We have a dropdown list that can contain up to 2000 items in it, but when paging down it reaches 256 and the scrollbar indicates it’s at the end of the list but you can still page down and the item is displayed in main part of the dropdown but the dropdown list part stays at 256.
I can reproduce this on my Linux PC using SDL and on the actual target which is SAMA5D1 board running Linux.
v8.3
I would like to be able to page all the way down to the end.
I can’t find any solution. I’ve checked through the configuration files but can’t find any limit on drop down lists.
Here is example code to reproduce on a Linux PC, it creates 2000 items, 0000, 0001, … 1999 and uses left and right arrow keys to page up and down by 10.
#include "lvgl.h"
#include "lv_drivers/sdl/sdl.h"
#include <stdio.h>
#include <stdlib.h>
#include <unistd.h>
#include <sys/time.h>
#define ITEM_COUNT 2000
#define SDL_HOR_RES 320
#define SDL_VER_RES 240
static lv_color_t buf1[SDL_HOR_RES * SDL_VER_RES];
static lv_group_t *group;
static void keyboard_event_cb(lv_event_t *e)
lv_obj_t *cb = lv_event_get_target(e);
if (code == LV_EVENT_KEY) {
uint32_t key = lv_event_get_key(e);
switch (key) {
case LV_KEY_UP:
lv_dropdown_set_selected(cb, lv_dropdown_get_selected(cb) - 1);
break;
case LV_KEY_DOWN:
lv_dropdown_set_selected(cb, lv_dropdown_get_selected(cb) + 1);
break;
case LV_KEY_LEFT: {
int sel = lv_dropdown_get_selected(cb) - 10;
lv_dropdown_set_selected(cb, sel < 0 ? 0 : sel);
break;
case LV_KEY_RIGHT: {
int sel = lv_dropdown_get_selected(cb) + 10;
if (sel >= ITEM_COUNT) sel = ITEM_COUNT - 1;
lv_dropdown_set_selected(cb, sel);
break;
static char options[(ITEM_COUNT * 5)]; // Each item is "0000\n" (4 chars + 1 for '\0')
static void create_combobox(void)
lv_obj_t *cb = lv_dropdown_create(lv_scr_act());
lv_obj_set_size(cb, 150, 40);
lv_obj_align(cb, LV_ALIGN_CENTER, 0, 0);
for (int i = 0; i < ITEM_COUNT; i++) {
snprintf(&options[i*5], 6, "%04d\n", i);
options[(ITEM_COUNT * 5)-1] = '\0';
lv_dropdown_set_options_static(cb, options);
lv_obj_add_event_cb(cb, keyboard_event_cb, LV_EVENT_KEY, NULL);
// Add dropdown to the group to receive keyboard input
lv_group_add_obj(group, cb);
lv_group_focus_obj(cb);
int main(void)
/* Use the 'sdl' driver which creates window on PC's monitor to simulate a display*/
sdl_init();
lv_disp_draw_buf_init(&draw_buf, buf1, NULL, SDL_HOR_RES * SDL_VER_RES);
lv_disp_drv_init(&disp_drv);
disp_drv.flush_cb = sdl_display_flush;
disp_drv.hor_res = SDL_HOR_RES;
disp_drv.ver_res = SDL_VER_RES;
indev_drv.type = LV_INDEV_TYPE_KEYPAD;
indev_drv.read_cb = sdl_keyboard_read;
lv_indev_t *kb_indev = lv_indev_drv_register(&indev_drv);
// Create a group for keyboard input
group = lv_group_create();
lv_indev_set_group(kb_indev, group);
create_combobox();
while(!sdl_quit_qry) {
lv_timer_handler();
usleep(5000); // Sleep for 5 milliseconds
return 0;
uint32_t
custom_tick_get(void)
static uint64_t start_ms = 0;
struct timeval tv_now;
uint64_t now_ms;
uint32_t time_ms;
if (start_ms == 0) {
struct timeval tv_start;
gettimeofday(&tv_start, NULL);
start_ms = (tv_start.tv_sec * 1000000 + tv_start.tv_usec) / 1000;
gettimeofday(&tv_now, NULL);
now_ms = (tv_now.tv_sec * 1000000 + tv_now.tv_usec) / 1000;
time_ms = now_ms - start_ms;
return time_ms;
