Encoder not working
STM32F205RGT6
8.3
Working with the LVGL encoder. When turning the knob to the right in data->enc_diff = 1; and on the left data->enc_diff = -1; in normal position data->enc_diff = 0; When I rotate the encoder and press the button, I observe the event in the debugger. But nothing works. Works well with touch screen. Please help. Sorry, English is not my native language, I can’t explain it better. Thank you.
Encoder_Init();
lv_indev_drv_t indev_drv;
indev_drv.type = LV_INDEV_TYPE_ENCODER;
indev_drv.read_cb = encoder_read;
void encoder_read(lv_indev_drv_t * drv, lv_indev_data_t*data){
data->enc_diff = StateRead();
if(!enc_pressed()) data->state = LV_INDEV_STATE_PRESSED;
else data->state = LV_INDEV_STATE_RELEASED;
Read Input device interface — LVGL documentation
To use an Encoder (similarly to the Keypads ) the objects should be added to groups. Because system dont know what is controlled as on touch.
Thanks for your help. I did this and it worked.
Encoder_Init();
encoder_indev = lv_indev_drv_register(&indev_drv);
g = lv_group_create();
lv_group_set_default(g);
lv_indev_set_group(encoder_indev, g);
bool encoder_read(lv_indev_drv_t * drv, lv_indev_data_t*data)
data->enc_diff = TIM4_read();
if (data->enc_diff > 0)
data->key = LV_KEY_LEFT;
if (data->enc_diff < 0)
data->key = LV_KEY_RIGHT;
if (!enc_pressed())
data->key = LV_KEY_ENTER;
else data->state = LV_INDEV_STATE_REL;
return false;
