Disable object error
Hi!, I’ve some errors when I try to disable object in tile view
ESP32 - ESP32S3
9.1
I’ve a tileview and a floating button that display a menu (like INK in LVGL demo)… In a specific tileview page i need to disable this menu.
Actually I’ve tile index and control if is scrolled, etc… and get the active tile index, but when I add or clear flag LV_OBJ_FLAG_HIDDEN for this object, raise an error object is NULL
This menu is independent of tileview, is floating and parent was mainscreen
I’ve tried with that object, objects inside , etc… with no result
Do you have the ability to debug your code? From the error it just seems like you are working with a NULL pointer of some sort, try debugging the function where you set LV_OBJ_FLAG_HIDDEN.
Otherwise please share the relevant code here and I’ll take a look.
Kind regards
Yes, I’ve debugged code and raise NULL pointer error.
I’ll try later again and share the relevant code, Thank you
Basically is this the relevant code, I’ve a definition of the object that I’ll hide (it’s a little button bar with options)
  buttonBar = lv_obj_create(mainScreen);
  lv_obj_remove_style_all(buttonBar);
  lv_obj_set_flex_flow(buttonBar, LV_FLEX_FLOW_ROW);
  lv_obj_set_flex_align(buttonBar, LV_FLEX_ALIGN_CENTER, LV_FLEX_ALIGN_CENTER, LV_FLEX_ALIGN_CENTER);
  lv_obj_add_flag(buttonBar, LV_OBJ_FLAG_FLOATING);
  lv_obj_set_style_radius(buttonBar, LV_RADIUS_CIRCLE, 0);
  lv_obj_set_style_border_color(buttonBar, lv_color_white(), 0);
  lv_obj_set_style_border_width(buttonBar, 1, 0);
  lv_obj_set_style_border_opa(buttonBar,LV_OPA_20,0);
  lv_obj_set_style_bg_color(buttonBar, lv_color_black(), 0);
  lv_obj_set_style_bg_opa(buttonBar, 250, 0);
  lv_obj_set_size(buttonBar, 50 * scaleBut, 50 * scaleBut);
  lv_obj_align(buttonBar, LV_ALIGN_BOTTOM_RIGHT, 0,  -LV_DPX(14) );
In the main screen I’ve an event that get the active tile (the active tile is another object of the main screen)
 lv_obj_add_event_cb(tilesScreen, getActTile, LV_EVENT_SCROLL_END, NULL);
  lv_obj_t *actTile = lv_tileview_get_tile_act(tilesScreen);
  lv_coord_t tileX = lv_obj_get_x(actTile) / TFT_WIDTH;
  activeTile = tileX;
activeTile is a enum structure with the name of the active Tile
Later I check the active tile if it’s one I need to hide the button bar
    if (activeTile == MAP)
       lv_obj_add_flag(buttonBar,LV_OBJ_FLAG_HIDDEN);
      lv_obj_clear_flag(buttonBar,LV_OBJ_FLAG_HIDDEN);
All this it’s when tile scroll is finished , of course.
When finish scroll to the tile raise this error
[Error]        (14.915, +14915)         lv_obj_add_flag: Asserted at expression: obj != NULL (The object is NULL) lv_obj.c:116
all objects, buttonBar, tileScreen, and mainScreen are globals variables
Solved!,
buttonBar object was static… now it’s works
