When I create a custom font with Noto Sans and Material Symbols, the icons are smaller than intended and not centered. It’s possible that the centering issue is merely a consequence of the sizing issue.
The attached zip file contains font_gen.sh which generates the fonts. It also has a slightly modified built_in_font_gen.py
To run it, you have to download the .ttf file above and rename it to MaterialSymbolsRounded.ttf font issue.zip (349.7 KB)
Update: I also tested the older font (Material Icons instead of Material Style) and it has the same issue:
Layout debug rendering:
“dump” font example. You’ll also find that it’s 12px high:
@kisvegabor Should I open an issue for this at lv_font_conv ?
I’m willing to put a bounty on it to get a fix.
Sidenote: If it can be fixed, would you consider making MaterialSymbols the standard for icons in LVGL? It would give users a lot more freedom in adding more icons as AwesomeFont charges 120$/year + tax and the Pro icons are likely not allowed in GPL-licensed projects (“distributing” is not allowed and it’s not clear what that means).
