_set_var(&a, obj);
    lv_anim_set_values(&a, 10, 50);
    lv_anim_set_duration(&a, 1000);
    lv_anim_set_playback_delay(&a, 100);
    lv_anim_set_playback_duration(&a, 300);
    lv_anim_set_repeat_delay(&a, 500);
    lv_anim_set_repeat_count(&a, LV_ANIM_REPEAT_INFINITE);
    lv_anim_set_path_cb(&a, lv_anim_path_ease_in_out);
    lv_anim_set_exec_cb(&a, anim_size_cb);
    lv_anim_start(&a);
    lv_anim_set_exec_cb(&a, anim_x_cb);
    lv_anim_set_values(&a, 10, 240);
    lv_anim_start(&a);
I have this simple example and I get the Error
error: invalid conversion from ‘void*’ to ‘lv_obj_t*’ [-fpermissive]
any clue how to solve this ?
You’re getting that error because var is a void*, while the function expects
an lv_obj_t*.
In C++, this isn’t implicitly allowed, so you need to cast it.
lv_obj_set_x((lv_obj_t *)var, v);
lv_obj_set_size((lv_obj_t *)var, v, v);
