First of all, sorry, this is going to be a long response.
Have you tried using a different library just to check there are no issues with your hardware or wiring.
Yes, after I posted my last reply I started testing with other libraries, actually just with Bodmer’s TFT_eSPI with Arduino IDE. I trusted this library since this is where I got the image of the display pinout (see my first post).
Well, the screen was still not working, so I decided to check again the connections, and in LCD Wiki I found that the display has two 5V pins instead of the one declared in the image mentioned. So I connected it, uploaded the graphics_test sketch and it works good as new.
So I thought that I could just copy the init sequence from Bodmer’s script (I also tried from other authors with different init sequences) into the ili9XXX.py script and it would work, since the flush method seems to be the same for ili9341 and ili9486. Turns out it did not, and I am again lost as to why, since this configuration works in TFT_eSPI.
In case anyone wants to see what I am doing, I’ll paste my ili9486 class:
class ili9486(ili9XXX):
def __init__(self,
miso=5, mosi=18, clk=19, cs=13, dc=12, rst=4, power=14, backlight=15, backlight_on=0, power_on=0,
spihost=esp.HSPI_HOST, mhz=40, factor=8, hybrid=True, width=320, height=480,
colormode=COLOR_MODE_BGR, rot=PORTRAIT, invert=False, double_buffer=True, half_duplex=True,
asynchronous=False, initialize=True
if lv.color_t.__SIZE__ != 2:
raise RuntimeError('ili9486 micropython driver requires defining LV_COLOR_DEPTH=16')
if colormode == COLOR_MODE_BGR and not hasattr(lv.color_t().ch, 'green_l'):
raise RuntimeError('ili9486 BGR color mode requires defining LV_COLOR_16_SWAP=1')
self.display_name = 'ILI9486'
self.display_type = DISPLAY_TYPE_ILI9486
self.init_cmds = [
# ustropo's & gfxlcd config (not working)
#{'cmd': 0xB0, 'data': bytes([0x00])}, # Interface Mode Control
#{'cmd': 0x11, 'data': bytes([0]), 'delay': 120}, # Sleep OUT
#{'cmd': 0x3A, 'data': bytes([0x55])}, # Interface Pixel Format (55 = 16 bits)
#{'cmd': 0xB6, 'data': bytes([0x0A, 0x02, 0x3B])}, # Display Function Control
#{'cmd': 0xC2, 'data': bytes([0x44])}, # Power Control 3, Normal Mode
#{'cmd': 0xC5, 'data': bytes([0x00, 0x00, 0x00, 0x00])}, # VCOM Control
#{'cmd': 0xE0, 'data': bytes([0x0F, 0x1F, 0x1C, 0x0C, 0x0F, 0x08, 0x48, 0x98, 0x37, 0x0A, 0x13, 0x04, 0x11, 0x00, 0x00])}, # Positive Gamma Correction
#{'cmd': 0xE1, 'data': bytes([0x0F, 0x32, 0x2E, 0x0B, 0x0D, 0x05, 0x47, 0x75, 0x37, 0x06, 0x10, 0x03, 0x24, 0x20, 0x00])}, # Negative Gamma Correction
#{'cmd': 0xE2, 'data': bytes([0x0F, 0x32, 0x2E, 0x0B, 0x0D, 0x05, 0x47, 0x75, 0x37, 0x06, 0x10, 0x03, 0x24, 0x20, 0x00])}, # Digital Gamma Control
#{'cmd': 0x36, 'data': bytes([rot | colormode])}, # Memory Access Control
#{'cmd': 0x29, 'data': bytes([0]), 'delay': 120} # Display ON
# lvgl_esp32_drivers & Bodmer's config (not working)
{'cmd': 0xC2, 'data': bytes([0x44])}, # Memory Write
{'cmd': 0x20, 'data': bytes([0])}, # Inversion OFF
{'cmd': 0x29, 'data': bytes([0]), 'delay': 150} # Display ON
# Waveshare_ILI9486 config (not working)
#{'cmd': 0xC0, 'data': bytes([0x19, 0x1A])}, # Power Control 1
#{'cmd': 0xC1, 'data': bytes([0x45, 0x00])}, # Power Control 2
#{'cmd': 0xC2, 'data': bytes([0x33])}, # Power Control 3, Normal Mode
#{'cmd': 0xC5, 'data': bytes([0x00, 0x28])}, # VCOM Control
#{'cmd': 0xB1, 'data': bytes([0xA0, 0x11])}, # Frame Rate Control
#{'cmd': 0xB4, 'data': bytes([0x02])}, # Display Inversion Control
#{'cmd': 0xB6, 'data': bytes([0x00, 0x42, 0x3B])}, # Display Function Control
#{'cmd': 0xE0, 'data': bytes([0x1F, 0x25, 0x22, 0x0B, 0x06, 0x0A, 0x4E, 0xC6, 0x39, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00])}, # Positive Gamma Correction
#{'cmd': 0xE1, 'data': bytes([0x1F, 0x3F, 0x3F, 0x0F, 0x1F, 0x0F, 0x46, 0x49, 0x31, 0x05, 0x09, 0x03, 0x1C, 0x1A, 0x00])}, # Negative Gamma Correction
#{'cmd': 0x20, 'data': bytes([0])}, # Inversion OFF
#{'cmd': 0x29, 'data': bytes([0]), 'delay': 150}
# way5's stm32 config (not working)
#{'cmd': 0x38, 'data': bytes([0])}, # Idle Mode OFF
#{'cmd': 0xB1, 'data': bytes([0xB0, 0x11])}, # Frame Rate Control
#{'cmd': 0xC2, 'data': bytes([0x55])}, # Power Control 3, Normal Mode
#{'cmd': 0xB6, 'data': bytes([0x02, 0x22, 0x3B])}, # Display Function Control
#{'cmd': 0x11, 'data': bytes([0]), 'delay': 150}, # Sleep OUT
#{'cmd': 0x29, 'data': bytes([0]), 'delay': 150} # Display ON
# My own config (not working, too)
#{'cmd': 0xC0, 'data': bytes([0x13, 0x13])}, # Power Control 1
#{'cmd': 0xC1, 'data': bytes([0x42, 0x30])}, # Power Control 2
#{'cmd': 0xB1, 'data': bytes([0xB0, 0x17])},
#{'cmd': 0x2A, 'data': bytes([0x00, 0x00, 0x01, 0x3F])}, # Column Address Set
#{'cmd': 0x2B, 'data': bytes([0x00, 0x00, 0x01, 0xDF])}, # Page Address Set
#{'cmd': 0x2C, 'data': bytes([0])},
#{'cmd': 0xB7, 'data': bytes([0x07])}, # Entry Mode Set
super().__init__(miso, mosi, clk, cs, dc, rst, power, backlight, backlight_on, power_on,
spihost, mhz, factor, hybrid, width, height, colormode, rot, invert, double_buffer, half_duplex,
asynchronous=asynchronous, initialize=initialize)
I think this should be either a problem of the flush function, or something in how lvgl handles SPI, but it is an uneducated guess.
Have you tried connecting either the back light or power pin to the lcd power input and tried toggling it over lvgl.
I did after you recommended it, the display has no backlight control, it is always on when powered, so I tried to connect a pin from the ESP32 to both 5V pins and turning it on with:
import lvgl as lv
from ili9XXX import ili9486
#lv.init gets called inside ili9XXX class
#Same mhz used in TFT_eSPI, and factor = 8 needed or else I get DMAerror
disp=ili9486(power=33, power_on=0, mhz=20, factor=8) # Also tried power_on=1
the display didn’t turn on. Then I tried connecting pin 33 to both 3.3V pins of the display and had the same results. Then I tried with backlight=33 instead of power, same results.
I’ll get an ili9341 for convenience, but I’ll keep an eye on this and update if I come up with something.
