Custom_exec_cb prevents lv_anim_del(obj, NULL)
Looking at the code, I see:
static inline void lv_anim_set_custom_exec_cb(lv_anim_t * a, lv_anim_custom_exec_cb_t exec_cb)
    a->var     = a;
    a->exec_cb = (lv_anim_exec_xcb_t)exec_cb;
This block allows us to pass in some data via user_data, and fetch it back out when calling the callback. This works great for writing language bindings, but comes with a notable drawback: the var is overwritten, causing the object-being-animated to no longer clean up the animation automatically during lv_obj_del.
Would it be possible to consolidate the custom and non-custom callbacks into one:
  1. Do not overwrite a->var
  2. Always pass lv_anim_t* via the animation callback to the callback function
  3. Users can fetch the object being animated via a->var in the callback function
By not overwriting a->var we can avoid two tricky bugs: (1) the location of your lv_anim_t struct cannot move in memory before calling lv_anim_start, and (2) we retain the automatic deletion of animations during object deletion.
I agree that it’s a problem. I think the simplest would be to add an
lv_anim_custom_exec_cb_t custom_exec_cb member to lv_anim_t and the animation engine would call the one which is was set.
cc @amirgon
Thanks @kisvegabor - that sounds like a good approach to me as well.
Great! I added it to the ROADMAP fir v9:
I would like to implement this for the upcomming V9 release.
I have one question:
The function lv_anim_custom_delete is now a thing wrapper around the lv_anim_delete since before that change the callback will always be stored in the exec_cb struct field of the animation.
If we add a new field, the lv_anim_delete function cannot be used anymore.
In my optionen we have to options:
  1. duplicate the lv_anim_delete and change one line io compare against the new field instead of the exec_cb.
  2. refatore the lv_anim_delete function to create a function which does the looping over all animations gets a flag to indicate whether to compare agains the exec_cb field or the custom_exec_cb field
I personally would favour the 2 options since I’m not a fan of code duplication.
BTW: I just realized that the same applies for lv_anim_custom_get vs lv_anim_get and maybe some other functions as well.
Thanks.
Martin
Hey,
I was planning to implement this in v9.
So something like:
static inline void lv_anim_set_exec_cb(lv_anim_t * a, lv_anim_exec_xcb_t exec_cb)
    a->exec_cb = exec_cb;
    a->var     = a;
    a->custom_exec_cb = (lv_anim_exec_xcb_t)exec_cb;
//When exec_cb is called
if(a->exec_cb) a->exec_cb(a->var, new_value);
if(a->custom_exec_cb) a->custom_exec_cb(a, new_value);
This way a->var is always the var you set. Would it solve your issue?
As far as I understood the original problem the implementation will not solve the problem because when you set the custom callback with lv_anim_set_custom_exec_cb the internal variable will be set to the animation.
When you than try to delete all animations which belong to an object by calling
it will not find the animations with the custom callback because the variable no longer points to the object but to the animation instance.
The question is: Why do you need to set
a->var = a
in lv_anim_set_custom_exec_cb?
This is no longer neccessary because now you have two different fields for the callbacks in the animation.
And if you don’t overrwrite the a->var in the lv_anim_set_custom_exec_cb function that the original problem of Cameron_Pickett is solved.
The second issue is what I pointed out.
When you try to delete animation by specifying the variable AND the callback.
The current implementation looks like this:
bool lv_anim_delete(void * var, lv_anim_exec_xcb_t exec_cb)
    lv_anim_t * a;
    bool del_any = false;
    a        = _lv_ll_get_head(anim_ll_p);
    while(a != NULL) {
        bool del = false;
        if((a->var == var || var == NULL) && (a->exec_cb == exec_cb || exec_cb == NULL)) {
            _lv_ll_remove(anim_ll_p, a);
            if(a->deleted_cb != NULL) a->deleted_cb(a);
            lv_free(a);
            anim_mark_list_change(); /*Read by `anim_timer`. It need to know if a delete occurred in
                                       the linked list*/
            del_any = true;
            del = true;
        /*Always start from the head on delete, because we don't know
         *how `anim_ll_p` was changes in `a->deleted_cb` */
        a = del ? _lv_ll_get_head(anim_ll_p) : _lv_ll_get_next(anim_ll_p, a);
    return del_any;
With this function you cannot delete an animation by checking the custom_exec_cb
Therefore my question of how the delete function should be implemented.
Thanks
Martin
I think the cleanest would be to have both
and
bool lv_anim_delete_custom(void * var, lv_anim_custom_exec_cb_t custom_exec_cb)
What do you think?
I think too that the best way is to have both functions.
The only problem I have is that the code for both functions is highly redundant, basically only one line is differnt.
So may question is, should we
  • duplicate the code or
  • create a function where we pass the information what we want to compare as parameter and the make two inline wrappers for the two functions:
static bool _anim_delete(void * var, void * cb, bool custom_callback)
    lv_anim_t * a;
    while(a != NULL) {
        bool del = false;
        if (  (a->var == var || var == NULL)
           && (  !cb
              || ( custom_callback && ((void *) a->exec_cb        == cb))
              || (!custom_callback && ((void *) a->custom_exec_cb == cb))
            lv_free(a);
                                     the linked list*/
            del_any = true;
            del = true;
    return del_any;
    return _anim_delete(var, (void *)exec_cb, false);
bool lv_anim_custom_delete(void * var, lv_anim_custom_exec_cb_t exec_cb)
    return _anim_delete(var, (void *)exec_cb, true);
Personally I prefer the second option to avoid code duplication as much as possible.
Thanks,
Martin
I perfectly agree. Would you like to send a Pill request for the master branch?
Sure, no problem.
Also, I would like to take on Use anim events to replace many callbacks with one.
How should be start the dicussion for that?
Open an issue on github?
Thanks,
Martin
Great!
I was thinking about it, and I’m not sure it has enough added value to be worth the refactoring and breaking the API. So let’s focus on the custom_exec_cb related update.
