Hello I tried a couple of example without success the Display kept black, so I tried an approach like this
I see the Line from the WROVER example but no result after Line 145
Any clue what I’m doing wrong
This is our GFX example for the Adafruit ILI9341 Breakout and Shield
----> http://www.adafruit.com/products/1651
Check out the links above for our tutorials and wiring diagrams
These displays use SPI to communicate, 4 or 5 pins are required to
interface (RST is optional)
Adafruit invests time and resources providing this open source code,
please support Adafruit and open-source hardware by purchasing
products from Adafruit!
Written by Limor Fried/Ladyada for Adafruit Industries.
MIT license, all text above must be included in any redistribution
#include "SPI.h"
#include "Adafruit_GFX.h"
#include "WROVER_KIT_LCD.h"
#include "../lvgl/src/lvgl.h"
#define min(X, Y) (((X) < (Y)) ? (X) : (Y))
WROVER_KIT_LCD tft;
static lv_disp_buf_t disp_buf; //LVGL stuff;
lv_disp_drv_t disp_drv;
lv_indev_drv_t indev_drv;
lv_obj_t * btn1;
lv_obj_t * btn2;
lv_obj_t *screenMain;
lv_obj_t *label;
static void event_handler_btn(lv_obj_t * obj, lv_event_t event){
if (obj == btn1)
lv_label_set_text(label, "Hello");
else if (obj == btn2){
lv_label_set_text(label, "Goodbye");
uint32_t wh = w*h;
tft.startWrite();
while (wh--) tft.pushColor(color_p++->full);//for Adafruit library
tft.endWrite();
lv_disp_flush_ready(disp);
printf("Clicked\n");
else if(event == LV_EVENT_VALUE_CHANGED) {
printf("Toggled\n");
void lv_ex_btn_1(void)
lv_obj_t * label;
lv_obj_t * btn1 = lv_btn_create(lv_scr_act(), NULL);
lv_obj_set_event_cb(btn1, event_handler);
lv_obj_align(btn1, NULL, LV_ALIGN_CENTER, 0, -40);
label = lv_label_create(btn1, NULL);
lv_obj_t * btn2 = lv_btn_create(lv_scr_act(), NULL);
lv_obj_set_event_cb(btn2, event_handler);
lv_obj_align(btn2, NULL, LV_ALIGN_CENTER, 0, 40);
lv_btn_set_checkable(btn2, true);
lv_btn_toggle(btn2);
lv_btn_set_fit2(btn2, LV_FIT_NONE, LV_FIT_TIGHT);
label = lv_label_create(btn2, NULL);
lv_label_set_text(label, "Toggled");
void setup() {
Serial.begin(115200);
unsigned long testLines(uint16_t color);
unsigned long testFastLines(uint16_t color1, uint16_t color2);
unsigned long testFilledRects(uint16_t color1, uint16_t color2);
tft.begin();
tft.setRotation(1);
uint8_t x = 0;
uint32_t id = tft.readId();
if(id){
Serial.println("======= WROVER ST7789V Display Test ========");
} else {
Serial.println("======= WROVER ILI9341 Display Test ========");
Serial.println("============================================");
Serial.printf("Display ID: 0x%06X\n", id);
x = tft.readcommand8(WROVER_RDDST);
Serial.print("Status: 0x"); Serial.println(x, HEX);
x = tft.readcommand8(WROVER_RDDPM);
Serial.print("Power Mode: 0x"); Serial.println(x, HEX);
x = tft.readcommand8(WROVER_RDDMADCTL);
Serial.print("MADCTL Mode: 0x"); Serial.println(x, HEX);
x = tft.readcommand8(WROVER_RDDCOLMOD);
Serial.print("Pixel Format: 0x"); Serial.println(x, HEX);
x = tft.readcommand8(WROVER_RDDIM);
Serial.print("Image Format: 0x"); Serial.println(x, HEX);
x = tft.readcommand8(WROVER_RDDSDR);
Serial.print("Self Diagnostic: 0x"); Serial.println(x, HEX);
Serial.println(F("Benchmark Time (microseconds)"));
delay(10);
Serial.print(F("Lines "));
Serial.println(testLines(WROVER_CYAN));
delay(500);
Serial.print(F("Horiz/Vert Lines "));
Serial.println(testFastLines(WROVER_RED, WROVER_BLUE));
delay(500);
Serial.println(F("Done!"));
lv_disp_buf_init(&disp_buf, buf, NULL, LV_HOR_RES_MAX * 10);
/*Initialize the display*/
lv_disp_drv_init(&disp_drv);
disp_drv.hor_res = 320;
disp_drv.ver_res = 240;
disp_drv.buffer = &disp_buf;
/* Try an example from the lv_examples repository
* https://github.com/lvgl/lv_examples*/
lv_ex_btn_1();
Serial.print("<----------------- ********* ------------------>");
void loop(void) {
lv_task_handler();
delay(1);
unsigned long testFillScreen() {
unsigned long start = micros();
tft.fillScreen(WROVER_BLACK);
yield();
tft.fillScreen(WROVER_RED);
yield();
tft.fillScreen(WROVER_GREEN);
yield();
tft.fillScreen(WROVER_BLUE);
yield();
yield();
return micros() - start;
unsigned long start, t;
int x1, y1, x2, y2,
w = tft.width(),
h = tft.height();
yield();
x1 = y1 = 0;
y2 = h - 1;
start = micros();
for(x2=0; x2<w; x2+=6) tft.drawLine(x1, y1, x2, y2, color);
x2 = w - 1;
for(y2=0; y2<h; y2+=6) tft.drawLine(x1, y1, x2, y2, color);
t = micros() - start; // fillScreen doesn't count against timing
yield();
yield();
x1 = w - 1;
y1 = 0;
y2 = h - 1;
start = micros();
x2 = 0;
t += micros() - start;
yield();
yield();
x1 = 0;
y1 = h - 1;
y2 = 0;
start = micros();
x2 = w - 1;
yield();
yield();
x1 = w - 1;
y1 = h - 1;
y2 = 0;
start = micros();
x2 = 0;
yield();
unsigned long start;
int x, y, w = tft.width(), h = tft.height();
start = micros();
for(y=0; y<h; y+=5) tft.drawFastHLine(0, y, w, color1);
for(x=0; x<w; x+=5) tft.drawFastVLine(x, 0, h, color2);
unsigned long testRects(uint16_t color) {
int n, i, i2,
cx = tft.width() / 2,
cy = tft.height() / 2;
n = min(tft.width(), tft.height());
start = micros();
for(i=2; i<n; i+=6) {
i2 = i / 2;
tft.drawRect(cx-i2, cy-i2, i, i, color);
unsigned long start, t = 0;
int n, i, i2,
cx = tft.width() / 2 - 1,
cy = tft.height() / 2 - 1;
for(i=n; i>0; i-=6) {
i2 = i / 2;
start = micros();
tft.fillRect(cx-i2, cy-i2, i, i, color1);
// Outlines are not included in timing results
tft.drawRect(cx-i2, cy-i2, i, i, color2);
yield();
return t;
