I still can’t reproduce the issue when I use arial font, what I tried to to create a new v8 project, add a dropdown widget and add 9 items with corresponding text, the whitespace is displayed. It would be helpful to troubleshoot if you can share a simple project to reproduce the issue.
The following is code of my setup_scr_screen.c.
static void _screen_ddlist_menu_event_cb(lv_event_t * e)
//Write style state: LV_STATE_DEFAULT for style_screen_ddlist_menu_extra_list_selected_default
static lv_style_t style_screen_ddlist_menu_extra_list_selected_default;
if (style_screen_ddlist_menu_extra_list_selected_default.prop_cnt > 1)
lv_style_reset(&style_screen_ddlist_menu_extra_list_selected_default);
lv_style_init(&style_screen_ddlist_menu_extra_list_selected_default);
lv_style_set_radius(&style_screen_ddlist_menu_extra_list_selected_default, 3);
lv_style_set_bg_color(&style_screen_ddlist_menu_extra_list_selected_default, lv_color_make(0x00, 0xa1, 0xb5));
lv_style_set_bg_grad_color(&style_screen_ddlist_menu_extra_list_selected_default, lv_color_make(0x00, 0xa1, 0xb5));
lv_style_set_bg_grad_dir(&style_screen_ddlist_menu_extra_list_selected_default, LV_GRAD_DIR_VER);
lv_style_set_bg_opa(&style_screen_ddlist_menu_extra_list_selected_default, 255);
lv_style_set_border_color(&style_screen_ddlist_menu_extra_list_selected_default, lv_color_make(0xe1, 0xe6, 0xee));
lv_style_set_border_width(&style_screen_ddlist_menu_extra_list_selected_default, 1);
lv_style_set_text_color(&style_screen_ddlist_menu_extra_list_selected_default, lv_color_make(0xff, 0xff, 0xff));
lv_style_set_text_font(&style_screen_ddlist_menu_extra_list_selected_default, &lv_font_simsun_12);
lv_obj_add_style(lv_dropdown_get_list(obj), &style_screen_ddlist_menu_extra_list_selected_default, LV_PART_SELECTED|LV_STATE_DEFAULT);
//Write style state: LV_STATE_DEFAULT for style_screen_ddlist_menu_extra_list_main_default
static lv_style_t style_screen_ddlist_menu_extra_list_main_default;
if (style_screen_ddlist_menu_extra_list_main_default.prop_cnt > 1)
lv_style_reset(&style_screen_ddlist_menu_extra_list_main_default);
lv_style_init(&style_screen_ddlist_menu_extra_list_main_default);
lv_style_set_radius(&style_screen_ddlist_menu_extra_list_main_default, 3);
lv_style_set_bg_color(&style_screen_ddlist_menu_extra_list_main_default, lv_color_make(0x75, 0x75, 0x75));
lv_style_set_bg_grad_color(&style_screen_ddlist_menu_extra_list_main_default, lv_color_make(0x78, 0x78, 0x78));
lv_style_set_bg_grad_dir(&style_screen_ddlist_menu_extra_list_main_default, LV_GRAD_DIR_VER);
lv_style_set_bg_opa(&style_screen_ddlist_menu_extra_list_main_default, 255);
lv_style_set_border_color(&style_screen_ddlist_menu_extra_list_main_default, lv_color_make(0xe1, 0xe6, 0xee));
lv_style_set_border_width(&style_screen_ddlist_menu_extra_list_main_default, 1);
lv_style_set_text_color(&style_screen_ddlist_menu_extra_list_main_default, lv_color_make(0x0D, 0x30, 0x55));
lv_style_set_text_font(&style_screen_ddlist_menu_extra_list_main_default, &lv_font_arial_12);
lv_style_set_max_height(&style_screen_ddlist_menu_extra_list_main_default, 220);
lv_obj_add_style(lv_dropdown_get_list(obj), &style_screen_ddlist_menu_extra_list_main_default, LV_PART_MAIN|LV_STATE_DEFAULT);
//Write style state: LV_STATE_DEFAULT for style_screen_ddlist_menu_extra_list_scrollbar_default
static lv_style_t style_screen_ddlist_menu_extra_list_scrollbar_default;
if (style_screen_ddlist_menu_extra_list_scrollbar_default.prop_cnt > 1)
lv_style_reset(&style_screen_ddlist_menu_extra_list_scrollbar_default);
lv_style_init(&style_screen_ddlist_menu_extra_list_scrollbar_default);
lv_style_set_radius(&style_screen_ddlist_menu_extra_list_scrollbar_default, 3);
lv_style_set_bg_color(&style_screen_ddlist_menu_extra_list_scrollbar_default, lv_color_make(0x00, 0xff, 0x00));
lv_style_set_bg_grad_color(&style_screen_ddlist_menu_extra_list_scrollbar_default, lv_color_make(0xff, 0xff, 0xff));
lv_style_set_bg_grad_dir(&style_screen_ddlist_menu_extra_list_scrollbar_default, LV_GRAD_DIR_VER);
lv_style_set_bg_opa(&style_screen_ddlist_menu_extra_list_scrollbar_default, 255);
lv_obj_add_style(lv_dropdown_get_list(obj), &style_screen_ddlist_menu_extra_list_scrollbar_default, LV_PART_SCROLLBAR|LV_STATE_DEFAULT);
void setup_scr_screen(lv_ui *ui){
//Write codes screen
ui->screen = lv_obj_create(NULL);
//Write style state: LV_STATE_DEFAULT for style_screen_main_main_default
static lv_style_t style_screen_main_main_default;
if (style_screen_main_main_default.prop_cnt > 1)
lv_style_reset(&style_screen_main_main_default);
lv_style_init(&style_screen_main_main_default);
lv_style_set_bg_color(&style_screen_main_main_default, lv_color_make(0xff, 0xff, 0xff));
lv_style_set_bg_opa(&style_screen_main_main_default, 0);
lv_obj_add_style(ui->screen, &style_screen_main_main_default, LV_PART_MAIN|LV_STATE_DEFAULT);
//Write codes screen_ddlist_menu
ui->screen_ddlist_menu = lv_dropdown_create(ui->screen);
lv_obj_set_pos(ui->screen_ddlist_menu, 1, 11);
lv_obj_set_width(ui->screen_ddlist_menu, 130);
lv_dropdown_set_options(ui->screen_ddlist_menu, "Brightness\nComm Interface\nScr Save Style\nScr Save Time\nPresets Saving\nAntelope Button\nFactory Reset\nDevice Info\nTouch Scr Calibr");
lv_obj_add_event_cb(ui->screen_ddlist_menu, _screen_ddlist_menu_event_cb, LV_EVENT_READY, NULL);
//Write style state: LV_STATE_DEFAULT for style_screen_ddlist_menu_main_main_default
static lv_style_t style_screen_ddlist_menu_main_main_default;
if (style_screen_ddlist_menu_main_main_default.prop_cnt > 1)
lv_style_reset(&style_screen_ddlist_menu_main_main_default);
lv_style_init(&style_screen_ddlist_menu_main_main_default);
lv_style_set_radius(&style_screen_ddlist_menu_main_main_default, 3);
lv_style_set_bg_color(&style_screen_ddlist_menu_main_main_default, lv_color_make(0x6b, 0x6b, 0x6b));
lv_style_set_bg_grad_color(&style_screen_ddlist_menu_main_main_default, lv_color_make(0x70, 0x70, 0x70));
lv_style_set_bg_grad_dir(&style_screen_ddlist_menu_main_main_default, LV_GRAD_DIR_VER);
lv_style_set_bg_opa(&style_screen_ddlist_menu_main_main_default, 255);
lv_style_set_border_color(&style_screen_ddlist_menu_main_main_default, lv_color_make(0xe1, 0xe6, 0xee));
lv_style_set_border_width(&style_screen_ddlist_menu_main_main_default, 1);
lv_style_set_text_color(&style_screen_ddlist_menu_main_main_default, lv_color_make(0xff, 0xff, 0xff));
lv_style_set_text_font(&style_screen_ddlist_menu_main_main_default, &lv_font_arial_12);
lv_style_set_text_line_space(&style_screen_ddlist_menu_main_main_default, 20);
lv_obj_add_style(ui->screen_ddlist_menu, &style_screen_ddlist_menu_main_main_default, LV_PART_MAIN|LV_STATE_DEFAULT);
