BBQ
December 23, 2020, 3:08am
#1
I use lv_gif_lib to display a gif on my screen with SD card,but the GIF’s color was distortion.And it can’t replay.
ESP32
lvgl7.5.0 lvgl-feat-new-fs-api
Display a GIF
Print log from open_cb,the log tell me the file is read too much .
#include <Arduino.h>
#include "lvgl.h"
#include <TFT_eSPI.h>
#include "lv_fs_if.h"
#include "lv_gif.h"
#include "SD.h"
LV_IMG_DECLARE(w1)
LV_IMG_DECLARE(ez)
/* TFT */
TFT_eSPI tft = TFT_eSPI();
static lv_color_t buf[LV_HOR_RES_MAX * 100];
/* Display flushing */
tft.startWrite();
tft.pushColors(&color_p->full, w * h, true);
tft.endWrite();
lv_disp_flush_ready(disp);
void setup() {
// write your initialization code here
Serial.begin(115200);
lv_fs_if_init();
tft.begin();
tft.setRotation(1);
lv_disp_buf_init(&disp_buf,buf,NULL,LV_HOR_RES_MAX * 100);
/*Initialize the display*/
lv_disp_drv_t disp_drv;
lv_disp_drv_init(&disp_drv);
disp_drv.hor_res = 240;
disp_drv.ver_res = 240;
disp_drv.buffer = &disp_buf;
disp_drv.rotated = 1;
if (!SD.begin()) {
Serial.print("~");
return;
Serial.println("SD card Ready!");
lv_obj_t * img = lv_gif_create_from_file(lv_scr_act(),"S:/sd/sun1301.gif");
lv_obj_align(img,NULL,LV_ALIGN_CENTER,0,0);
void loop() {
// write your code here
lv_task_handler();
delay(5);
BBQ
December 23, 2020, 3:14am
#2
ets Jun 8 2016 00:22:57
rst:0x1 (POWERON_RESET),boot:0x17 (SPI_FAST_FLASH_BOOT)
flash read err, 1000
ets_main.c 371
rst:0x10 (RTCWDT_RTC_RESET),boot:0x17 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
mode:DIO, clock div:2
load:0x3fff0018,len:4
load:0x3fff001c,len:1044
load:0x40078000,len:8896
load:0x40080400,len:5828
entry 0x400806ac
Info: lv_init ready (lv_obj.c #186 lv_init())
Info: Object create ready (lv_obj.c #417 lv_obj_create())
SD card Ready!
Info: image created (lv_img.c #127 lv_img_create())
Info: OPEN (lv_fs_pc.c #128 fs_open())
Info: READ (lv_fs_pc.c #183 fs_read())
Info: SEEK (lv_fs_pc.c #216 fs_seek())
Info: TELL (lv_fs_pc.c #253 fs_tell())
Info: lv_img_set_src: `LV_IMG_SRC_VARIABLE` type found (lv_img.c #180 lv_img_set_src())
Info: image draw: cache miss, cached to an empty entry (lv_img_cache.c #122 _lv_img_cache_open())
Info: label created (lv_label.c #167 lv_label_create())
Info: READ (lv_fs_pc.c #183 fs_read())Preformatted text
my log was print like this.
ly-bo
May 25, 2021, 6:37am
#3
Hello, I am confused about GIF decoding. Can you see your GIF decoding code?
ly-bo
May 25, 2021, 6:39am
#4
when I decode, There will be
if (memcmp(sigver, "GIF", 3) != 0) {
fprintf(stderr, "invalid signature\n");
goto fail;
DJ_9
August 6, 2021, 9:54am
#5
BBQ:
lv_gif_lib
from where you find lv_gif.h file, is it available online or any reference for it?
I am trying to run gif file which is stored in SD card and trying to display on LCD using LVGL libraries
Hello, I would like to ask why I can use your picture to display normally, but not my own picture.
