incorrect operation of the driver, reboots after a random period of time
ESP32
If possible, add screenshots and/or videos about the current issue.
ESP32
Are you using the current master of the lv_port_esp32 repo? What size is your display? Are you using the touch of the display?
I guess you’re running the widgets demo without modification.
I will try to replicate the issue.
hi i’m not using the master, i will try to update, 480x320, yes i use
no i use widgets with changes
i`am upgrade repo, right now
E (1578573) i2c: i2c command link malloc error
SYSTEM_EVENT_STA_DISCONNECTED
IP : 0.0.0.0
used: 11036 ( 34 %), frag: 1 %, biggest free: 21720
motor power = 346.732635, TARGET = 152.789093/168
W (1579626) ILI9488: Could not allocate enough DMA memory!
W (1579627) ILI9488: Could not allocate enough DMA memory!
W (1579628) ILI9488: Could not allocate enough DMA memory!
W (1579634) ILI9488: Could not allocate enough DMA memory!
Just like the error message says, it can’t allocate memory for the buffer we use to send the pixel data.
Can you add ESP_LOGI(TAG, "size: %d", size); below uint32_t size = lv_area_get_width(area) * lv_area_get_height(area);
I will try to replicate the issue you are having.
I’m not being able to replicate the issue, I’m using the following LVGL configuration:
And the following display configuration (no touch at the moment):
CS signal is attached to GND and LED signal is attached to VCC (3.3Vcc).
Hello, I apologize for my long absence, since there was no access to the board, I forgot then to add that I noticed that this bug is triggered on any of my screens, whether I do something or not, it will happen in the range from 40min - 1h:30min
how will my settings look
What changes did you make?
maybe I misunderstood, I did not touch the widgets themselves, I thought for the demo screen
Okay; what were the changes you made to the demo screen?
screen created from scratch
It seems to me like you are using an old version of the repository, can you do git log -n 1 on the root directory of the example and paste the output here?
I did not use a git clone, I downloaded from a zip archive
* @file ili9488.c
* INCLUDES
#include "ili9488.h"
#include "disp_spi.h"
#include "driver/gpio.h"
#include "esp_log.h"
#include "esp_heap_caps.h"
#include "freertos/task.h"
* DEFINES
#define TAG "ILI9488"
#define USB_CS 26
* TYPEDEFS
/*The LCD needs a bunch of command/argument values to be initialized. They are stored in this struct. */
typedef struct {
uint8_t cmd;
uint8_t data[16];
uint8_t databytes; //No of data in data; bit 7 = delay after set; 0xFF = end of cmds.
} lcd_init_cmd_t;
* STATIC PROTOTYPES
static void ili9488_send_cmd(uint8_t cmd);
static void ili9488_send_data(void * data, uint16_t length);
static void ili9488_send_color(void * data, uint16_t length);
* STATIC VARIABLES
* MACROS
* GLOBAL FUNCTIONS
// Functions for driver MAX3421e (implement LCD_Reset as extended GPIO of MAX3421e ) LCD_Reset -> GPOUT1
// CTP_Reset -> GPOUT2
static void ili9488_clr_rst(void);
static void ili9488_set_rst(void);
//static void ft6236_reset(void);
uint8_t tmp = 0xA2;
gpio_set_level(USB_CS, 0);
while(disp_spi_is_busy()) {};
disp_spi_send_data(&tmp, 1); // Write R20 (IOPINS1)
tmp = 0;
disp_spi_send_data(&tmp, 1); // Write GPOUT1 - 0
gpio_set_level(USB_CS, 1);
uint8_t tmp = 0xA2;
tmp = 0x06; // 0x02
disp_spi_send_data(&tmp, 1); // Write GPOUT1 - 1
uint8_t tmp = 0xA2;
tmp = 0;
disp_spi_send_data(&tmp, 1); // Write GPOUT2 - 0
// From github.com/jeremyjh/ESP32_TFT_library
// From github.com/mvturnho/ILI9488-lvgl-ESP32-WROVER-B
void ili9488_init(void)
lcd_init_cmd_t ili_init_cmds[]={
{ILI9488_CMD_SLEEP_OUT, {0x00}, 0x80},
{ILI9488_CMD_POSITIVE_GAMMA_CORRECTION, {0x00, 0x03, 0x09, 0x08, 0x16, 0x0A, 0x3F, 0x78, 0x4C, 0x09, 0x0A, 0x08, 0x16, 0x1A, 0x0F}, 15},
{ILI9488_CMD_NEGATIVE_GAMMA_CORRECTION, {0x00, 0x16, 0x19, 0x03, 0x0F, 0x05, 0x32, 0x45, 0x46, 0x04, 0x0E, 0x0D, 0x35, 0x37, 0x0F}, 15},
{ILI9488_CMD_POWER_CONTROL_1, {0x17, 0x15}, 2},
{ILI9488_CMD_POWER_CONTROL_2, {0x41}, 1},
{ILI9488_CMD_VCOM_CONTROL_1, {0x00, 0x12, 0x80}, 3},
{ILI9488_CMD_MEMORY_ACCESS_CONTROL, {0x48}, 1},
{ILI9488_CMD_COLMOD_PIXEL_FORMAT_SET, {0x66}, 1},
{ILI9488_CMD_INTERFACE_MODE_CONTROL, {0x00}, 1},
{ILI9488_CMD_FRAME_RATE_CONTROL_NORMAL, {0xA0}, 1},
{ILI9488_CMD_DISPLAY_INVERSION_CONTROL, {0x02}, 1},
{ILI9488_CMD_DISPLAY_FUNCTION_CONTROL, {0x02, 0x02}, 2},
{ILI9488_CMD_SET_IMAGE_FUNCTION, {0x00}, 1},
{ILI9488_CMD_WRITE_CTRL_DISPLAY, {0x28}, 1},
{ILI9488_CMD_WRITE_DISPLAY_BRIGHTNESS, {0x7F}, 1},
{ILI9488_CMD_ADJUST_CONTROL_3, {0xA9, 0x51, 0x2C, 0x02}, 4},
{ILI9488_CMD_DISPLAY_ON, {0x00}, 0x80},
{0, {0}, 0xff},
//Initialize non-SPI GPIOs
gpio_pad_select_gpio(ILI9488_DC);
gpio_set_direction(ILI9488_DC, GPIO_MODE_OUTPUT);
gpio_set_direction(USB_CS, GPIO_MODE_OUTPUT);
/* ESP_LOGI(TAG, "ILI9488 Start RST");
for (size_t i = 0; i < 20; i++)
ili9488_set_rst();
vTaskDelay(100 / portTICK_RATE_MS);
ili9488_clr_rst();
ESP_LOGI(TAG, "ILI9488 End RST");
#if ILI9488_ENABLE_BACKLIGHT_CONTROL
gpio_set_direction(ILI9488_BCKL, GPIO_MODE_OUTPUT);
//Reset the display
/* gpio_set_level(ILI9488_RST, 0);
gpio_set_level(ILI9488_RST, 1);
ili9488_clr_rst();
ili9488_set_rst();
ESP_LOGI(TAG, "ILI9488 initialization.");
// Exit sleep
ili9488_send_cmd(0x01); /* Software reset */
//Send all the commands
uint16_t cmd = 0;
while (ili_init_cmds[cmd].databytes!=0xff) {
ili9488_send_cmd(ili_init_cmds[cmd].cmd);
ili9488_send_data(ili_init_cmds[cmd].data, ili_init_cmds[cmd].databytes&0x1F);
if (ili_init_cmds[cmd].databytes & 0x80) {
cmd++;
ili9488_enable_backlight(true);
#if ILI9488_INVERT_DISPLAY
uint8_t data[] = {0x68};
// this same command also sets rotation (portrait/landscape) and inverts colors.
// https://gist.github.com/motters/38a26a66020f674b6389063932048e4c#file-ili9844_defines-h-L24
ili9488_send_cmd(0x36);
ili9488_send_data(&data, 1);
// Flush function based on mvturnho repo
void ili9488_flush(lv_disp_drv_t * drv, const lv_area_t * area, lv_color_t * color_map)
// ESP_LOGI(TAG, "size: %d", size);
lv_color16_t *buffer_16bit = (lv_color16_t *) color_map;
uint8_t *mybuf;
do {
mybuf = (uint8_t *) heap_caps_malloc(3 * size * sizeof(uint8_t), MALLOC_CAP_DMA);
if (mybuf == NULL) ESP_LOGW(TAG, "Could not allocate enough DMA memory!");
} while (mybuf == NULL);
uint32_t LD = 0;
uint32_t j = 0;
for (uint32_t i = 0; i < size; i++) {
LD = buffer_16bit[i].full;
mybuf[j] = (uint8_t) (((LD & 0xF800) >> 8) | ((LD & 0x8000) >> 13));
j++;
mybuf[j] = (uint8_t) ((LD & 0x07E0) >> 3);
j++;
mybuf[j] = (uint8_t) (((LD & 0x001F) << 3) | ((LD & 0x0010) >> 2));
j++;
/* Column addresses */
uint8_t xb[] = {
(uint8_t) (area->x1 >> 8) & 0xFF,
(uint8_t) (area->x1) & 0xFF,
(uint8_t) (area->x2 >> 8) & 0xFF,
(uint8_t) (area->x2) & 0xFF,
/* Page addresses */
uint8_t yb[] = {
(uint8_t) (area->y1 >> 8) & 0xFF,
(uint8_t) (area->y1) & 0xFF,
(uint8_t) (area->y2 >> 8) & 0xFF,
(uint8_t) (area->y2) & 0xFF,
/*Column addresses*/
ili9488_send_cmd(ILI9488_CMD_COLUMN_ADDRESS_SET);
ili9488_send_data(xb, 4);
/*Page addresses*/
ili9488_send_cmd(ILI9488_CMD_PAGE_ADDRESS_SET);
ili9488_send_data(yb, 4);
/*Memory write*/
ili9488_send_cmd(ILI9488_CMD_MEMORY_WRITE);
ili9488_send_color((void *) mybuf, size * 3);
heap_caps_free(mybuf);
void ili9488_enable_backlight(bool backlight)
ESP_LOGI(TAG, "%s backlight.", backlight ? "Enabling" : "Disabling");
uint32_t tmp = 0;
#if (ILI9488_BCKL_ACTIVE_LVL==1)
tmp = backlight ? 1 : 0;
#else
tmp = backlight ? 0 : 1;
gpio_set_level(ILI9488_BCKL, tmp);
* STATIC FUNCTIONS
gpio_set_level(ILI9488_DC, 0); /*Command mode*/
disp_spi_send_data(&cmd, 1);
gpio_set_level(ILI9488_DC, 1); /*Data mode*/
disp_spi_send_data(data, length);
disp_spi_send_colors(data, length);
my file ili9488
lvgl_esp32_drivers.zip (44.3 KB)
please see the archive, it works but with an error that I presented in the topic
I updated the repo, and now it gives me an error, I tried to change it under those settings with which it worked for me, but this is not successful
