I have a 320x170 (ST7789V2) LCD screen , I want to use it to display a GUI, and used the LVGL 8.3.5 graphics library to implement it. I wrote a demo scene by using GUI Guider 1.5.1, but the actual displayed on the lcd is a bit different from what I expected. The text and the picture appear blurry.
expect
but
Has anyone encountered such a phenomenon?
NXP I.MXRT1051, IAR ARM 9.40.1, LCD 320x170 with ST7789
Porting LVGL to the project for the GUI
Implemented a driver for the ST7789V2 by using SPI DMA, and imported the LVGL library into the project, wrote a simple demo scene for testing, worked but the screen seems strange.
ST7789 Initialize
//************* Start Initial Sequence **********//
///< Software Reset
writeCommond(ST7789_SWRESET);
wait_ms(200);
///< Disable sleep
writeCommond(ST7789_SLPOUT);
wait_ms(200);
///< Vertical Scrolling Definition
writeCommond(ST7789_VSCRDEF);
writeData(0x00);
writeData(0x00);
writeData(0x14);
writeData(0x00);
writeData(0x00);
writeData(0x00);
///< Normal Display Mode On
writeCommond(ST7789_NORON);
wait_ms(10);
// Display Inversion: Invert the display colours (light becomes dark and vice versa) (ST7789 Datasheet Pages 188, 190)
if (INVERTED) {
writeCommond(ST7789_INVON);
} else {
writeCommond(ST7789_INVOFF);
// Set the read / write scan direction of the frame memory
writeCommond(ST7789_MADCTL); // MX, MY, RGB mode
writeData(0x70); // 0x08 set RGB
/* RGB 5-6-5-bit */
writeCommond(ST7789_COLMOD);
writeData(0x55);///< 65K, 16bit pixel
/** Display On */
writeCommond(ST7789_DISPON);
wait_ms(200);
/* Porch Setting */
writeCommond(ST7789_PORCTRL);
writeData(0x0C);
writeData(0x0C);
writeData(0x00);
writeData(0x33);
writeData(0x33);
/* Gate Control */
writeCommond(ST7789_GCTRL);
writeData(0x35);
/* VCOM Setting */
writeCommond(ST7789_VCOMS);
writeData(0x1A);
/* LCM Control */
writeCommond(ST7789_LCMCTRL);
writeData(0x2C);
/* VDV and VRH Command Enable */
writeCommond(ST7789_VDVVRHEN);
writeData(0x01);
/* VRH Set */
writeCommond(ST7789_VRHS);
writeData(0x0B);
/* VDV Set */
writeCommond(ST7789_VDVSET);
writeData(0x20);
/* Frame Rate Control in Normal Mode */
writeCommond(ST7789_FRCTR2);
writeData(0x0F);//60MHZ
/* Power Control 1 */
writeCommond(ST7789_PWCTRL1);
writeData(0xA4);
writeData(0xA1);
/* Positive Voltage Gamma Control */
writeCommond(ST7789_PVGAMCTRL);
writeData(0xF0);
writeData(0x00);
writeData(0x04);
writeData(0x04);
writeData(0x04);
writeData(0x05);
writeData(0x29);
writeData(0x33);
writeData(0x3E);
writeData(0x38);
writeData(0x12);
writeData(0x12);
writeData(0x28);
writeData(0x30);
/* Negative Voltage Gamma Control */
writeCommond(ST7789_NVGAMCTRL);
writeData(0xF0);
writeData(0x07);
writeData(0x0A);
writeData(0x0D);
writeData(0x0B);
writeData(0x07);
writeData(0x28);
writeData(0x33);
writeData(0x3E);
writeData(0x36);
writeData(0x14);
writeData(0x14);
writeData(0x29);
writeData(0x32);
/** Sleep Out */
wait_ms(120);
/** Display On */
#define LCD_WIDTH 320
#define LCD_HEIGHT 170
#define LCD_FB_BYTE_PER_PIXEL 2
#define LCD_VIRTUAL_BUF_SIZE (LCD_WIDTH * LCD_HEIGHT)
///< LVGL porting func
AT_NONCACHEABLE_SECTION_ALIGN(static uint8_t s_frameBuffer[2][LCD_VIRTUAL_BUF_SIZE * LCD_FB_BYTE_PER_PIXEL], 32);
void lv_port_disp_init(void)
lv_disp_draw_buf_init(&disp_buf, s_frameBuffer[0], s_frameBuffer[1], LCD_VIRTUAL_BUF_SIZE);
* Initialize your display
InitializeLCD();
static lv_disp_drv_t disp_drv; /*Descriptor of a display driver*/
disp_drv.hor_res = LCD_WIDTH;
disp_drv.ver_res = LCD_HEIGHT;
/*Set a display buffer*/
static void my_disp_flush(lv_disp_drv_t *disp_drv, const lv_area_t *area, lv_color_t *color_p)
int16_t w = (area->x2 - area->x1 + 1);
int16_t h = (area->y2 - area->y1 + 1);
uint32_t size = w * h * sizeof(lv_color_t);
// g_lcd_screen.ResetAddrWindow();
g_lcd_screen.setAddrWindow(area->x1, area->y1, area->x2, area->y2);
g_lcd_screen.writeData16Dma((uint8_t*)color_p, size);
void setup_scr_startup(lv_ui *ui){
//Write codes startup
ui->startup = lv_obj_create(NULL);
lv_obj_set_scrollbar_mode(ui->startup, LV_SCROLLBAR_MODE_OFF);
//Set style for startup. Part: LV_PART_MAIN, State: LV_STATE_DEFAULT
lv_obj_set_style_bg_color(ui->startup, lv_color_make(0x26, 0xB0, 0x8C), LV_PART_MAIN|LV_STATE_DEFAULT);
lv_obj_set_style_bg_grad_color(ui->startup, lv_color_make(0x21, 0x95, 0xf6), LV_PART_MAIN|LV_STATE_DEFAULT);
lv_obj_set_style_bg_grad_dir(ui->startup, LV_GRAD_DIR_NONE, LV_PART_MAIN|LV_STATE_DEFAULT);
lv_obj_set_style_bg_opa(ui->startup, 255, LV_PART_MAIN|LV_STATE_DEFAULT);
//Write codes startup_startup_ip
ui->startup_startup_ip = lv_label_create(ui->startup);
lv_obj_set_pos(ui->startup_startup_ip, 23, 19);
lv_obj_set_size(ui->startup_startup_ip, 278, 32);
lv_obj_set_scrollbar_mode(ui->startup_startup_ip, LV_SCROLLBAR_MODE_OFF);
lv_label_set_text(ui->startup_startup_ip, "IP:\n");
lv_label_set_long_mode(ui->startup_startup_ip, LV_LABEL_LONG_WRAP);
//Set style for startup_startup_ip. Part: LV_PART_MAIN, State: LV_STATE_DEFAULT
lv_obj_set_style_radius(ui->startup_startup_ip, 0, LV_PART_MAIN|LV_STATE_DEFAULT);
lv_obj_set_style_bg_color(ui->startup_startup_ip, lv_color_make(0x26, 0xB0, 0x8C), LV_PART_MAIN|LV_STATE_DEFAULT);
lv_obj_set_style_bg_grad_color(ui->startup_startup_ip, lv_color_make(0x21, 0x95, 0xf6), LV_PART_MAIN|LV_STATE_DEFAULT);
lv_obj_set_style_bg_grad_dir(ui->startup_startup_ip, LV_GRAD_DIR_NONE, LV_PART_MAIN|LV_STATE_DEFAULT);
lv_obj_set_style_bg_opa(ui->startup_startup_ip, 255, LV_PART_MAIN|LV_STATE_DEFAULT);
lv_obj_set_style_shadow_width(ui->startup_startup_ip, 0, LV_PART_MAIN|LV_STATE_DEFAULT);
lv_obj_set_style_shadow_color(ui->startup_startup_ip, lv_color_make(0x21, 0x95, 0xf6), LV_PART_MAIN|LV_STATE_DEFAULT);
lv_obj_set_style_shadow_opa(ui->startup_startup_ip, 255, LV_PART_MAIN|LV_STATE_DEFAULT);
lv_obj_set_style_shadow_spread(ui->startup_startup_ip, 0, LV_PART_MAIN|LV_STATE_DEFAULT);
lv_obj_set_style_shadow_ofs_x(ui->startup_startup_ip, 0, LV_PART_MAIN|LV_STATE_DEFAULT);
lv_obj_set_style_shadow_ofs_y(ui->startup_startup_ip, 0, LV_PART_MAIN|LV_STATE_DEFAULT);
lv_obj_set_style_text_color(ui->startup_startup_ip, lv_color_make(0xff, 0xff, 0xff), LV_PART_MAIN|LV_STATE_DEFAULT);
lv_obj_set_style_text_font(ui->startup_startup_ip, &lv_font_montserratMedium_16, LV_PART_MAIN|LV_STATE_DEFAULT);
lv_obj_set_style_text_letter_space(ui->startup_startup_ip, 2, LV_PART_MAIN|LV_STATE_DEFAULT);
lv_obj_set_style_text_line_space(ui->startup_startup_ip, 0, LV_PART_MAIN|LV_STATE_DEFAULT);
lv_obj_set_style_text_align(ui->startup_startup_ip, LV_TEXT_ALIGN_LEFT, LV_PART_MAIN|LV_STATE_DEFAULT);
lv_obj_set_style_pad_left(ui->startup_startup_ip, 8, LV_PART_MAIN|LV_STATE_DEFAULT);
lv_obj_set_style_pad_right(ui->startup_startup_ip, 0, LV_PART_MAIN|LV_STATE_DEFAULT);
lv_obj_set_style_pad_top(ui->startup_startup_ip, 8, LV_PART_MAIN|LV_STATE_DEFAULT);
lv_obj_set_style_pad_bottom(ui->startup_startup_ip, 0, LV_PART_MAIN|LV_STATE_DEFAULT);
//Write codes startup_startup_name
ui->startup_startup_name = lv_label_create(ui->startup);
lv_obj_set_pos(ui->startup_startup_name, 23, 60);
lv_obj_set_size(ui->startup_startup_name, 172, 32);
lv_obj_set_scrollbar_mode(ui->startup_startup_name, LV_SCROLLBAR_MODE_OFF);
lv_label_set_text(ui->startup_startup_name, "Name:");
lv_label_set_long_mode(ui->startup_startup_name, LV_LABEL_LONG_WRAP);
//Set style for startup_startup_name. Part: LV_PART_MAIN, State: LV_STATE_DEFAULT
lv_obj_set_style_radius(ui->startup_startup_name, 0, LV_PART_MAIN|LV_STATE_DEFAULT);
lv_obj_set_style_bg_color(ui->startup_startup_name, lv_color_make(0x26, 0xB0, 0x8C), LV_PART_MAIN|LV_STATE_DEFAULT);
lv_obj_set_style_bg_grad_color(ui->startup_startup_name, lv_color_make(0x21, 0x95, 0xf6), LV_PART_MAIN|LV_STATE_DEFAULT);
lv_obj_set_style_bg_grad_dir(ui->startup_startup_name, LV_GRAD_DIR_NONE, LV_PART_MAIN|LV_STATE_DEFAULT);
lv_obj_set_style_bg_opa(ui->startup_startup_name, 255, LV_PART_MAIN|LV_STATE_DEFAULT);
lv_obj_set_style_shadow_width(ui->startup_startup_name, 0, LV_PART_MAIN|LV_STATE_DEFAULT);
lv_obj_set_style_shadow_color(ui->startup_startup_name, lv_color_make(0x21, 0x95, 0xf6), LV_PART_MAIN|LV_STATE_DEFAULT);
lv_obj_set_style_shadow_opa(ui->startup_startup_name, 0, LV_PART_MAIN|LV_STATE_DEFAULT);
lv_obj_set_style_shadow_spread(ui->startup_startup_name, 0, LV_PART_MAIN|LV_STATE_DEFAULT);
lv_obj_set_style_shadow_ofs_x(ui->startup_startup_name, 0, LV_PART_MAIN|LV_STATE_DEFAULT);
lv_obj_set_style_shadow_ofs_y(ui->startup_startup_name, 0, LV_PART_MAIN|LV_STATE_DEFAULT);
lv_obj_set_style_text_color(ui->startup_startup_name, lv_color_make(0xff, 0xff, 0xff), LV_PART_MAIN|LV_STATE_DEFAULT);
lv_obj_set_style_text_font(ui->startup_startup_name, &lv_font_montserratMedium_16, LV_PART_MAIN|LV_STATE_DEFAULT);
lv_obj_set_style_text_letter_space(ui->startup_startup_name, 2, LV_PART_MAIN|LV_STATE_DEFAULT);
lv_obj_set_style_text_line_space(ui->startup_startup_name, 0, LV_PART_MAIN|LV_STATE_DEFAULT);
lv_obj_set_style_text_align(ui->startup_startup_name, LV_TEXT_ALIGN_LEFT, LV_PART_MAIN|LV_STATE_DEFAULT);
lv_obj_set_style_pad_left(ui->startup_startup_name, 8, LV_PART_MAIN|LV_STATE_DEFAULT);
lv_obj_set_style_pad_right(ui->startup_startup_name, 0, LV_PART_MAIN|LV_STATE_DEFAULT);
lv_obj_set_style_pad_top(ui->startup_startup_name, 8, LV_PART_MAIN|LV_STATE_DEFAULT);
lv_obj_set_style_pad_bottom(ui->startup_startup_name, 0, LV_PART_MAIN|LV_STATE_DEFAULT);
//Write codes startup_startup_version
ui->startup_startup_version = lv_label_create(ui->startup);
lv_obj_set_pos(ui->startup_startup_version, 23, 102);
lv_obj_set_size(ui->startup_startup_version, 100, 32);
lv_obj_set_scrollbar_mode(ui->startup_startup_version, LV_SCROLLBAR_MODE_OFF);
lv_label_set_text(ui->startup_startup_version, "Version:\n");
lv_label_set_long_mode(ui->startup_startup_version, LV_LABEL_LONG_WRAP);
//Set style for startup_startup_version. Part: LV_PART_MAIN, State: LV_STATE_DEFAULT
lv_obj_set_style_radius(ui->startup_startup_version, 0, LV_PART_MAIN|LV_STATE_DEFAULT);
lv_obj_set_style_bg_color(ui->startup_startup_version, lv_color_make(0x26, 0xB0, 0x8C), LV_PART_MAIN|LV_STATE_DEFAULT);
lv_obj_set_style_bg_grad_color(ui->startup_startup_version, lv_color_make(0x21, 0x95, 0xf6), LV_PART_MAIN|LV_STATE_DEFAULT);
lv_obj_set_style_bg_grad_dir(ui->startup_startup_version, LV_GRAD_DIR_NONE, LV_PART_MAIN|LV_STATE_DEFAULT);
lv_obj_set_style_bg_opa(ui->startup_startup_version, 255, LV_PART_MAIN|LV_STATE_DEFAULT);
lv_obj_set_style_shadow_width(ui->startup_startup_version, 0, LV_PART_MAIN|LV_STATE_DEFAULT);
lv_obj_set_style_shadow_color(ui->startup_startup_version, lv_color_make(0x21, 0x95, 0xf6), LV_PART_MAIN|LV_STATE_DEFAULT);
lv_obj_set_style_shadow_opa(ui->startup_startup_version, 255, LV_PART_MAIN|LV_STATE_DEFAULT);
lv_obj_set_style_shadow_spread(ui->startup_startup_version, 0, LV_PART_MAIN|LV_STATE_DEFAULT);
lv_obj_set_style_shadow_ofs_x(ui->startup_startup_version, 0, LV_PART_MAIN|LV_STATE_DEFAULT);
lv_obj_set_style_shadow_ofs_y(ui->startup_startup_version, 0, LV_PART_MAIN|LV_STATE_DEFAULT);
lv_obj_set_style_text_color(ui->startup_startup_version, lv_color_make(0xff, 0xff, 0xff), LV_PART_MAIN|LV_STATE_DEFAULT);
lv_obj_set_style_text_font(ui->startup_startup_version, &lv_font_montserratMedium_16, LV_PART_MAIN|LV_STATE_DEFAULT);
lv_obj_set_style_text_letter_space(ui->startup_startup_version, 2, LV_PART_MAIN|LV_STATE_DEFAULT);
lv_obj_set_style_text_line_space(ui->startup_startup_version, 0, LV_PART_MAIN|LV_STATE_DEFAULT);
lv_obj_set_style_text_align(ui->startup_startup_version, LV_TEXT_ALIGN_LEFT, LV_PART_MAIN|LV_STATE_DEFAULT);
lv_obj_set_style_pad_left(ui->startup_startup_version, 8, LV_PART_MAIN|LV_STATE_DEFAULT);
lv_obj_set_style_pad_right(ui->startup_startup_version, 0, LV_PART_MAIN|LV_STATE_DEFAULT);
lv_obj_set_style_pad_top(ui->startup_startup_version, 8, LV_PART_MAIN|LV_STATE_DEFAULT);
lv_obj_set_style_pad_bottom(ui->startup_startup_version, 0, LV_PART_MAIN|LV_STATE_DEFAULT);
//Write codes startup_img_1
ui->startup_img_1 = lv_img_create(ui->startup);
lv_obj_set_pos(ui->startup_img_1, 281, 8);
lv_obj_set_size(ui->startup_img_1, 32, 33);
lv_obj_set_scrollbar_mode(ui->startup_img_1, LV_SCROLLBAR_MODE_OFF);
//Set style for startup_img_1. Part: LV_PART_MAIN, State: LV_STATE_DEFAULT
lv_obj_set_style_img_recolor(ui->startup_img_1, lv_color_make(0xff, 0xff, 0xff), LV_PART_MAIN|LV_STATE_DEFAULT);
lv_obj_set_style_img_recolor_opa(ui->startup_img_1, 0, LV_PART_MAIN|LV_STATE_DEFAULT);
lv_obj_set_style_img_opa(ui->startup_img_1, 255, LV_PART_MAIN|LV_STATE_DEFAULT);
lv_obj_add_flag(ui->startup_img_1, LV_OBJ_FLAG_CLICKABLE);
lv_img_set_src(ui->startup_img_1,&_heart_alpha_32x33);
lv_img_set_pivot(ui->startup_img_1, 50,50);
lv_img_set_angle(ui->startup_img_1, 0);
//Init events for screen
events_init_startup(ui);
Color setting in lv_conf.h
COLOR SETTINGS
/*Maximal horizontal resolution*/
#define LV_HOR_RES_MAX (320)
#define LV_VER_RES_MAX (170)
#define LV_COLOR_DEPTH 16
#define LV_COLOR_16_SWAP 1
#define LV_COLOR_SCREEN_TRANSP 1
#define LV_COLOR_MIX_ROUND_OFS 64
#define LV_DPI_DEF 100
#define LV_COLOR_CHROMA_KEY lv_color_hex(0x00ff00)
#define LV_DRAW_COMPLEX 1
#define LV_SHADOW_CACHE_SIZE 0
#define LV_CIRCLE_CACHE_SIZE 4
#define LV_BIG_ENDIAN_SYSTEM 0
#define LV_ATTRIBUTE_TICK_INC
#define LV_ATTRIBUTE_TIMER_HANDLER
#define LV_ATTRIBUTE_MEM_ALIGN_SIZE 64
#define LV_FONT_MONTSERRAT_12 1
#define LV_FONT_MONTSERRAT_14 1
