Do transitions require call backs?
I am trying to implement a transition on some some text to change color. More generally, I am trying to understand how transitions work. I am adapting the code from this style example as my starting place: Styles — LVGL documentation
As well as this on sending events:
https://docs.lvgl.io/9.2/overview/event.html#custom-events
I have a sense I am approaching this incorrectly. Maybe I need a call back function?
Arduino Giga with Arduino IDE 2.3.4
9.2.2
I want my code to transition from one color to another, similar to the button transition example in the docs.
Meshing some basic example code from the docs.
I know this is not the simulator code. Trying to understand how the simulator works in practice has been a bit of challenge.
If this is not acceptable, I understand. And thoughts would be highly appreciated. All the best.
#include "Arduino_BMI270_BMM150.h"
#include "Arduino_H7_Video.h"
#include "lvgl.h"
#include "lv_conf.h"
Arduino_H7_Video Display(800, 480, GigaDisplayShield); /* Arduino_H7_Video Display(1024, 768, USBCVideo); */
BoschSensorClass imu(Wire1);
// Custom Event
uint32_t SHAKE_EVENT;
// Text
lv_obj_t * label;
void setup() {
  Serial.begin(9600);
  Display.begin();
  imu.begin();
  // Register Custom Even
  SHAKE_EVENT = lv_event_register_id();
  /******* Transitions ************************************/
  // Properties that will change during a transition
  static const lv_style_prop_t trans_props[] = {
    LV_STYLE_TEXT_COLOR,
    0, /*End marker*/
  // Show Fortune Transition Description
  static lv_style_transition_dsc_t trans_show_fortune;
  lv_style_transition_dsc_init(&trans_show_fortune, trans_props, lv_anim_path_ease_out, 500, 100, NULL);
  // Get Fortune Transition Description
  static lv_style_transition_dsc_t trans_get_fortune;
  lv_style_transition_dsc_init(&trans_get_fortune, trans_props, lv_anim_path_ease_out, 1000, 0, NULL);
  /******** Styles **********************************/
  // Default Style
  static lv_style_t style_show_fortune;
  lv_style_init(&style_show_fortune);
  lv_style_set_text_font(&style_show_fortune, &lv_font_montserrat_42);
  lv_style_set_text_color(&style_show_fortune, lv_color_hex(0x2ecc71));
  lv_style_set_transition(&style_show_fortune, &trans_show_fortune);
  // Shake Style
  static lv_style_t style_get_fortune;
  lv_style_init(&style_get_fortune);
  lv_style_set_text_color(&style_get_fortune, lv_color_hex(0xEF7422));
  lv_style_set_transition(&style_get_fortune, &trans_get_fortune);
  /* Objects **********************************/
  /*Create an object with the new style*/
  label = lv_label_create(lv_screen_active());
  lv_obj_center(label);
  lv_label_set_text(label, "Drag me!");
  lv_obj_add_style(label, &style_show_fortune, 0);
  lv_obj_add_style(label, &style_get_fortune, SHAKE_EVENT);
void loop() {
  float x, y, z;
  static int count = 0;
  if (imu.accelerationAvailable()) {
    imu.readAcceleration(x, y, z);
    if (z < 0.8 && z > -0.8) {
      Serial.println(count++);
      lv_obj_send_event(label, LV_EVENT_PRESSED, NULL);
  lv_timer_handler();
