Dynamically resizing a display
Emscripten/HTML5.
I want to change the logical display width/height in LittlevGL and have the whole UI redraw itself.
I have implemented the ability to resize my window, but I’m not sure how to safely inform LittlevGL that the display size just changed.
I don’t think this should be necessary.
Right now LittlevGL appears in the top left corner of my window at the default size and the remaining space is black.
You should use lv_disp_drv_update
Thanks! That works perfectly.
How do I force the whole screen to be refreshed? At the moment I am using lv_obj_invalidate(lv_disp_get_scr_act(disp)) but I’m not sure if that is the right way to do it or not (plus that won’t refresh the top/sys layers).
Sys and Top layers are always drawn so lv_obj_invalidate(lv_disp_get_scr_act(disp)) should be fine. Note that if you have only one display lv_obj_invalidate(lv_scr_act()) also works.
