Describe the bug
Hi i creating a simple ESP32 app. I building this app in lvgl on esp32. I creating in arduino IDE with lvgl libraries. My problem is bad showing graphics on TFT display. I trying make app with old library lv_arduino and in this library it is all perfect. Display is nice showing my graphics. But now i try use actually library from lvgl 8.3.3 and i have this problem. Where should I look for the bug? I have a MHS 3.5" display and ESP32 dev module. I create a UI in SquareLine and import in arduino. It works perfect but the graphics are like that, see the picture.
Thank you for any advice.
To Reproduce
Hardware: ESP32 DevKit + MHS 3.5" TFT
LVGL: 8.3.3
This is my code
#include <lvgl.h>
#include <TFT_eSPI.h>
#include "ui.h"
/*Change to your screen resolution*/
static const uint16_t screenWidth = 480;
static const uint16_t screenHeight = 320;
static lv_color_t buf[ screenWidth * 10 ];
static lv_obj_t *label;
TFT_eSPI tft = TFT_eSPI(screenWidth, screenHeight); /* TFT instance */
#if LV_USE_LOG != 0
/* Serial debugging */
void my_print(const char * buf)
Serial.printf(buf);
Serial.flush();
/* Display flushing */
void my_disp_flush( lv_disp_drv_t *disp, const lv_area_t *area, lv_color_t *color_p )
uint32_t w = ( area->x2 - area->x1 + 1 );
uint32_t h = ( area->y2 - area->y1 + 1 );
tft.startWrite();
tft.setAddrWindow( area->x1, area->y1, w, h );
tft.pushColors( ( uint16_t * )&color_p->full, w * h, true );
tft.endWrite();
lv_disp_flush_ready( disp );
/*Read the touchpad*/
void my_touchpad_read( lv_indev_drv_t * indev_driver, lv_indev_data_t * data )
uint16_t touchX, touchY;
bool touched = tft.getTouch( &touchX, &touchY, 600 );
if( !touched )
/*Set the coordinates*/
data->point.x = touchX;
data->point.y = touchY;
Serial.print( "Data x " );
Serial.println( touchX );
Serial.print( "Data y " );
Serial.println( touchY );
void setup()
Serial.begin( 115200 );
#if LV_USE_LOG != 0
lv_log_register_print_cb( my_print ); /* register print function for debugging */
tft.begin(); /* TFT init */
tft.setRotation(1); /* Landscape orientation, flipped */
uint16_t calData[5] = {299, 3588, 348, 3474, 1};
tft.setTouch(calData);
lv_disp_draw_buf_init( &draw_buf, buf, NULL, screenWidth * 10 );
/*Initialize the display*/
/*Change the following line to your display resolution*/
lv_disp_drv_register( &disp_drv );
lv_indev_drv_init( &indev_drv );
lv_indev_drv_register( &indev_drv );
ui_init();
Serial.println( "Starting" );
void loop()
delay(5);
