Different language in same label
I want show different language in one label.Like
void _demoLabel()
    LV_FONT_DECLARE(winChineseFonts);
    lv_obj_t* screen = lv_scr_act();
    lv_obj_t* lable = lv_label_create(screen);
    lv_label_set_text(lable, "正在使用Lvgl中...");
    lv_obj_align(lable, LV_ALIGN_CENTER, 0, 0);
    //lv_obj_set_style_text_color(lable, lv_palette_main(LV_PALETTE_BROWN), 0);
    static lv_style_t style;
    lv_style_init(&style);
    lv_style_set_text_font(&style, &winChineseFonts);
    lv_style_set_text_color(&style, lv_palette_main(LV_PALETTE_BROWN));
    lv_obj_add_style(lable,&style,0);
But I find out one label cannot have two fonts.Like Pic
This means I have to convert all words which already exist and need to be used to my font.
That takes up unnecessary memory.
How to show different fonts in same label?
So it can use default font when it don’t exist in my font.
lv_port_pc_visual_studio-release-v8.3.
  • @file lv_conf.h
  • Configuration file for v8.3.4
When I write words which don’t exist in my font, it will turn to default font in one label.
Trying method 3.I have install lv_font_conv and python.But I don’t know how to do next.
And it could work?(use default font when user font don’t have the words).
void _demoLabel()
Have installed nobe.js.
Need a instruction.
Examples
Merge english from Roboto Regular and icons from Font Awesome, and show debug info:
env DEBUG=* lv_font_conv --font Roboto-Regular.ttf -r 0x20-0x7F --font FontAwesome.ttf -r 0xFE00=>0x81 --size 16 --format bin --bpp 3 --no-compress -o output.font
Merge english & russian from Roboto Regular, and show debug info:
env DEBUG=* lv_font_conv --font Roboto-Regular.ttf -r 0x20-0x7F -r 0x401,0x410-0x44F,0x451 --size 16 --format bin --bpp 3 --no-compress -o output.font
Dump all Roboto glyphs to inspect icons and font details:
lv_font_conv --font Roboto-Regular.ttf -r 0x20-0x7F --size 16 --format dump --bpp 3 -o ./dump
Note. Option --no-compress exists temporary, to avoid confusion until LVGL adds compression support.
You can set font fallback for each font. LVGL will check the next fallback if the glyph is not found in the first font
