xr872
8.2.0
1.I have two font files, one containing “abc” and one containing “def”.
2.Use create_label() to create a label,now it only display “abc”
3.Use load_font(),it’s still just showing “abc”
4. What should I do to display “abcdef”
I try to use lv_refr_now(lv_disp_t * disp) and _lv_inv_area(lv_disp_t * disp, const lv_area_t * area_p), but none of them worked
Hello, it seems to me that the fallback font is only used when there are no symbols/glyphs for a character in a font. Say you have two fonts with the following glyphs:
Font 1: ABCDEFG
Font 2: ABCDEFGHIJKL (fallback font!)
Now let’s say you want to set a label to say “HELLO”
it will recognize that font 1 does not have the H and L, so it uses the H and L from the fallback font.
Result would be: HELLO .
I’m not sure what you want to achieve with this code here, could you explain?
I think you need to load the font first, including the fallback, and then try to put text in a label.
When I set a label, the fallback for Font 1 is NULL. Maybe later, I’ll download Font 2 from the Internet, at which point I’ll set the Font1->fallback = Font 2.
At this point, how do we make the Font that is not in Font 1 appear without recreate the label?
