Display glitching while connecting to WiFi: ESP32S3+8048S043
Hi guys,
I’m using this really nice IPS display (Makerfabs clone 800x480 ESP32-8048S043) Arduino IDE and SquareLine to generate gui (apart from this example, which is stripped back and all included in the ino file).
Everything works including touch.
But when I try to connect to a WiFi network, the display glitches a couple of times like in this video:
glitchoutput
No glitching when scanning for networks.
I’ve tried putting the lvgl loop in a separate thread, i’ve tried the WiFi connect routine in a separate thread with different priorities, no change: without fail it will glitch the screen every time I try to connect to a network.
I’ve reduced the BL intensity in case it’s a power issue: I don’t believe it is.
This is mentioned on this blog, which may point to the problem:
Since the RGB Display method uses the ESP32’s PSRAM for his buffer,
slowdowns and flickering may occur.
I’m not experienced enough in the inner workings of frame buffers to figure out how to fix this, do you kind folks have any ideas?
I don’t mind pausing the screen buffering and resuming it while connecting if it means I can hide the glitching. But I’d like to get to the real solution if possible.
Here’s the .ino code, and I’m using a touch.h header file next to the main ino for touch.
#include "WiFi.h"
#include <lvgl.h>
#include <vector>
#define TFT_BL 2
#define GFX_BL DF_GFX_BL // default backlight pin, you may replace DF_GFX_BL to actual backlight pin
/* More data bus class: https://github.com/moononournation/Arduino_GFX/wiki/Data-Bus-Class */
//Arduino_DataBus *bus = create_default_Arduino_DataBus();
/* More display class: https://github.com/moononournation/Arduino_GFX/wiki/Display-Class */
//Arduino_GFX *gfx = new Arduino_ILI9341(bus, DF_GFX_RST, 0 /* rotation */, false /* IPS */);
Arduino_ESP32RGBPanel *bus = new Arduino_ESP32RGBPanel(
    GFX_NOT_DEFINED /* CS */, GFX_NOT_DEFINED /* SCK */, GFX_NOT_DEFINED /* SDA */,
    40 /* DE */, 41 /* VSYNC */, 39 /* HSYNC */, 42 /* PCLK */,
    45 /* R0 */, 48 /* R1 */, 47 /* R2 */, 21 /* R3 */, 14 /* R4 */,
    5 /* G0 */, 6 /* G1 */, 7 /* G2 */, 15 /* G3 */, 16 /* G4 */, 4 /* G5 */,
    8 /* B0 */, 3 /* B1 */, 46 /* B2 */, 9 /* B3 */, 1 /* B4 */
// ST7262 IPS LCD 800x480
 Arduino_RPi_DPI_RGBPanel *gfx = new Arduino_RPi_DPI_RGBPanel(
   bus,
   800 /* width */, 0 /* hsync_polarity */, 8 /* hsync_front_porch */, 4 /* hsync_pulse_width */, 8 /* hsync_back_porch */,
   480 /* height */, 0 /* vsync_polarity */, 8 /* vsync_front_porch */, 4 /* vsync_pulse_width */, 8 /* vsync_back_porch */,
   1 /* pclk_active_neg */, 12000000 /* prefer_speed */, true /* auto_flush */);
#include "time.h"
const char *ntpServer = "pool.ntp.org";
const long gmtOffset_sec = -8 * 60 * 60;  // Set your timezone here
const int daylightOffset_sec = 0;
#include "touch.h"
//#include <FT6236.h>
//#define SDA_FT6236 21
//#define SCL_FT6236 22
//FT6236 ts = FT6236();
typedef enum {
  NONE,
  NETWORK_SEARCHING,
  NETWORK_CONNECTED_POPUP,
  NETWORK_CONNECTED,
  NETWORK_CONNECT_FAILED
} Network_Status_t;
Network_Status_t networkStatus = NONE;
/*Change to your screen resolution*/
static uint32_t screenWidth;
static uint32_t screenHeight;
static lv_color_t buf[800 * 10];
static lv_style_t label_style;
static lv_obj_t *headerLabel;
#if (LV_COLOR_16_SWAP != 0)
  gfx->draw16bitBeRGBBitmap(area->x1, area->y1, (uint16_t *)&color_p->full, w, h);
#else
  gfx->draw16bitRGBBitmap(area->x1, area->y1, (uint16_t *)&color_p->full, w, h);
  lv_disp_flush_ready(disp);
void my_touchpad_read(lv_indev_drv_t *indev_driver, lv_indev_data_t *data)
  if (touch_has_signal())
    if (touch_touched())
      /*Set the coordinates*/
      data->point.x = touch_last_x;
      data->point.y = touch_last_y;
    else if (touch_released())
static lv_style_t border_style;
static lv_style_t popupBox_style;
static lv_obj_t *timeLabel;
static lv_obj_t *settings;
static lv_obj_t *settingBtn;
static lv_obj_t *settingCloseBtn;
static lv_obj_t *settingWiFiSwitch;
static lv_obj_t *wfList;
static lv_obj_t *settinglabel;
static lv_obj_t *mboxConnect;
static lv_obj_t *mboxTitle;
static lv_obj_t *mboxPassword;
static lv_obj_t *mboxConnectBtn;
static lv_obj_t *mboxCloseBtn;
static lv_obj_t *keyboard;
static lv_obj_t *popupBox;
static lv_obj_t *popupBoxCloseBtn;
static lv_timer_t *timer;
static int foundNetworks = 0;
unsigned long networkTimeout = 10 * 1000;
String ssidName, ssidPW;
// TaskHandle_t ntScanTaskHandler, ntConnectTaskHandler;
TaskHandle_t ntScanTaskHandler;
std::vector<String> foundWifiList;
void setup() {
  Serial.begin(115200);
  gfx->begin();
  pinMode(TFT_BL, OUTPUT);
  analogWrite(TFT_BL, 100);
  delay(10);
  touch_init();
  screenWidth = gfx->width();
  screenHeight = gfx->height();
  static lv_color_t *disp_draw_buf;
  disp_draw_buf = (lv_color_t *)heap_caps_malloc(sizeof(lv_color_t) * screenWidth * screenHeight/4 , MALLOC_CAP_8BIT|MALLOC_CAP_INTERNAL);
  lv_disp_draw_buf_init(&draw_buf, disp_draw_buf, NULL, screenWidth * screenHeight/4);
  /* Initialize the display */
  lv_disp_drv_init(&disp_drv);
  /* Change the following line to your display resolution */
  //disp_drv.rotated = LV_DISP_ROT_270;
  disp_drv.hor_res = 800;
  disp_drv.ver_res = 480;
  /* Initialize the (dummy) input device driver */
  setStyle();
  makeKeyboard();
  buildStatusBar();
  buildPWMsgBox();
  buildBody();
  buildSettings();
  tryPreviousNetwork();
void loop() {
  lv_timer_handler();
  delay(5);
void tryPreviousNetwork() {
  //loadWIFICredentialEEPROM();
static void setStyle() {
  lv_style_init(&border_style);
  lv_style_set_border_width(&border_style, 2);
  lv_style_set_border_color(&border_style, lv_color_black());
  lv_style_init(&popupBox_style);
  lv_style_set_radius(&popupBox_style, 10);
  lv_style_set_bg_opa(&popupBox_style, LV_OPA_COVER);
  lv_style_set_border_color(&popupBox_style, lv_palette_main(LV_PALETTE_BLUE));
  lv_style_set_border_width(&popupBox_style, 5);
static void buildStatusBar() {
  static lv_style_t style_btn;
  lv_style_init(&style_btn);
  lv_style_set_bg_color(&style_btn, lv_color_hex(0xC5C5C5));
  lv_style_set_bg_opa(&style_btn, LV_OPA_50);
  lv_obj_t *statusBar = lv_obj_create(lv_scr_act());
  lv_obj_set_size(statusBar, 800, 30);
  lv_obj_align(statusBar, LV_ALIGN_TOP_MID, 0, 0);
  lv_obj_remove_style(statusBar, NULL, LV_PART_SCROLLBAR | LV_STATE_ANY);
  timeLabel = lv_label_create(statusBar);
  lv_obj_set_size(timeLabel,800 - 50, 30);
  lv_label_set_text(timeLabel, "WiFi Not Connected!    " LV_SYMBOL_CLOSE);
  lv_obj_align(timeLabel, LV_ALIGN_LEFT_MID, 8, 4);
  settingBtn = lv_btn_create(statusBar);
  lv_obj_set_size(settingBtn, 30, 30);
  lv_obj_align(settingBtn, LV_ALIGN_RIGHT_MID, 0, 0);
  lv_obj_add_event_cb(settingBtn, btn_event_cb, LV_EVENT_ALL, NULL);
  lv_obj_t *label = lv_label_create(settingBtn); /*Add a label to the button*/
  lv_label_set_text(label, LV_SYMBOL_SETTINGS);  /*Set the labels text*/
  lv_obj_center(label);
static void btn_event_cb(lv_event_t *e) {
  lv_obj_t *btn = lv_event_get_target(e);
  if (code == LV_EVENT_CLICKED) {
    if (btn == settingBtn) {
      lv_obj_clear_flag(settings, LV_OBJ_FLAG_HIDDEN);
    } else if (btn == settingCloseBtn) {
      lv_obj_add_flag(settings, LV_OBJ_FLAG_HIDDEN);
    } else if (btn == mboxConnectBtn) {
      ssidPW = String(lv_textarea_get_text(mboxPassword));
      beginWIFITask();
      //networkConnector();
      lv_obj_move_background(mboxConnect);
      popupMsgBox("Connecting!", "Attempting to connect to the selected network.");
    } else if (btn == mboxCloseBtn) {
    } else if (btn == popupBoxCloseBtn) {
      lv_obj_move_background(popupBox);
  } else if (code == LV_EVENT_VALUE_CHANGED) {
    if (btn == settingWiFiSwitch) {
      if (lv_obj_has_state(btn, LV_STATE_CHECKED)) {
        if (ntScanTaskHandler == NULL) {
          networkStatus = NETWORK_SEARCHING;
          networkScanner();
          timer = lv_timer_create(timerForNetwork, 1000, wfList);
          lv_list_add_text(wfList, "WiFi: Looking for Networks...");
      } else {
        if (ntScanTaskHandler != NULL) {
          vTaskDelete(ntScanTaskHandler);
          ntScanTaskHandler = NULL;
          lv_timer_del(timer);
          lv_obj_clean(wfList);
        if (WiFi.status() == WL_CONNECTED) {
          WiFi.disconnect(true);
static void timerForNetwork(lv_timer_t *timer) {
  LV_UNUSED(timer);
  switch (networkStatus) {
    case NETWORK_SEARCHING:
      showingFoundWiFiList();
      break;
    case NETWORK_CONNECTED_POPUP:
      popupMsgBox("WiFi Connected!", "Now you'll get the current time soon.");
      networkStatus = NETWORK_CONNECTED;
      configTime(gmtOffset_sec, daylightOffset_sec, ntpServer);
      break;
    case NETWORK_CONNECTED:
      updateLocalTime();
      break;
    case NETWORK_CONNECT_FAILED:
      popupMsgBox("Oops!", "Please check your wifi password and try again.");
      break;
    default:
      break;
static void showingFoundWiFiList() {
  if (foundWifiList.size() == 0 || foundNetworks == foundWifiList.size())
    return;
  lv_list_add_text(wfList, foundWifiList.size() > 1 ? "WiFi: Found Networks" : "WiFi: Not Found!");
  for (std::vector<String>::iterator item = foundWifiList.begin(); item != foundWifiList.end(); ++item) {
    lv_obj_t *btn = lv_list_add_btn(wfList, LV_SYMBOL_WIFI, (*item).c_str());
    lv_obj_add_event_cb(btn, list_event_handler, LV_EVENT_CLICKED, NULL);
    delay(1);
  foundNetworks = foundWifiList.size();
static void buildBody() {
  lv_obj_t *bodyScreen = lv_obj_create(lv_scr_act());
  lv_obj_add_style(bodyScreen, &border_style, 0);
  lv_obj_set_size(bodyScreen, 800, 480 - 34);
  lv_obj_align(bodyScreen, LV_ALIGN_BOTTOM_MID, 0, 0);
  lv_obj_t *label = lv_label_create(bodyScreen);
  lv_label_set_text(label, "Your Contents");
static void buildSettings() {
  settings = lv_obj_create(lv_scr_act());
  lv_obj_add_style(settings, &border_style, 0);
  lv_obj_set_size(settings, 800 - 100, 480 - 40);
  lv_obj_align(settings, LV_ALIGN_TOP_RIGHT, -20, 20);
  settinglabel = lv_label_create(settings);
  lv_label_set_text(settinglabel, "Settings " LV_SYMBOL_SETTINGS);
  lv_obj_align(settinglabel, LV_ALIGN_TOP_LEFT, 0, 0);
  settingCloseBtn = lv_btn_create(settings);
  lv_obj_set_size(settingCloseBtn, 30, 30);
  lv_obj_align(settingCloseBtn, LV_ALIGN_TOP_RIGHT, 0, -10);
  lv_obj_add_event_cb(settingCloseBtn, btn_event_cb, LV_EVENT_ALL, NULL);
  lv_obj_t *btnSymbol = lv_label_create(settingCloseBtn);
  lv_label_set_text(btnSymbol, LV_SYMBOL_CLOSE);
  lv_obj_center(btnSymbol);
  settingWiFiSwitch = lv_switch_create(settings);
  lv_obj_add_event_cb(settingWiFiSwitch, btn_event_cb, LV_EVENT_ALL, NULL);
  lv_obj_align_to(settingWiFiSwitch, settinglabel, LV_ALIGN_TOP_RIGHT, 60, -10);
  wfList = lv_list_create(settings);
  lv_obj_set_size(wfList, 800 - 140, 210);
  lv_obj_align_to(wfList, settinglabel, LV_ALIGN_TOP_LEFT, 0, 30);
static void list_event_handler(lv_event_t *e) {
  lv_obj_t *obj = lv_event_get_target(e);
    String selectedItem = String(lv_list_get_btn_text(wfList, obj));
    for (int i = 0; i < selectedItem.length() - 1; i++) {
      if (selectedItem.substring(i, i + 2) == " (") {
        ssidName = selectedItem.substring(0, i);
        lv_label_set_text_fmt(mboxTitle, "Selected WiFi SSID: %s", ssidName);
        lv_obj_move_foreground(mboxConnect);
        break;
 * NETWORK TASKS
static void networkScanner() {
  xTaskCreate(scanWIFITask,
              "ScanWIFITask",
              4096,
              NULL,
              1,
              &ntScanTaskHandler);
//static void networkConnector() {
//  xTaskCreate(beginWIFITask,
//              "beginWIFITask",
//              4096,
//              NULL,
//              1,
//              &ntConnectTaskHandler);
static void scanWIFITask(void *pvParameters) {
  while (1) {
    foundWifiList.clear();
    int n = WiFi.scanNetworks();
    vTaskDelay(10);
    for (int i = 0; i < n; ++i) {
      String item = WiFi.SSID(i) + " (" + WiFi.RSSI(i) + ") " + ((WiFi.encryptionType(i) == WIFI_AUTH_OPEN) ? " " : "*");
      foundWifiList.push_back(item);
      vTaskDelay(10);
    vTaskDelay(5000);
//void beginWIFITask(void *pvParameters) {
void beginWIFITask() {
  unsigned long startingTime = millis();
  WiFi.mode(WIFI_STA);
  WiFi.disconnect();
  //vTaskDelay(100);
  WiFi.begin(ssidName.c_str(), ssidPW.c_str());
  while (WiFi.status() != WL_CONNECTED && (millis() - startingTime) < networkTimeout) {
    //vTaskDelay(250);
    networkStatus = NETWORK_CONNECTED_POPUP;
    //saveWIFICredentialEEPROM(1, ssidName + " " + ssidPW);
  } else {
    networkStatus = NETWORK_CONNECT_FAILED;
    //saveWIFICredentialEEPROM(0, "");
  //vTaskDelete(NULL);
static void buildPWMsgBox() {
  mboxConnect = lv_obj_create(lv_scr_act());
  lv_obj_add_style(mboxConnect, &border_style, 0);
  lv_obj_set_size(mboxConnect, 800 * 2 / 3, 480 / 2);
  lv_obj_center(mboxConnect);
  mboxTitle = lv_label_create(mboxConnect);
  lv_label_set_text(mboxTitle, "Selected WiFi SSID: ThatProject");
  lv_obj_align(mboxTitle, LV_ALIGN_TOP_LEFT, 0, 0);
  mboxPassword = lv_textarea_create(mboxConnect);
  lv_obj_set_size(mboxPassword, 800 / 2, 40);
  lv_obj_align_to(mboxPassword, mboxTitle, LV_ALIGN_TOP_LEFT, 0, 30);
  lv_textarea_set_placeholder_text(mboxPassword, "Password?");
  lv_obj_add_event_cb(mboxPassword, text_input_event_cb, LV_EVENT_ALL, keyboard);
  mboxConnectBtn = lv_btn_create(mboxConnect);
  lv_obj_add_event_cb(mboxConnectBtn, btn_event_cb, LV_EVENT_ALL, NULL);
  lv_obj_align(mboxConnectBtn, LV_ALIGN_BOTTOM_LEFT, 0, 0);
  lv_obj_t *btnLabel = lv_label_create(mboxConnectBtn);
  lv_label_set_text(btnLabel, "Connect");
  lv_obj_center(btnLabel);
  mboxCloseBtn = lv_btn_create(mboxConnect);
  lv_obj_add_event_cb(mboxCloseBtn, btn_event_cb, LV_EVENT_ALL, NULL);
  lv_obj_align(mboxCloseBtn, LV_ALIGN_BOTTOM_RIGHT, 0, 0);
  lv_obj_t *btnLabel2 = lv_label_create(mboxCloseBtn);
  lv_label_set_text(btnLabel2, "Cancel");
  lv_obj_center(btnLabel2);
static void text_input_event_cb(lv_event_t *e) {
  lv_obj_t *ta = lv_event_get_target(e);
  if (code == LV_EVENT_FOCUSED) {
    lv_obj_move_foreground(keyboard);
    lv_keyboard_set_textarea(keyboard, ta);
    lv_obj_clear_flag(keyboard, LV_OBJ_FLAG_HIDDEN);
  if (code == LV_EVENT_DEFOCUSED) {
    lv_keyboard_set_textarea(keyboard, NULL);
    lv_obj_add_flag(keyboard, LV_OBJ_FLAG_HIDDEN);
static void makeKeyboard() {
  keyboard = lv_keyboard_create(lv_scr_act());
static void popupMsgBox(String title, String msg) {
  if (popupBox != NULL) {
    lv_obj_del(popupBox);
  popupBox = lv_obj_create(lv_scr_act());
  lv_obj_add_style(popupBox, &popupBox_style, 0);
  lv_obj_set_size(popupBox, 800 * 2 / 3, 480 / 2);
  lv_obj_center(popupBox);
  lv_obj_t *popupTitle = lv_label_create(popupBox);
  lv_label_set_text(popupTitle, title.c_str());
  lv_obj_set_width(popupTitle, 800 * 2 / 3 - 50);
  lv_obj_align(popupTitle, LV_ALIGN_TOP_LEFT, 0, 0);
  lv_obj_t *popupMSG = lv_label_create(popupBox);
  lv_obj_set_width(popupMSG, 800 * 2 / 3 - 50);
  lv_label_set_text(popupMSG, msg.c_str());
  lv_obj_align(popupMSG, LV_ALIGN_TOP_LEFT, 0, 40);
  popupBoxCloseBtn = lv_btn_create(popupBox);
  lv_obj_add_event_cb(popupBoxCloseBtn, btn_event_cb, LV_EVENT_ALL, NULL);
  lv_obj_align(popupBoxCloseBtn, LV_ALIGN_BOTTOM_RIGHT, 0, 0);
  lv_obj_t *btnLabel = lv_label_create(popupBoxCloseBtn);
  lv_label_set_text(btnLabel, "Okay");
void updateLocalTime() {
  struct tm timeinfo;
  if (!getLocalTime(&timeinfo)) {
    return;
  char hourMin[6];
  strftime(hourMin, 6, "%H:%M", &timeinfo);
  String hourMinWithSymbol = String(hourMin);
  hourMinWithSymbol += "   ";
  hourMinWithSymbol += LV_SYMBOL_WIFI;
  lv_label_set_text(timeLabel, hourMinWithSymbol.c_str());
touch.h
 * Touch libraries:
 * FT6X36: https://github.com/strange-v/FT6X36.git
 * GT911: https://github.com/TAMCTec/gt911-arduino.git
 * XPT2046: https://github.com/PaulStoffregen/XPT2046_Touchscreen.git
/* uncomment for FT6X36 */
// #define TOUCH_FT6X36
// #define TOUCH_FT6X36_SCL 19
// #define TOUCH_FT6X36_SDA 18
// #define TOUCH_FT6X36_INT 39
// #define TOUCH_SWAP_XY
// #define TOUCH_MAP_X1 480
// #define TOUCH_MAP_X2 0
// #define TOUCH_MAP_Y1 0
// #define TOUCH_MAP_Y2 320
/* uncomment for GT911 */
 #define TOUCH_GT911
 #define TOUCH_GT911_SCL 20
 #define TOUCH_GT911_SDA 19
 #define TOUCH_GT911_INT -1
 #define TOUCH_GT911_RST 38
 #define TOUCH_GT911_ROTATION ROTATION_NORMAL
 #define TOUCH_MAP_Y1 272
 #define TOUCH_MAP_Y2 0
/* uncomment for XPT2046 */
// #define TOUCH_XPT2046
// #define TOUCH_XPT2046_SCK 12
// #define TOUCH_XPT2046_MISO 13
// #define TOUCH_XPT2046_MOSI 11
// #define TOUCH_XPT2046_CS 38
// #define TOUCH_XPT2046_INT 18
// #define TOUCH_XPT2046_ROTATION 0
// #define TOUCH_MAP_X1 4000
// #define TOUCH_MAP_X2 100
// #define TOUCH_MAP_Y1 100
// #define TOUCH_MAP_Y2 4000
int touch_last_x = 0, touch_last_y = 0;
#if defined(TOUCH_FT6X36)
#include <Wire.h>
#include <FT6X36.h>
FT6X36 ts(&Wire, TOUCH_FT6X36_INT);
bool touch_touched_flag = true, touch_released_flag = true;
#elif defined(TOUCH_GT911)
#include <Wire.h>
#include <TAMC_GT911.h>
TAMC_GT911 ts = TAMC_GT911(TOUCH_GT911_SDA, TOUCH_GT911_SCL, TOUCH_GT911_INT, TOUCH_GT911_RST, max(TOUCH_MAP_X1, TOUCH_MAP_X2), max(TOUCH_MAP_Y1, TOUCH_MAP_Y2));
#elif defined(TOUCH_XPT2046)
#include <XPT2046_Touchscreen.h>
#include <SPI.h>
XPT2046_Touchscreen ts(TOUCH_XPT2046_CS, TOUCH_XPT2046_INT);
void touch(TPoint p, TEvent e)
  if (e != TEvent::Tap && e != TEvent::DragStart && e != TEvent::DragMove && e != TEvent::DragEnd)
    return;
  // translation logic depends on screen rotation
#if defined(TOUCH_SWAP_XY)
  touch_last_x = map(p.y, TOUCH_MAP_X1, TOUCH_MAP_X2, 0, gfx->width());
  touch_last_y = map(p.x, TOUCH_MAP_Y1, TOUCH_MAP_Y2, 0, gfx->height());
#else
  touch_last_x = map(p.x, TOUCH_MAP_X1, TOUCH_MAP_X2, 0, gfx->width());
  touch_last_y = map(p.y, TOUCH_MAP_Y1, TOUCH_MAP_Y2, 0, gfx->height());
  switch (e)
  case TEvent::Tap:
    Serial.println("Tap");
    touch_touched_flag = true;
    break;
  case TEvent::DragStart:
    Serial.println("DragStart");
    break;
  case TEvent::DragMove:
    Serial.println("DragMove");
    break;
  case TEvent::DragEnd:
    Serial.println("DragEnd");
    break;
  default:
    Serial.println("UNKNOWN");
    break;
void touch_init()
  Wire.begin(TOUCH_FT6X36_SDA, TOUCH_FT6X36_SCL);
  ts.begin();
  ts.registerTouchHandler(touch);
  Wire.begin(TOUCH_GT911_SDA, TOUCH_GT911_SCL);
  ts.begin();
  ts.setRotation(TOUCH_GT911_ROTATION);
  SPI.begin(TOUCH_XPT2046_SCK, TOUCH_XPT2046_MISO, TOUCH_XPT2046_MOSI, TOUCH_XPT2046_CS);
  ts.begin();
  ts.setRotation(TOUCH_XPT2046_ROTATION);
bool touch_has_signal()
  ts.loop();
  return touch_touched_flag || touch_released_flag;
  return true;
  return ts.tirqTouched();
#else
  return false;
bool touch_touched()
  if (touch_touched_flag)
    touch_touched_flag = false;
    return true;
    return false;
  ts.read();
  if (ts.isTouched)
    touch_last_x = map(ts.points[0].y, TOUCH_MAP_X1, TOUCH_MAP_X2, 0, gfx->width() - 1);
    touch_last_y = map(ts.points[0].x, TOUCH_MAP_Y1, TOUCH_MAP_Y2, 0, gfx->height() - 1);
#else
    touch_last_x = map(ts.points[0].x, TOUCH_MAP_X1, TOUCH_MAP_X2, 0, gfx->width() - 1);
    touch_last_y = map(ts.points[0].y, TOUCH_MAP_Y1, TOUCH_MAP_Y2, 0, gfx->height() - 1);
    return true;
    return false;
  if (ts.touched())
    TS_Point p = ts.getPoint();
    touch_last_x = map(p.y, TOUCH_MAP_X1, TOUCH_MAP_X2, 0, gfx->width() - 1);
    touch_last_y = map(p.x, TOUCH_MAP_Y1, TOUCH_MAP_Y2, 0, gfx->height() - 1);
#else
    touch_last_x = map(p.x, TOUCH_MAP_X1, TOUCH_MAP_X2, 0, gfx->width() - 1);
    touch_last_y = map(p.y, TOUCH_MAP_Y1, TOUCH_MAP_Y2, 0, gfx->height() - 1);
    return true;
    return false;
#else
  return false;
bool touch_released()
  if (touch_released_flag)
    touch_released_flag = false;
    return true;
    return false;
  return true;
  return true;
#else
  return false;
Thanks for any help/pointers!
and my lv_conf.h
 * @file lv_conf.h
 * Configuration file for v8.3.0-dev
 * Copy this file as `lv_conf.h`
 * 1. simply next to the `lvgl` folder
 * 2. or any other places and
 *    - define `LV_CONF_INCLUDE_SIMPLE`
 *    - add the path as include path
/* clang-format off */
#ifndef LV_CONF_H
#define LV_CONF_H
#include <stdint.h>
   COLOR SETTINGS
/*Color depth: 1 (1 byte per pixel), 8 (RGB332), 16 (RGB565), 32 (ARGB8888)*/
#define LV_COLOR_DEPTH 16
/*Swap the 2 bytes of RGB565 color. Useful if the display has an 8-bit interface (e.g. SPI)*/
#define LV_COLOR_16_SWAP 0
/*Enable more complex drawing routines to manage screens transparency.
 *Can be used if the UI is above another layer, e.g. an OSD menu or video player.
 *Requires `LV_COLOR_DEPTH = 32` colors and the screen's `bg_opa` should be set to non LV_OPA_COVER value*/
#define LV_COLOR_SCREEN_TRANSP 0
/* Adjust color mix functions rounding. GPUs might calculate color mix (blending) differently.
 * 0: round down, 64: round up from x.75, 128: round up from half, 192: round up from x.25, 254: round up */
#define LV_COLOR_MIX_ROUND_OFS (LV_COLOR_DEPTH == 32 ? 0: 128)
/*Images pixels with this color will not be drawn if they are chroma keyed)*/
#define LV_COLOR_CHROMA_KEY lv_color_hex(0x00ff00)         /*pure green*/
   MEMORY SETTINGS
/*1: use custom malloc/free, 0: use the built-in `lv_mem_alloc()` and `lv_mem_free()`*/
#define LV_MEM_CUSTOM 0
#if LV_MEM_CUSTOM == 0
    #define LV_MEM_SIZE (48U * 1024U)          /*[bytes]*/
    #define LV_MEM_ADR 0     /*0: unused*/
    #if LV_MEM_ADR == 0
        //#define LV_MEM_POOL_INCLUDE your_alloc_library  /* Uncomment if using an external allocator*/
        //#define LV_MEM_POOL_ALLOC   your_alloc          /* Uncomment if using an external allocator*/
#else       /*LV_MEM_CUSTOM*/
    #define LV_MEM_CUSTOM_INCLUDE <stdlib.h>   /*Header for the dynamic memory function*/
    #define LV_MEM_CUSTOM_ALLOC   malloc
    #define LV_MEM_CUSTOM_FREE    free
    #define LV_MEM_CUSTOM_REALLOC realloc
#endif     /*LV_MEM_CUSTOM*/
/*Number of the intermediate memory buffer used during rendering and other internal processing mechanisms.
 *You will see an error log message if there wasn't enough buffers. */
#define LV_MEM_BUF_MAX_NUM 32
/*Use the standard `memcpy` and `memset` instead of LVGL's own functions. (Might or might not be faster).*/
#define LV_MEMCPY_MEMSET_STD 0
   HAL SETTINGS
/*Default display refresh period. LVG will redraw changed areas with this period time*/
#define LV_DISP_DEF_REFR_PERIOD 30      /*[ms]*/ //15
/*Input device read period in milliseconds*/
#define LV_INDEV_DEF_READ_PERIOD 30     /*[ms]*///30
/*Use a custom tick source that tells the elapsed time in milliseconds.
 *It removes the need to manually update the tick with `lv_tick_inc()`)*/
#define LV_TICK_CUSTOM 1
#if LV_TICK_CUSTOM
    #define LV_TICK_CUSTOM_INCLUDE "Arduino.h"         /*Header for the system time function*/
    #define LV_TICK_CUSTOM_SYS_TIME_EXPR (millis())    /*Expression evaluating to current system time in ms*/
#endif   /*LV_TICK_CUSTOM*/
/*Default Dot Per Inch. Used to initialize default sizes such as widgets sized, style paddings.
 *(Not so important, you can adjust it to modify default sizes and spaces)*/
#define LV_DPI_DEF 130     /*[px/inch]*/
 * FEATURE CONFIGURATION
 * Drawing
/*Enable complex draw engine.
 *Required to draw shadow, gradient, rounded corners, circles, arc, skew lines, image transformations or any masks*/
#define LV_DRAW_COMPLEX 1
#if LV_DRAW_COMPLEX != 0
    /*Allow buffering some shadow calculation.
    *LV_SHADOW_CACHE_SIZE is the max. shadow size to buffer, where shadow size is `shadow_width + radius`
    *Caching has LV_SHADOW_CACHE_SIZE^2 RAM cost*/
    #define LV_SHADOW_CACHE_SIZE 0
    /* Set number of maximally cached circle data.
    * The circumference of 1/4 circle are saved for anti-aliasing
    * radius * 4 bytes are used per circle (the most often used radiuses are saved)
    * 0: to disable caching */
    #define LV_CIRCLE_CACHE_SIZE 4
#endif /*LV_DRAW_COMPLEX*/
/*Default image cache size. Image caching keeps the images opened.
 *If only the built-in image formats are used there is no real advantage of caching. (I.e. if no new image decoder is added)
 *With complex image decoders (e.g. PNG or JPG) caching can save the continuous open/decode of images.
 *However the opened images might consume additional RAM.
 *0: to disable caching*/
#define LV_IMG_CACHE_DEF_SIZE   0
/*Number of stops allowed per gradient. Increase this to allow more stops.
 *This adds (sizeof(lv_color_t) + 1) bytes per additional stop*/
#define LV_GRADIENT_MAX_STOPS       2
/*Default gradient buffer size.
 *When LVGL calculates the gradient "maps" it can save them into a cache to avoid calculating them again.
 *LV_GRAD_CACHE_DEF_SIZE sets the size of this cache in bytes.
 *If the cache is too small the map will be allocated only while it's required for the drawing.
 *0 mean no caching.*/
#define LV_GRAD_CACHE_DEF_SIZE      0
/*Allow dithering the gradients (to achieve visual smooth color gradients on limited color depth display)
 *LV_DITHER_GRADIENT implies allocating one or two more lines of the object's rendering surface
 *The increase in memory consumption is (32 bits * object width) plus 24 bits * object width if using error diffusion */
#define LV_DITHER_GRADIENT      0
#if LV_DITHER_GRADIENT
    /*Add support for error diffusion dithering.
     *Error diffusion dithering gets a much better visual result, but implies more CPU consumption and memory when drawing.
     *The increase in memory consumption is (24 bits * object's width)*/
    #define LV_DITHER_ERROR_DIFFUSION   0
/*Maximum buffer size to allocate for rotation.
 *Only used if software rotation is enabled in the display driver.*/
#define LV_DISP_ROT_MAX_BUF (10*1024)
 * GPU
/*Use STM32's DMA2D (aka Chrom Art) GPU*/
#define LV_USE_GPU_STM32_DMA2D 0
#if LV_USE_GPU_STM32_DMA2D
    /*Must be defined to include path of CMSIS header of target processor
    e.g. "stm32f769xx.h" or "stm32f429xx.h"*/
    #define LV_GPU_DMA2D_CMSIS_INCLUDE
/*Use NXP's PXP GPU iMX RTxxx platforms*/
#define LV_USE_GPU_NXP_PXP 0
#if LV_USE_GPU_NXP_PXP
    /*1: Add default bare metal and FreeRTOS interrupt handling routines for PXP (lv_gpu_nxp_pxp_osa.c)
    *   and call lv_gpu_nxp_pxp_init() automatically during lv_init(). Note that symbol SDK_OS_FREE_RTOS
    *   has to be defined in order to use FreeRTOS OSA, otherwise bare-metal implementation is selected.
    *0: lv_gpu_nxp_pxp_init() has to be called manually before lv_init()
    #define LV_USE_GPU_NXP_PXP_AUTO_INIT 0
/*Use NXP's VG-Lite GPU iMX RTxxx platforms*/
#define LV_USE_GPU_NXP_VG_LITE 0
/*Use SDL renderer API*/
#define LV_USE_GPU_SDL 0
#if LV_USE_GPU_SDL
    #define LV_GPU_SDL_INCLUDE_PATH <SDL2/SDL.h>
    /*Texture cache size, 8MB by default*/
    #define LV_GPU_SDL_LRU_SIZE (1024 * 1024 * 8)
    /*Custom blend mode for mask drawing, disable if you need to link with older SDL2 lib*/
    #define LV_GPU_SDL_CUSTOM_BLEND_MODE (SDL_VERSION_ATLEAST(2, 0, 6))
 * Logging
/*Enable the log module*/
#define LV_USE_LOG 0
#if LV_USE_LOG
    *LV_LOG_LEVEL_TRACE       A lot of logs to give detailed information
    *LV_LOG_LEVEL_INFO        Log important events
    *LV_LOG_LEVEL_WARN        Log if something unwanted happened but didn't cause a problem
    *LV_LOG_LEVEL_ERROR       Only critical issue, when the system may fail
    *LV_LOG_LEVEL_USER        Only logs added by the user
    *LV_LOG_LEVEL_NONE        Do not log anything*/
    #define LV_LOG_LEVEL LV_LOG_LEVEL_WARN
    #define LV_LOG_PRINTF 0
    #define LV_LOG_TRACE_MEM        1
    #define LV_LOG_TRACE_TIMER      1
    #define LV_LOG_TRACE_INDEV      1
    #define LV_LOG_TRACE_DISP_REFR  1
    #define LV_LOG_TRACE_EVENT      1
    #define LV_LOG_TRACE_OBJ_CREATE 1
    #define LV_LOG_TRACE_LAYOUT     1
    #define LV_LOG_TRACE_ANIM       1
#endif  /*LV_USE_LOG*/
 * Asserts
/*Enable asserts if an operation is failed or an invalid data is found.
 *If LV_USE_LOG is enabled an error message will be printed on failure*/
#define LV_USE_ASSERT_NULL          1   /*Check if the parameter is NULL. (Very fast, recommended)*/
#define LV_USE_ASSERT_MALLOC        1   /*Checks is the memory is successfully allocated or no. (Very fast, recommended)*/
#define LV_USE_ASSERT_STYLE         0   /*Check if the styles are properly initialized. (Very fast, recommended)*/
#define LV_USE_ASSERT_MEM_INTEGRITY 0   /*Check the integrity of `lv_mem` after critical operations. (Slow)*/
#define LV_USE_ASSERT_OBJ           0   /*Check the object's type and existence (e.g. not deleted). (Slow)*/
/*Add a custom handler when assert happens e.g. to restart the MCU*/
#define LV_ASSERT_HANDLER while(1);   /*Halt by default*/
 * Others
/*1: Show CPU usage and FPS count*/
#define LV_USE_PERF_MONITOR 0
#if LV_USE_PERF_MONITOR
/*1: Show the used memory and the memory fragmentation
 * Requires LV_MEM_CUSTOM = 0*/
#define LV_USE_MEM_MONITOR 0
#if LV_USE_MEM_MONITOR
#define LV_USE_REFR_DEBUG 0
/*Change the built in (v)snprintf functions*/
#define LV_SPRINTF_CUSTOM 0
#if LV_SPRINTF_CUSTOM
    #define LV_SPRINTF_INCLUDE <stdio.h>
    #define lv_snprintf  snprintf
    #define lv_vsnprintf vsnprintf
#else   /*LV_SPRINTF_CUSTOM*/
    #define LV_SPRINTF_USE_FLOAT 0
#endif  /*LV_SPRINTF_CUSTOM*/
#define LV_USE_USER_DATA 1
/*Garbage Collector settings
 *Used if lvgl is bound to higher level language and the memory is managed by that language*/
#define LV_ENABLE_GC 0
#if LV_ENABLE_GC != 0
    #define LV_GC_INCLUDE "gc.h"                           /*Include Garbage Collector related things*/
#endif /*LV_ENABLE_GC*/
 *  COMPILER SETTINGS
/*For big endian systems set to 1*/
#define LV_BIG_ENDIAN_SYSTEM 0
/*Define a custom attribute to `lv_tick_inc` function*/
#define LV_ATTRIBUTE_TICK_INC
/*Define a custom attribute to `lv_timer_handler` function*/
#define LV_ATTRIBUTE_TIMER_HANDLER
/*Define a custom attribute to `lv_disp_flush_ready` function*/
/*Required alignment size for buffers*/
#define LV_ATTRIBUTE_MEM_ALIGN_SIZE 1
/*Will be added where memories needs to be aligned (with -Os data might not be aligned to boundary by default).
 * E.g. __attribute__((aligned(4)))*/
/*Attribute to mark large constant arrays for example font's bitmaps*/
/*Compiler prefix for a big array declaration in RAM*/
#define LV_ATTRIBUTE_LARGE_RAM_ARRAY
/*Place performance critical functions into a faster memory (e.g RAM)*/
#define LV_ATTRIBUTE_FAST_MEM
/*Prefix variables that are used in GPU accelerated operations, often these need to be placed in RAM sections that are DMA accessible*/
#define LV_ATTRIBUTE_DMA
/*Export integer constant to binding. This macro is used with constants in the form of LV_<CONST> that
 *should also appear on LVGL binding API such as Micropython.*/
#define LV_EXPORT_CONST_INT(int_value) struct _silence_gcc_warning /*The default value just prevents GCC warning*/
/*Extend the default -32k..32k coordinate range to -4M..4M by using int32_t for coordinates instead of int16_t*/
#define LV_USE_LARGE_COORD 0
 *   FONT USAGE
/*Montserrat fonts with ASCII range and some symbols using bpp = 4
 *https://fonts.google.com/specimen/Montserrat*/
#define LV_FONT_MONTSERRAT_8  0
#define LV_FONT_MONTSERRAT_10 0
#define LV_FONT_MONTSERRAT_12 0
#define LV_FONT_MONTSERRAT_14 1
#define LV_FONT_MONTSERRAT_16 0
#define LV_FONT_MONTSERRAT_18 0
#define LV_FONT_MONTSERRAT_20 0
#define LV_FONT_MONTSERRAT_22 0
#define LV_FONT_MONTSERRAT_24 0
#define LV_FONT_MONTSERRAT_26 0
#define LV_FONT_MONTSERRAT_28 0
#define LV_FONT_MONTSERRAT_30 0
#define LV_FONT_MONTSERRAT_32 0
#define LV_FONT_MONTSERRAT_34 0
#define LV_FONT_MONTSERRAT_36 0
#define LV_FONT_MONTSERRAT_38 0
#define LV_FONT_MONTSERRAT_40 0
#define LV_FONT_MONTSERRAT_42 0
#define LV_FONT_MONTSERRAT_44 0
#define LV_FONT_MONTSERRAT_46 0
#define LV_FONT_MONTSERRAT_48 0
/*Demonstrate special features*/
#define LV_FONT_MONTSERRAT_12_SUBPX      0
#define LV_FONT_MONTSERRAT_28_COMPRESSED 0  /*bpp = 3*/
#define LV_FONT_DEJAVU_16_PERSIAN_HEBREW 0  /*Hebrew, Arabic, Persian letters and all their forms*/
#define LV_FONT_SIMSUN_16_CJK            0  /*1000 most common CJK radicals*/
/*Pixel perfect monospace fonts*/
#define LV_FONT_UNSCII_8  0
#define LV_FONT_UNSCII_16 0
/*Optionally declare custom fonts here.
 *E.g. #define LV_FONT_CUSTOM_DECLARE   LV_FONT_DECLARE(my_font_1) LV_FONT_DECLARE(my_font_2)*/
/*Always set a default font*/
#define LV_FONT_DEFAULT &lv_font_montserrat_14
/*Enable handling large font and/or fonts with a lot of characters.
 *Compiler error will be triggered if a font needs it.*/
#define LV_FONT_FMT_TXT_LARGE 0
/*Enables/disables support for compressed fonts.*/
#define LV_USE_FONT_COMPRESSED 0
/*Enable subpixel rendering*/
#define LV_USE_FONT_SUBPX 0
#if LV_USE_FONT_SUBPX
    /*Set the pixel order of the display. Physical order of RGB channels. Doesn't matter with "normal" fonts.*/
    #define LV_FONT_SUBPX_BGR 0  /*0: RGB; 1:BGR order*/
 *  TEXT SETTINGS
 * Select a character encoding for strings.
 * - LV_TXT_ENC_UTF8
 * - LV_TXT_ENC_ASCII
#define LV_TXT_BREAK_CHARS " ,.;:-_"
/*If a word is at least this long, will break wherever "prettiest"
 *To disable, set to a value <= 0*/
#define LV_TXT_LINE_BREAK_LONG_LEN 0
/*Minimum number of characters in a long word to put on a line before a break.
 *Depends on LV_TXT_LINE_BREAK_LONG_LEN.*/
#define LV_TXT_LINE_BREAK_LONG_PRE_MIN_LEN 3
/*Minimum number of characters in a long word to put on a line after a break.
/*The control character to use for signalling text recoloring.*/
#define LV_TXT_COLOR_CMD "#"
/*Support bidirectional texts. Allows mixing Left-to-Right and Right-to-Left texts.
 *The direction will be processed according to the Unicode Bidirectional Algorithm:
#define LV_USE_BIDI 0
#if LV_USE_BIDI
    *`LV_BASE_DIR_LTR` Left-to-Right
    *`LV_BASE_DIR_RTL` Right-to-Left
    *`LV_BASE_DIR_AUTO` detect texts base direction*/
/*Enable Arabic/Persian processing
 *In these languages characters should be replaced with an other form based on their position in the text*/
 *  WIDGET USAGE
/*Documentation of the widgets: https://docs.lvgl.io/latest/en/html/widgets/index.html*/
#define LV_USE_ARC        1
#define LV_USE_ANIMIMG    1
#define LV_USE_BAR        1
#define LV_USE_BTN        1
#define LV_USE_BTNMATRIX  1
#define LV_USE_CANVAS     1
#define LV_USE_CHECKBOX   1
#define LV_USE_DROPDOWN   1   /*Requires: lv_label*/
#define LV_USE_IMG        1   /*Requires: lv_label*/
#define LV_USE_LABEL      1
#if LV_USE_LABEL
    #define LV_LABEL_TEXT_SELECTION 1 /*Enable selecting text of the label*/
    #define LV_LABEL_LONG_TXT_HINT 1  /*Store some extra info in labels to speed up drawing of very long texts*/
#define LV_USE_LINE       1
#define LV_USE_ROLLER     1   /*Requires: lv_label*/
#if LV_USE_ROLLER
    #define LV_ROLLER_INF_PAGES 7 /*Number of extra "pages" when the roller is infinite*/
#define LV_USE_SLIDER     1   /*Requires: lv_bar*/
#define LV_USE_SWITCH     1
#define LV_USE_TEXTAREA   1   /*Requires: lv_label*/
#if LV_USE_TEXTAREA != 0
    #define LV_TEXTAREA_DEF_PWD_SHOW_TIME 1500    /*ms*/
#define LV_USE_TABLE      1
 * EXTRA COMPONENTS
 * Widgets
#define LV_USE_CALENDAR   1
#if LV_USE_CALENDAR
    #define LV_CALENDAR_WEEK_STARTS_MONDAY 0
    #if LV_CALENDAR_WEEK_STARTS_MONDAY
        #define LV_CALENDAR_DEFAULT_DAY_NAMES {"Mo", "Tu", "We", "Th", "Fr", "Sa", "Su"}
    #else
        #define LV_CALENDAR_DEFAULT_DAY_NAMES {"Su", "Mo", "Tu", "We", "Th", "Fr", "Sa"}
    #define LV_CALENDAR_DEFAULT_MONTH_NAMES {"January", "February", "March",  "April", "May",  "June", "July", "August", "September", "October", "November", "December"}
    #define LV_USE_CALENDAR_HEADER_ARROW 1
    #define LV_USE_CALENDAR_HEADER_DROPDOWN 1
#endif  /*LV_USE_CALENDAR*/
#define LV_USE_CHART      1
#define LV_USE_COLORWHEEL 1
#define LV_USE_IMGBTN     1
#define LV_USE_KEYBOARD   1
#define LV_USE_LED        1
#define LV_USE_LIST       1
#define LV_USE_MENU       1
#define LV_USE_METER      1
#define LV_USE_MSGBOX     1
#define LV_USE_SPINBOX    1
#define LV_USE_SPINNER    1
#define LV_USE_TABVIEW    1
#define LV_USE_TILEVIEW   1
#define LV_USE_WIN        1
#define LV_USE_SPAN       1
#if LV_USE_SPAN
    #define LV_SPAN_SNIPPET_STACK_SIZE 64
 * Themes
/*A simple, impressive and very complete theme*/
#if LV_USE_THEME_DEFAULT
    /*0: Light mode; 1: Dark mode*/
    #define LV_THEME_DEFAULT_DARK 0
    /*1: Enable grow on press*/
    #define LV_THEME_DEFAULT_GROW 1
    /*Default transition time in [ms]*/
    #define LV_THEME_DEFAULT_TRANSITION_TIME 80
#endif /*LV_USE_THEME_DEFAULT*/
/*A very simple theme that is a good starting point for a custom theme*/
#define LV_USE_THEME_BASIC 1
/*A theme designed for monochrome displays*/
#define LV_USE_THEME_MONO 1
 * Layouts
/*A layout similar to Flexbox in CSS.*/
#define LV_USE_FLEX 1
/*A layout similar to Grid in CSS.*/
#define LV_USE_GRID 1
 * 3rd party libraries
/*File system interfaces for common APIs */
/*API for fopen, fread, etc*/
#define LV_USE_FS_STDIO 0
#if LV_USE_FS_STDIO
    #define LV_FS_STDIO_LETTER '\0'     /*Set an upper cased letter on which the drive will accessible (e.g. 'A')*/
    #define LV_FS_STDIO_PATH ""         /*Set the working directory. File/directory paths will be appended to it.*/
    #define LV_FS_STDIO_CACHE_SIZE  0   /*>0 to cache this number of bytes in lv_fs_read()*/
/*API for open, read, etc*/
#define LV_USE_FS_POSIX 0
#if LV_USE_FS_POSIX
    #define LV_FS_POSIX_LETTER '\0'     /*Set an upper cased letter on which the drive will accessible (e.g. 'A')*/
    #define LV_FS_POSIX_PATH ""         /*Set the working directory. File/directory paths will be appended to it.*/
    #define LV_FS_POSIX_CACHE_SIZE  0   /*>0 to cache this number of bytes in lv_fs_read()*/
/*API for CreateFile, ReadFile, etc*/
#define LV_USE_FS_WIN32 0
#if LV_USE_FS_WIN32
    #define LV_FS_WIN32_LETTER  '\0'    /*Set an upper cased letter on which the drive will accessible (e.g. 'A')*/
    #define LV_FS_WIN32_PATH ""         /*Set the working directory. File/directory paths will be appended to it.*/
    #define LV_FS_WIN32_CACHE_SIZE 0    /*>0 to cache this number of bytes in lv_fs_read()*/
#define LV_USE_FS_FATFS  0
#if LV_USE_FS_FATFS
    #define LV_FS_FATFS_LETTER '\0'     /*Set an upper cased letter on which the drive will accessible (e.g. 'A')*/
    #define LV_FS_FATFS_CACHE_SIZE 0    /*>0 to cache this number of bytes in lv_fs_read()*/
/*PNG decoder library*/
#define LV_USE_PNG 0
/*BMP decoder library*/
#define LV_USE_BMP 0
/* JPG + split JPG decoder library.
 * Split JPG is a custom format optimized for embedded systems. */
#define LV_USE_SJPG 0
/*GIF decoder library*/
#define LV_USE_GIF 0
/*QR code library*/
#define LV_USE_QRCODE 0
/*FreeType library*/
#define LV_USE_FREETYPE 0
#if LV_USE_FREETYPE
    /*Memory used by FreeType to cache characters [bytes] (-1: no caching)*/
    #define LV_FREETYPE_CACHE_SIZE (16 * 1024)
    #if LV_FREETYPE_CACHE_SIZE >= 0
        /* 1: bitmap cache use the sbit cache, 0:bitmap cache use the image cache. */
        /* sbit cache:it is much more memory efficient for small bitmaps(font size < 256) */
        /* if font size >= 256, must be configured as image cache */
        #define LV_FREETYPE_SBIT_CACHE 0
        /* Maximum number of opened FT_Face/FT_Size objects managed by this cache instance. */
        /* (0:use system defaults) */
        #define LV_FREETYPE_CACHE_FT_FACES 0
        #define LV_FREETYPE_CACHE_FT_SIZES 0
/*Rlottie library*/
#define LV_USE_RLOTTIE 0
/*FFmpeg library for image decoding and playing videos
 *Supports all major image formats so do not enable other image decoder with it*/
#define LV_USE_FFMPEG  0
#if LV_USE_FFMPEG
    /*Dump input information to stderr*/
    #define LV_FFMPEG_AV_DUMP_FORMAT 0
 * Others
/*1: Enable API to take snapshot for object*/
#define LV_USE_SNAPSHOT 0
/*1: Enable Monkey test*/
#define LV_USE_MONKEY   0
/*1: Enable grid navigation*/
#define LV_USE_GRIDNAV  0
/*1: Enable lv_obj fragment*/
#define LV_USE_FRAGMENT 0
* EXAMPLES
/*Enable the examples to be built with the library*/
#define LV_BUILD_EXAMPLES 1
 * DEMO USAGE
/*Show some widget. It might be required to increase `LV_MEM_SIZE` */
#define LV_USE_DEMO_WIDGETS        1
#if LV_USE_DEMO_WIDGETS
#define LV_DEMO_WIDGETS_SLIDESHOW  1
/*Demonstrate the usage of encoder and keyboard*/
#define LV_USE_DEMO_KEYPAD_AND_ENCODER     1
/*Benchmark your system*/
#define LV_USE_DEMO_BENCHMARK   1
/*Stress test for LVGL*/
#define LV_USE_DEMO_STRESS      0
/*Music player demo*/
#define LV_USE_DEMO_MUSIC       0
#if LV_USE_DEMO_MUSIC
# define LV_DEMO_MUSIC_SQUARE       0
# define LV_DEMO_MUSIC_LANDSCAPE    0
# define LV_DEMO_MUSIC_ROUND        0
# define LV_DEMO_MUSIC_LARGE        0
# define LV_DEMO_MUSIC_AUTO_PLAY    0
/*--END OF LV_CONF_H--*/
#endif /*LV_CONF_H*/
Hi @ASMD ,
Based on my own experiences…
I am not familiar with your hardware specifically, so I can only really give generic advice, although you do appear to be using FreeRTOS which I do have experience of.
Having a quick scan over your code I can see you are calling functions from LVGL event handlers and timers which can potentially block LVGL. As a rule personally I have found anything that blocks the execution of LVGL is bad, so any piece of code which makes a call to vTaskDelay() or triggers any kind of tight loop waiting for some other event should be avoided as it is going to delay the screen refreshing in LVGL and you will potentially end up with the type of glitches you are experiencing, I hope that makes sense.
The way I deal with this is to create a system manager process/queue utilising FreeRTOS and run this at a lower priority than the LVGL thread to process functions triggered by the GUI. I also have a single lv_timer_t setup in LVGL which monitors another RTOS queue which allows screen refreshes to be triggered or other events can be posted to LVGL when various external tasks complete. Please see this post for more details.
If you find this approach helpful and have further questions please post here, I will be happy to help if I can.
Note: there could also be something in the Wi-Fi driver itself which is disabling interrupts for a long period, or the network interface driver is at a high priority and doing something to steal time also. These are also possible causes. With that said the above approach is still in my opinion worth using as it helps to keep LVGL working as smoothly as possible…
Kind Regards,
Pete
Thanks for taking your time Pete,
Your solution seems to be really comprehensive but my programming knowledge doesn’t stretch that far. Would you be able to point me to any code examples if you don’t want to share any of your own?
Regarding vTaskDelay: I’ve commented out the vTaskDelay from the WiFi connect function while testing and saw no difference. The WiFi scan function still has very long vTaskDelays but it doesn’t seem to induce the glitches like the WiFi connect. Also since lvgl is running in the main loop, these delays shouldnt impact lvgl right (if my understanding is correct?).
It’s as soon as WiFi.begin() is called that the glitch happens.
If there’s no solution for lvgl to work in partnership with the underlying wifi library, is there a way to ‘pause’ LVGL just before, to mask the glitch?
I’ve reworked my code to use LovyanGFX driver as something to try, but exactly the same glitch happens.
Here’s the new code, condensed into one file
#include "WiFi.h"
#include <lvgl.h>
#include <vector>
#include <LovyanGFX.hpp>
#include <lgfx/v1/platforms/esp32s3/Panel_RGB.hpp>
#include <lgfx/v1/platforms/esp32s3/Bus_RGB.hpp>
#include <driver/i2c.h>
//#include <lgfx_user/LGFX_ESP32S3_RGB_MakerfabsParallelTFTwithTouch43.h>
class LGFX : public lgfx::LGFX_Device
public:
  lgfx::Bus_RGB     _bus_instance;
  lgfx::Panel_RGB   _panel_instance;
  lgfx::Light_PWM   _light_instance;
  lgfx::Touch_GT911 _touch_instance;
  LGFX(void)
      auto cfg = _panel_instance.config();
      cfg.memory_width  = 800;
      cfg.memory_height = 480;
      cfg.panel_width  = 800;
      cfg.panel_height = 480;
      cfg.offset_x = 0;
      cfg.offset_y = 0;
      _panel_instance.config(cfg);
      auto cfg = _panel_instance.config_detail();
      cfg.use_psram = 1;
      _panel_instance.config_detail(cfg);
      auto cfg = _bus_instance.config();
      cfg.panel = &_panel_instance;
      cfg.pin_d0  = GPIO_NUM_8;  // B0
      cfg.pin_d1  = GPIO_NUM_3;  // B1
      cfg.pin_d2  = GPIO_NUM_46; // B2
      cfg.pin_d3  = GPIO_NUM_9;  // B3
      cfg.pin_d4  = GPIO_NUM_1;  // B4
      cfg.pin_d5  = GPIO_NUM_5;  // G0
      cfg.pin_d6  = GPIO_NUM_6;  // G1
      cfg.pin_d7  = GPIO_NUM_7;  // G2
      cfg.pin_d8  = GPIO_NUM_15; // G3
      cfg.pin_d9  = GPIO_NUM_16; // G4
      cfg.pin_d10 = GPIO_NUM_4;  // G5
      cfg.pin_d11 = GPIO_NUM_45; // R0
      cfg.pin_d12 = GPIO_NUM_48; // R1
      cfg.pin_d13 = GPIO_NUM_47; // R2
      cfg.pin_d14 = GPIO_NUM_21; // R3
      cfg.pin_d15 = GPIO_NUM_14; // R4
      cfg.pin_henable = GPIO_NUM_40;
      cfg.pin_vsync   = GPIO_NUM_41;
      cfg.pin_hsync   = GPIO_NUM_39;
      cfg.pin_pclk    = GPIO_NUM_42;
      cfg.freq_write  = 16000000;
      cfg.hsync_polarity    = 0;
      cfg.hsync_front_porch = 8;
      cfg.hsync_pulse_width = 4;
      cfg.hsync_back_porch  = 16;
      cfg.vsync_polarity    = 0;
      cfg.vsync_front_porch = 4;
      cfg.vsync_pulse_width = 4;
      cfg.vsync_back_porch  = 4;
      cfg.pclk_idle_high    = 1;
      _bus_instance.config(cfg);
    _panel_instance.setBus(&_bus_instance);
      auto cfg = _light_instance.config();
      cfg.pin_bl = GPIO_NUM_2;
      _light_instance.config(cfg);
    _panel_instance.light(&_light_instance);
      auto cfg = _touch_instance.config();
      cfg.x_min      = 0;
      cfg.y_min      = 0;
      cfg.bus_shared = false;
      cfg.offset_rotation = 0;
      // I2C接続
      cfg.i2c_port   = I2C_NUM_1;
      cfg.pin_sda    = GPIO_NUM_19;
      cfg.pin_scl    = GPIO_NUM_20;
// for Board v1.3
//      cfg.pin_int    = GPIO_NUM_NC;
//      cfg.pin_rst    = GPIO_NUM_38;
//      cfg.x_max      = 800;
//      cfg.y_max      = 480;
// for Board v1.1 / v1.2
      cfg.x_max      = 480;
      cfg.y_max      = 272;
      cfg.freq       = 400000;
      _touch_instance.config(cfg);
      _panel_instance.setTouch(&_touch_instance);
    setPanel(&_panel_instance);
static LGFX tft;                 // LGFXのインスタンスを作成。
#include "time.h"
typedef enum {
  NONE,
  NETWORK_SEARCHING,
  NETWORK_CONNECTED,
} Network_Status_t;
static const uint32_t screenWidth  = 800;
static const uint32_t screenHeight = 480;
void my_disp_flush( lv_disp_drv_t *disp, const lv_area_t *area, lv_color_t *color_p )
   uint32_t w = ( area->x2 - area->x1 + 1 );
   uint32_t h = ( area->y2 - area->y1 + 1 );
   tft.startWrite();
   tft.setAddrWindow( area->x1, area->y1, w, h );
   //tft.pushColors( ( uint16_t * )&color_p->full, w * h, true );
   tft.writePixels((lgfx::rgb565_t *)&color_p->full, w * h);
   tft.endWrite();
   lv_disp_flush_ready( disp );
void my_touchpad_read( lv_indev_drv_t * indev_driver, lv_indev_data_t * data )
   uint16_t touchX, touchY;
   bool touched = tft.getTouch( &touchX, &touchY);
   if( !touched )
      data->point.x = touchX;
      data->point.y = touchY;
      //Serial.print( "Data x " );
      //Serial.println( touchX );
      //Serial.print( "Data y " );
      //Serial.println( touchY );
//TaskHandle_t ntScanTaskHandler;
void setup() {
  tft.begin();
  tft.setBrightness(100);
  tft.setColorDepth(16);  // RGB565の16ビットに設定
  lv_disp_draw_buf_init( &draw_buf, buf, NULL, screenWidth * 10 );
  delay(10);
  //lv_disp_drv_init(&disp_drv);
  setStyle();
  makeKeyboard();
  buildStatusBar();
  buildPWMsgBox();
  buildBody();
  buildSettings();
void loop() {
  lv_timer_handler();
  //delay(5);
  vTaskDelay(5);
      //beginWIFITask();
      networkConnector();
          networkScanner();
      } else {
  LV_UNUSED(timer);
      break;
      break;
      updateLocalTime();
      break;
      break;
    default:
      break;
    return;
    delay(1);
        break;
 * NETWORK TASKS
              "ScanWIFITask",
              4096,
              NULL,
              1,
              "beginWIFITask",
              4096,
              NULL,
              1,
  while (1) {
    vTaskDelay(10);
      vTaskDelay(10);
    vTaskDelete(NULL);
    //vTaskDelay(5000);
//void beginWIFITask() {
  //vTaskDelete(scanWIFITask);
  WiFi.disconnect();
  //vTaskDelay(100);
    vTaskDelay(250);
  } else {
  vTaskDelete(NULL);
  struct tm timeinfo;
    return;
  char hourMin[6];
Here’s another clip:
output2
Hi @ASMD ,
Okay we can try a different approach…
The following modifications to your setup() and beginWIFITask() functions will allow the halting of the LVGL display refresh timer during the Wi-Fi setup, this may or may not work but feel free to give it a try:
static lv_disp_t *disp;    // Add a variable to keep a copy of the display pointer
void setup() {
  tft.begin();
  delay(10);
 disp =  lv_disp_drv_register(&disp_drv);    // Save the display pointer here to allow access to timer variable
  setStyle();
  makeKeyboard();
  buildStatusBar();
  buildPWMsgBox();
  buildBody();
  buildSettings();
  lv_timer_pause( disp->refr_timer );    // Halt the LVGL display refresh timer.
  WiFi.disconnect();
  //vTaskDelay(100);
    vTaskDelay(250);
  } else {
  lv_timer_resume( disp->refr_timer );    // Resume the display refresh timer
  vTaskDelete(NULL);
I hope that makes sense…
Kind Regards,
Pete
Thanks @pete-pjb
Unfortunately it throws a compile error at the lv_disp_drv_init line:
Hi @ASMD ,
I’m really sorry I made a mistake… rushing!
I have edited the post please take another look, hopefully that will fix it!
Kind Regards,
Pete
Thank you for your effort, but unfortunately it never stops refreshing… I tried removing the lv_timer_resume in order to try freeze the display permanently but it seems just crack on.
Also tried calling the pause from outside of the WiFi task (from the function that calls the task to be created) but still it doesn’t seem to do anything :frowning:
I also tried a very rudimentary thing:
bool DISPGO = true;
void loop() {
  if (DISPGO) {
    lv_timer_handler();
  delay(5);
Setting the bool flag to false just ahead of the WiFi.begin does stop lvgl refresh but the glitches still appear. Not sure if it’s actually stopping the buffer being pushed to the display.
Hi @ASMD ,
This seems quite odd! It could be as I mentioned earlier, there may be a driver which is disabling interrupts for a long period or something running at a high priority in the background…
Please note I have no experience with Arduino or ESP devices, I am used to doing everything myself from scratch and not having prebuilt libraries to work with as I typically work with bespoke hardware platforms where no drivers/libraries exist.
So if you want me to try and help further, can you send me links to/details of the tools you are using please and let me know whether you are using windows/linux for development etc… As much info as possible. I will try and duplicate your development setup which hopefully will give me access to the underlying code so I can try and see what is going on at a lower level.
Kind Regards,
Pete
Hey Pete,
Thanks for your continued help! I have packaged up the tools and dependencies here: Temp share – Google Drive
My IDE is silly old Arduino 1.8.19, I’m on Windows 10, LVGL v8.3.7
I would appreciate if you could take a look if you have any time!
From my basic understanding, I was thinking maybe as the buffer lives in PSRAM, something is happening in WiFi.begin which kicks the SPI bus into lower priority (interrupts?) and the frame buffer gets some out of sync/corrupted data.
But then I changed this line which I thought was locating the graphics buffer internally,
disp_draw_buf = (lv_color_t *)heap_caps_malloc(sizeof(lv_color_t) * screenWidth * screenHeight / 4 , MALLOC_CAP_8BIT | MALLOC_CAP_INTERNAL);
MALLOC_CAP_INTERNAL to MALLOC_CAP_SPIRAM and the glitches were happening pretty much all the time, as I was touching the display etc.
So maybe the graphics buffer isn’t in PSRAM? I’m very lost & confused. I’ve ordered a slightly different variation of this display board, in hopes that I might have a noise prone PCB design or something. The traces to the display l. But as of yet, I’ve not found anybody on the internet to have the same problem with this display as me, that’s after a solid 4 days of trying to figure this out :frowning:
Maybe you can test with other drivers lib. For example LovyanGFX or TFT_eSPI
@Marian_M I tested with LovyanGFX, same problem with glitching, at the same point in the program :disappointed:
Hi @ASMD ,
I have got your files okay and have added the IDE to my Windows 10 machine I am currently failing to compile the sketch (I am learning Arduino on the fly here!). I am out of time today, please bare with me, but I will take another look tomorrow and let you know if I can see anything which will help.
Kind Regards,
Pete
Yes your choiced display RGB mode without framebuffer memory require precise dont interrupted data stream, by pdf on 25MHz dotclock (ST7262). On MCU as ESP seems this isnt simple to guarantie on some special states.
Because of how fast the screen gets corrected the problem is going to be hardware and not software. The ESP32 is not going to be able to redraw the entire display as quickly as what you are seeing. It looks like EMI or aa power issue. How do you have the ESP32 powered. if you are using the power from a USB port on a PC I recommend changing to a wall wart (AC/DC adapter). I would also use something that has a rating of 4-5 amps. While the specs on the board you have might only be 1 amp if you use even a 2 amp rated wall wart you will have a decent amount of voltage drop and when the WiFi kicks on the sudden inrush of current would cause the voltage to drop big time. If the wall wart doesn’t have enough power storage in it you will see a quick drop in voltage and then it will come back up… Get a meter on it and monitor the voltage.
The other thing is the ESP32 uses 3.3 volts. so there is going to be an LDO on the board and if that LDO is not of sufficient size and there isn’t large enough caps you will see this same thing as a result of the way the board is made. I believe that makerfabs uses aa single LDO to handle the power to both the display and the ESP which is not something I would personally do because of this kind of issue happening.
A way you can verify that it is in fact a hardware issue and not software is to intentionally cover the screen with a solid color and then call lv_refr_now and right after that then hide or delete the object used to make the display the solid color. Then call the begin function for the WiFi. If the display glitches while the display is the solid color it is hardware related. if it glitches during the next refresh of the display the glitch would be seen once the solid color is removed because the object that made the solid color was deleted before starting the WiFi. I am willing to bet the glitch occurs when the display is a solid color. I am also willing to bet the problem is nothing that you can correct easily because it is a design problem with the board.
Good points @kdschlosser, I’ve been exploring that aspect:
My display is the Sunton version of the Makerfabs, the 2 are almost identical with just PCB & bom differences.
The Sunton uses 2x 3.3v ldos - one for the ESP32 and one for driving the backlight LED via the driver. I’ve tried back-feeding both simultaneously with 3.3v from my linear psu in case there’s a lack of decoupling but it behaves the same. I’ve also powered it from the 5v input as well, in both cases the max power draw is around 250ma which isn’t enough power I think to cause any concern with ripples. Maybe I’ll put it on my scope to investigate more.
Your idea for the test is a good one, I’ll go try that today.
@pete-pjb thank you also for taking a look, I appreciate your time very much
Hi @ASMD ,
Sorry I have not replied my day job hasn’t gotten in the way!
I’m afraid I can not help quickly with this one…
I have ordered the board you are using as it is very low cost, and it will give me something with an ESP32 CPU which I can play with as I have often thought about taking a look for fun…
Once I have the board I can run your code and step through into the library code if I can(hopefully I can hack the Arduino build and get it to put in the debug symbols) and see what is going on at a low level.
At the moment the delivery is showing July the 18th but hopefully it will come sooner… I will keep you posted.
If you get it solved in the mean time please let us know here…
Kind Regards,
Pete
Hi @pete-pjb thank you for your dedication to try to get to the bottom of this, it’s much appreciated!
To be fair these displays are excellent quality and there is going to be a lot of LVGL development going this way due to cheapness and ease of the ESP32-S3/arduino platform, so it would be good to get to the bottom of it I think :slightly_smiling_face:
I’ve ordered a Makerfabs variant of this board as well just to see, as they have a video where it looks like LVGL+wifi doesn’t glitch like my Sunton display does All Makerfabs MaTouch Support LVGL - ESP32 Touch Display | SquareLine Demo - YouTube.
If the makerfabs one works then indeed it’s the hardware that’s at fault. Should be arriving in the next week :crossed_fingers:
PS they’ve published the code for their example so I’ll go through it to see if they did anything different.
Looks like they’re pinning their tasks to core 0 and core 1 instead of letting rtos manage, so that’s something to try :crossed_fingers:
I am interested in finding out what is causing the issue as well.
