Apologies if my question really makes clear that I have insufficient understanding about LVGL. Despite this, I do hope someone is willing to Gove me some help beyond “read the documentation”.
I use the Arduino IDE and try to display a JPG on the Arduino Giga Display using the Arduino R1.
I also browsed the Arduino forum and asked some questions, but apparently it appears to be complex.
I have an array which contains JPG data const uint8_t panda[]. You can find this panda as part of the TJpg_Decoder : GitHub - Bodmer/TJpg_Decoder: Jpeg decoder library based on Tiny JPEG Decompressor
The link to the panda array can be found here : https://github.com/Bodmer/TJpg_Decoder/tree/master/examples/SD%20Card/SD_Jpg/data
In this link Tiny JPEG Decompressor (TJpgDec) — LVGL documentation
I found that If enabled in lv_conf.h by LV_USE_TJPGD LVGL will register a new image decoder automatically so JPEG files can be used directly as image sources.
So in my lv_conf.h file which resides within the lvgl folder I have the following statement
/* JPG + split JPG decoder library.
- Split JPG is a custom format optimized for embedded systems. */
#define LV_USE_TJPGD 1
In this link : Images — LVGL documentation
It says :
You can store images in a Raw format to indicate that it’s not encoded with one of the built-in color formats and an external Image decoder needs to be used to decode the image.
- LV_COLOR_FORMAT_RAW: Indicates a basic raw image (e.g. a PNG or JPG image).
- LV_COLOR_FORMAT_RAW_ALPHA: Indicates that an image has alpha and an alpha byte is added for every pixel.
So I created a struct :
lv_img_dsc_t Panda_dsc_struct;
And filled it as follows :
Panda_dsc_struct.header.cf = LV_IMG_CF_RAW; //LV_IMG_CF_TRUE_COLOR;
Panda_dsc_struct.header.always_zero = 0;
Panda_dsc_struct.header.reserved = 0;
Panda_dsc_struct.header.w = 480; //200;
Panda_dsc_struct.header.h = 320; //150;
Panda_dsc_struct.data_size = 15000; //30000 * LV_COLOR_SIZE / 8;
Panda_dsc_struct.data = panda; //file_buffer;
Where panda is the data array containing the JPG data.
Then I use Arduino code to try to displat this panda jpg. This code has been tested with another c-array containing an Arduino logo and it works.
Please find include the Arduino code i am using. I left out the panda array because that one is very large.
And again, maybe I have no idea what I am doing, but nothing is being displayed.
Could someone help out how to display a JPG data array?
Many thanks,
My Code :
// according to this link Tiny JPEG Decompressor (TJpgDec) — LVGL documentation
// If enabled in lv_conf.h by LV_USE_TJPGD LVGL will register a new image decoder automatically so JPEG files can be used directly as image sources.
// according to this link : Images — LVGL documentation
// LV_COLOR_FORMAT_RAW: Indicates a basic raw image (e.g. a PNG or JPG image).
#include “Arduino.h”
#include “Arduino_H7_Video.h”
#include “lvgl.h”
#include <TJpg_Decoder.h> // I am not sure why to include this one
Arduino_H7_Video Display(800, 480, GigaDisplayShield);
const unsigned int max_File_size=62000;
uint8_t file_buffer[max_File_size];
const uint8_t panda[] // i have omitted the data here
void setup() {
Serial.begin( 115200 );
while (!Serial && millis() < 5000);
delay(500);
Serial.print("LV_COLOR_DEPTH : ");
Serial.println(LV_COLOR_DEPTH);
Display.begin();
lv_obj_t * screen = lv_obj_create(lv_scr_act());
lv_obj_set_size(screen, Display.width(), Display.height());
static lv_coord_t col_dsc[] = { 500, LV_GRID_TEMPLATE_LAST};
static lv_coord_t row_dsc[] = { 400, LV_GRID_TEMPLATE_LAST};
lv_obj_t * grid = lv_obj_create(lv_scr_act());
lv_obj_set_grid_dsc_array(grid, col_dsc, row_dsc);
lv_obj_set_size(grid, Display.width(), Display.height());
lv_obj_center(grid);
lv_obj_t * obj;
lv_obj_t * img2;
img2 = lv_img_create(obj);
lv_img_set_src(img2, &Panda_dsc_struct);
lv_obj_align(img2, LV_ALIGN_CENTER, 100, 100);
lv_obj_set_size(img2, 400, 300);
lv_refr_now(lv_disp_get_default());
Serial.println(“Image ready”);
void loop() {
// put your main code here, to run repeatedly:
