Enabling Helium Acceleration on STM32N6 (CM55)
Hello.
I’m currently experimenting with LVGL on STM32N6. I have project up and running and the benchmark runs well with either the Nema GPU or with SW rendering.
I’m mainly interested in experimenting with the performance gains from using the Arm2D library with helium acceleration. The N6 should be capable due to it’s CM55 core. However i can’t get it working nicely.
I have added Arm2D manually to my project and everything compiles when enabling
  • LV_USE_DRAW_ARM2D_SYNC
  • LV_USE_NATIVE_HELIUM_ASM
However, no helium acceleration is present.
What is the intended way to enable helium acceleration?
STM32N6570-DK
IAR and MDK-ARM
Branch: Master
Commit: 7ab421ed30fdc679895d8db0a86c39b44d0feee4
Helium acceleration using Arm2D on STM32N6.
Enabling:
Have also tried setting
#define LV_USE_DRAW_SW_ASM LV_DRAW_SW_ASM_HELIUM
But then it does not compile.
The application is using ThreadX (Azure RTOS). The main task lvgl_app is shown below.
void lvgl_app(void)
    /* initialize LVGL framework */
#if (LV_USE_NEMA_GFX == 0)
    nema_init();
#if (LV_COLOR_DEPTH==32)
    init_display(NEMA_BGRA8888, 2);
#elif (LV_COLOR_DEPTH==16)
    init_display(NEMA_RGB565, 2);
#else
#error
    lv_tick_set_cb(get_time_cb);
    lvgl_display_init();
    lv_demo_benchmark();
    while (1)
        lv_timer_handler();
        /* Sleep for 5ms */
        tx_thread_sleep(5);
Hi andreasp,
I just started to explore and port lvgl to the same STM32N6570-DK, I might be of help, but for me currently SW rendering with and without DMA2D is very laggy and lots of screan tear is being observed. Did you face that issue? Do you have any repo or references for stm32n6 with lvgl.
Thank you
