Hi all,
I have a project with ESP32 and ILI9844 LCD. It’s mostly working, though having a little trouble with drawing sprites cleanly. Since I’m planning on using LVGL for some parts of the project anyway, I was wondering if I can use LVGL to draw this kind of thing:
https://imgur.com/gallery/HKP3Cpa
If it’s possible, could someone point me in the direction of a tutorial or wiki that covers this, please? Even just the name of the functions so I can research them myself.
Happy new year,
Dax.
Hey gang,
Any thoughts on this for a LVGL newbie, please?
I would start with an image asset and display that using the lv_img widget.
You can use a transformation to rotate the image along a pivot point.
If you create the asset so that the top-left corner is the main point of the triangle and pivot point, you can use lv_obj_set_pos to easily move it to the right position.
LV_IMG_DECLARE(img_asset);
lv_obj_t * img = lv_img_create(lv_scr_act());
lv_img_set_src(img, &img_asset);
lv_img_set_pivot(img, 0, 0); // 0;0 is the top left corner.
lv_img_set_angle(img, 450); // rotate 45 degrees
lv_obj_set_pos(img, 10, 20); // move to coordinate 10;20
I hope you get the idea.
@fvanroie, thank you so much for taking the time to write about these. I truly appreciate it!
Also, that’s great news. I’ll read through all of the links you provided and give it a shot.
Thanks again and happy new year.
-Dax.
