Try to use ElegantOTA library, but appears that the call “lv_task_handler()” in the loop function cause a bootloop of the board.
Honestly i don’t know if this is the correct place where to post this problem i’ve encountered.
MakerFabs Esp32 S3 with Arduino IDE
LVGL 9.1.0
I want to add the feature to upload via OTA a new update to the board.
Different test, appears that the code for ElegantOta works perfectly on ESP32 S3, but used in my context, keeps crashing.
I’ve tried to add the “ElegantOTA.loop()” in a separate task, with FreeRTOS, but appears to be not linked to my issue.
I’ve also attempted to select a different core into the library Async_TCP, but nothing changed . This is the define that i’ve changed “CONFIG_ASYNC_TCP_RUNNING_CORE”.
#include <WiFi.h>
#include <AsyncTCP.h>
#include <ESPAsyncWebServer.h>
#include <ElegantOTA.h>
const char* WIFI_SSID = "FILMACHINE_WIFI";
const char* WIFI_PASSWORD = "password";
const char* USERNAME = "username";
const char* PASSWORD = "password";
void connectOtaAP(){
WiFi.softAP(WIFI_SSID, WIFI_PASSWORD);
IPAddress myIP = WiFi.softAPIP();
LV_LOG_USER("AP IP address: %s",myIP.toString());
ElegantOTA.setAutoReboot(true);
ElegantOTA.setAuth(USERNAME, PASSWORD);
ElegantOTA.begin(&otaServer);
// ElegantOTA callbacks
ElegantOTA.onStart(onOTAStart);
ElegantOTA.onProgress(onOTAProgress);
ElegantOTA.onEnd(onOTAEnd);
otaServer.begin();
LV_LOG_USER("Server started");
void loop()
ElegantOTA.loop();
delay(5);
Any kind of suggestion is appreciated!
Thanks in advance!
