Hi there,
I am working on interface for device controlled only by buttons.
Currently I am looking for a solution for a list.
What I have
The list should contain items with embedded controls like switches, sliders and drop down lists.
However I would like to highlight entire Container (or only the container).
something like this:
The list is constructed from Page
every entry is made from Container
inside the container there is a Label and Control element (Switch, slider, dropdown, button …)
The control element is inside the group and it is working fine.
Current implementation
I am using user data to store focus_parent and focus_child, so the parent can check if the child is focused.
I have added code to lv_obj.c / lv_obj_get_style
if (obj->user_data.child_focus)
lv_obj_t * cf = obj->user_data.child_focus;
//focus if child is focused
if(cf->group_p) {
if (lv_group_get_focused(cf->group_p) == cf)
style_act = lv_group_mod_style(cf->group_p, style_act);
And the child can invalidate the parent to force it to repaint it.
In lv_group.c / lv_group_set_editing and focus_next_core
lv_obj_t * p = (*group->obj_focus)->user_data.parent_focus;
if (p) lv_obj_invalidate(p);
I just assign the parent/child pointers to user data during element creation
//create container
c = lv_cont_create(page, NULL);
//create label
lv_obj_t * l = lv_label_create(c, NULL);
lv_label_set_text(l, text);
//create slider
lv_obj_t * slider = lv_slider_create(c, NULL);
lv_group_add_obj(group, slider);
//assign reference for parent and child focus
c->user_data.child_focus = slider;
slider->user_data.parent_focus = c;
The problem
This is working nice, however when I use dropdown as control element, the program fails with segmentation fault, because of the infinite recursion, but I am not sure why.
I do not understand fully the (re)drawing procedures, so I can be missing something trivial. How does changing the element style might lead to this behavior? I think that it might be related to calculating the redrawing area.
I am sure that problem is caused by this line, because when I remove all code causing the parent invalidation it is still happening.
Except the modifications above the lvgl code is untouched.
Maybe I am missing some easier solution to this problem?
Thank you for your advise
