Hi ,
I moved my code from esp-idf v4 to v5.4.1 and migrate lvgl v8 to v9.
My display is based on st7789.
My previous configuration worked perfectly, but i had to upgrade to esp-idf sdk v5 for bluetooth reason. After impossibility to have a working solution with lvgl v8, I decided to shift to v9. Almost all is fine now exept screen orientation.
ESP32S3 Custom board, gcc integrated in esp-idf install.
V9.2.2
Turn to 270degres the screen to have landscape display format.
I have used lv_display_set_rotation(display, LV_DISPLAY_ROTATION_270); in the init step of the code, resulting in wrong screen.
I also played all the possibility with esp_lcd_panel_swap_xy(panel_handle, false) and esp_lcd_panel_mirror(panel_handle, false, false) without finding the good combinaison.
I also consult the documentation before to post. But I wonder if I need to overload the flush_cb with computation and memory usage just for this.
In lvgl v8, it was only a setting in the driver init. I have the feeling that the esp_lcd layer bring more complexity than advantage for the moment. I hope i’m just missing something.
( Picture below)
With lvgl v8 and the use of
// disp_drv.sw_rotate = 1;
// disp_drv.rotated = 1;
It worked fine.
Here is the initialization procedure of the new code
ESP_LOGI(TAG_GUI, "Install panel IO");
esp_lcd_panel_io_handle_t io_handle = NULL;
esp_lcd_panel_io_spi_config_t io_config = {
.dc_gpio_num = EXAMPLE_PIN_NUM_LCD_DC,
.cs_gpio_num = EXAMPLE_PIN_NUM_CS,
.pclk_hz = EXAMPLE_LCD_PIXEL_CLOCK_HZ,
.lcd_cmd_bits = EXAMPLE_LCD_CMD_BITS,
.lcd_param_bits = EXAMPLE_LCD_PARAM_BITS,
.spi_mode = 0,
.trans_queue_depth = 10,
// Attach the LCD to the SPI bus
ESP_ERROR_CHECK(esp_lcd_new_panel_io_spi((esp_lcd_spi_bus_handle_t)LCD_HOST, &io_config, &io_handle));
esp_lcd_panel_handle_t panel_handle = NULL;
esp_lcd_panel_dev_config_t panel_config = {
.reset_gpio_num = EXAMPLE_PIN_NUM_RST,
.rgb_ele_order = LCD_RGB_ELEMENT_ORDER_RGB,
.bits_per_pixel = 16,
ESP_LOGI(TAG_GUI, "Install st7789 panel driver");
ESP_ERROR_CHECK(esp_lcd_new_panel_st7789(io_handle, &panel_config, &panel_handle));
ESP_ERROR_CHECK(esp_lcd_panel_reset(panel_handle));
ESP_ERROR_CHECK(esp_lcd_panel_init(panel_handle));
ESP_ERROR_CHECK(esp_lcd_panel_invert_color(panel_handle, true));
// // the gap is LCD panel specific, even panels with the same driver IC, can have different gap value
ESP_ERROR_CHECK(esp_lcd_panel_set_gap(panel_handle,0, 0));
// user can flush pre-defined pattern to the screen before we turn on the screen or backlight
ESP_ERROR_CHECK(esp_lcd_panel_disp_on_off(panel_handle, true));
ESP_LOGI(TAG_GUI, "Turn on LCD backlight");
gpio_set_level(EXAMPLE_PIN_NUM_BK_LIGHT, EXAMPLE_LCD_BK_LIGHT_ON_LEVEL);
ESP_LOGI(TAG_GUI, "Initialize LVGL library");
ESP_LOGI(TAG_GUI, "Initialize LVGL library done");
// create a lvgl display
lv_display_t *display = lv_display_create(EXAMPLE_LCD_H_RES, EXAMPLE_LCD_V_RES);
// alloc draw buffers used by LVGL
// it's recommended to choose the size of the draw buffer(s) to be at least 1/10 screen sized
size_t draw_buffer_sz = EXAMPLE_LCD_H_RES * EXAMPLE_LVGL_DRAW_BUF_LINES * sizeof(lv_color16_t);
void *buf1 = spi_bus_dma_memory_alloc(LCD_HOST, draw_buffer_sz, 0);
assert(buf1);
void *buf2 = spi_bus_dma_memory_alloc(LCD_HOST, draw_buffer_sz, 0);
assert(buf2);
// initialize LVGL draw buffers
lv_display_set_buffers(display, buf1, buf2, draw_buffer_sz, LV_DISPLAY_RENDER_MODE_PARTIAL);
// associate the mipi panel handle to the display
lv_display_set_user_data(display, panel_handle);
// set color depth
lv_display_set_color_format(display, LV_COLOR_FORMAT_RGB565);
lv_display_set_rotation(display, LV_DISPLAY_ROTATION_270); //ORIENTATION HERE
// set the callback which can copy the rendered image to an area of the display
lv_display_set_flush_cb(display, example_lvgl_flush_cb);
With orientation function, I have an abnormal behavior:
Without orientation function, screen looks normal :
Square Line Studio 1.5.1 design:
Thanls a lot for your help, migration was a huge works, but i’m almost at the end.
I hope an easy solution can be found ( like it was with lvgl v8).
