I tried a simple code to show some values on the CYD (Cheap-Yellow-Display with ILI9341), received through MQTT, but the screen always is getting white on updates.
ESP32-WROOM on CYD with ILI9341
Show some values (e.g. temperature) received from MQTT devices
The LVGL init works fine and I can update values, if there is no WIFI initialized. I got a successfull WIFI initialization if I put 1s delay after the display init. When updating the screen after receiving the MQTT meassge the screen turns white. No relevant log messages (INFO-Level).
LVGL version is 8.3 to be compatible through Squarline project
Updating the screen (with static values) without Wifi works stable
#include <TFT_eSPI.h>
#include <Arduino.h>
#include <SPI.h>
#define USE_UI //if you want to use the ui export from Squareline ,pleease define USE_UI.
#ifdef USE_UI
#include <lvgl.h>
#include "ui.h"
#include <WiFi.h>
#include <PubSubClient.h>
const char* ssid = "+++";
const char* password = "+++";
const char* mqtt_server = "192.168.179.40";
WiFiClient espClient;
PubSubClient client(espClient);
static const uint16_t screenWidth = 320;
static const uint16_t screenHeight = 240;
uint16_t calData[5] = { 189, 3416, 359, 3439, 1 };
TFT_eSPI lcd = TFT_eSPI(); /* TFT entity */
bool reconnect() {
// Loop until we're reconnected
unsigned int i = 0;
while (!client.connected()) {
Serial.print("Attempting MQTT connection...");
// Attempt to connect
if (client.connect("CYD1")) {
Serial.println("connected");
// Subscribe
client.publish("CYD1/arbeitszimmer/status", "connected to MQTT");
client.subscribe("esp32/draussen2/bme_temperature");
client.subscribe("esp32/draussen2/bme_humidity");
client.loop();
client.loop();
return true;
} else {
Serial.print("failed, rc=");
Serial.print(client.state());
Serial.println(" try again in 5 seconds");
// Wait 5 seconds before retrying
delay(5000);
i++;
if (i >5)
return false;
return true;
void setup_wifi() {
delay(10);
// We start by connecting to a WiFi network
Serial.println();
Serial.print("Connecting to ");
Serial.println(ssid);
WiFi.begin(ssid, password);
int i=0;
while (WiFi.status() != WL_CONNECTED) {
delay(500);
Serial.print(".");
if(i++ > 5)
ESP.restart();
Serial.println("");
Serial.println("WiFi connected");
Serial.println("IP address: ");
Serial.println(WiFi.localIP());
//vTaskDelete(NULL);
void callbackmqtt(char* topic, byte* payload, unsigned int length) {
// char str[20];
Serial.print("Message arrived [");
Serial.print(topic);
Serial.print("] ");
for (int i = 0; i < length; i++) {
Serial.print((char)payload[i]);
Serial.println();
// client.publish("esp32/epaper/state", "received msg");
if ((String(topic) == ("esp32/draussen2/bme_humidity"))) {
// strcpy(str,(char *)payload);
hum_draussen = atof((char *)payload);
update_draussen = true;
if ((String(topic) == ("esp32/draussen2/bme_temperature"))) {
temp_draussen = atof((char *)payload);
#if defined USE_UI
static lv_color_t buf1[ screenWidth * screenHeight / 13 ];
//_______________________
/* display flash */
void my_disp_flush( lv_disp_drv_t *disp, const lv_area_t *area, lv_color_t *color_p )
uint32_t w = ( area->x2 - area->x1 + 1 );
uint32_t h = ( area->y2 - area->y1 + 1 );
lcd.startWrite();
lcd.setAddrWindow( area->x1, area->y1, w, h );
lcd.pushColors( ( uint16_t * )&color_p->full, w * h, true );
lcd.endWrite();
lv_disp_flush_ready( disp );
//Serial.println("Flush");
void my_print(const char * buf)
Serial.printf(buf);
Serial.flush();
void setup()
Serial.begin( 115200 ); /*serial init */
//Port_D
pinMode(25, OUTPUT);
digitalWrite(25, LOW);
//LCD init
lcd.begin();
lcd.setRotation(1);
lcd.fillScreen(TFT_BLACK);
// lcd.setTouch(calData);
delay(100);
//background light pin
pinMode(27, OUTPUT);
digitalWrite(27, HIGH);
//lvgl init
lv_disp_draw_buf_init( &draw_buf, buf1, NULL, screenWidth * screenHeight / 13 );
/*Display init*/
/*Display driver port of LVGL*/
lv_disp_drv_register( &disp_drv );
lv_log_register_print_cb(my_print);
ui_init(); //LVGL UI init
lv_timer_handler();
delay(1000);
setup_wifi();
client.setServer(mqtt_server, 1883);
// client.setCallback(callback);
client.setCallback(callbackmqtt);
if (!client.connected()) {
reconnect();
client.publish("CYD1/arbeitszimmer/version","1.0");
void loop()
lv_timer_handler();
reconnect();
client.loop();
vTaskDelay(100 / portTICK_PERIOD_MS);
if(update_draussen)
/*char tbuffer[100];
sprintf(tbuffer,"%0.1f °C %0.1f %% \0",temp_draussen,hum_draussen);
Serial.println(tbuffer);*/
delay(1000);
lv_label_set_text(ui_temperatur, "ttt");
lv_refr_now(NULL);
delay(1000);
update_draussen = false;
