Display flickers when using Preferences ... put String
Hi, I am using the elecrow 5 inch Display. I wan´t to save a data string in the flash memory, when a button is pressed, by using the libary Preferences.h.
Sometimes the Display is flickering and i don´t know how to prevent the problem.
ESP32 / VSC
8.3.6
Stop flickering when save data.
void SaveData(int Dataseparated,bool newData)
buffer[100];
char text[20];
char Ventilnummer[20] = “Ventil”;
if(newData)
    Dataseparated[CHANGED] = 1;
sprintf(text, "%d,",Dataseparated[POSI]);
strcpy(buffer,text);
for(int i = 1; i < ANZAHLSPEICHERSTELLEN; i++)
    sprintf(text,"%d,",Dataseparated[i]);
    strcat(buffer,text);
//Serial.print("gespeicherte Daten:");
//Serial.println(buffer);
preferences.begin("Ventildata",false);
sprintf(Ventilnummer,"Ventil%d",Dataseparated[POSI]);
preferences.putString(Ventilnummer,buffer);
preferences.end();
void eventButtonSpeichern(lv_event_t * e)
if(event_code == LV_EVENT_RELEASED && speichern)
SaveData(Data->Dataseparated,true);
speichern = false;
lv_obj_set_style_bg_color(buttonSpeichern,lv_palette_main(LV_PALETTE_GREY),LV_PART_MAIN);
