I don’t see that you’ve picked a style anywhere. I copied the code you gave me and I see the drop-down, but I didn’t give this object a style so it’s using the defaults. I see this:
And per embeddedt’s post, my default font is LV_FONT_ROBOTO_22.
No dice.
And I made a mistake in my earlier post, I had not set a style for this drop down. I am using the material theme as the default theme. I’m not sure if that’s playing a part or not.
I changed my theme to use this explicitly, and I still see the drop-down arrow. Sorry, I don’t know how much more help I can be at this point.
Are you developing in the PC Simulator, or in an embedded device? If the latter, perhaps you could give the simulator a try as this helps me rule out whether the problem is in the library or my embedded environment.
