Delete the screen contents with cursor
Custom board
8.3
I want to delete a screen which has cursor and pin entry I have created.
Initially, the first screen has no cursor and when I switch to next screen I could delete the entire objects using -
lv_obj_t * prev_screen = lv_scr_act();lv_scr_load(next_screen);lv_obj_del(prev_screen);
But once I use the same code snippet to delete the screen which has cursor and pin entry, the blank screen is appearing!!
Can you please suggest!!
Instead of deleting the prev_screen directly, you could load the next_screen using
lv_screen_load_anim(scr, transition_type, time, delay, auto_del); function and set auto_del to true. This will delete the older screen automatically
