Custom decoder SPIFLASH and get_area
Image spiflash decoder and rendering with transformations
STM32F411 + spiflash
The decoder I wrote seems working with images as designed but I have problem when some transformation are involved during rendering.
For example, I have an arrow 4 pixels width and 144 pixels height rotating by animation.
In its original position it is showed, but when it starts to rotate it disappears.
I think my problems are in my get_area decoder function because I don’t really understand how rendering works.
In lv_draw_images.c, I put my focus on the function img_decode_and_draw, follow the snippet of the main else branch of it.
/*Draw in smaller pieces*/
else {
    lv_area_t relative_full_area_to_decode = *clipped_img_area;
    lv_area_move(&relative_full_area_to_decode, -img_area->x1, -img_area->y1);
    lv_area_t tmp;
    if(relative_decoded_area == NULL) relative_decoded_area = &tmp;
    relative_decoded_area->x1 = LV_COORD_MIN;
    relative_decoded_area->y1 = LV_COORD_MIN;
    relative_decoded_area->x2 = LV_COORD_MIN;
    relative_decoded_area->y2 = LV_COORD_MIN;
    lv_result_t res = LV_RESULT_OK;
    while(res == LV_RESULT_OK) {
        res = lv_image_decoder_get_area(decoder_dsc, &relative_full_area_to_decode, relative_decoded_area);
        lv_area_t absolute_decoded_area = *relative_decoded_area;
        lv_area_move(&absolute_decoded_area, img_area->x1, img_area->y1);
        if(res == LV_RESULT_OK) {
            /*Limit draw area to the current decoded area and draw the image*/
            lv_area_t clipped_img_area_sub;
            if(lv_area_intersect(&clipped_img_area_sub, clipped_img_area, &absolute_decoded_area)) {
                draw_core_cb(t, draw_dsc, decoder_dsc, &sup,
                             &absolute_decoded_area, &clipped_img_area_sub);
My decoder get_area function gets the image from spiflash line by line(due to memory limitations).
At the first call it allocates the line buffer by relative_full_area_to_decode x1,x2,cf and uses it in the iteration until it reads all lines needed.
When the rotation comes, the code at the beginning of the snippet
puts negative value in relative_full_area_to_decode->x1 and I don’t understand what it means.
Does anyone explain me the really meaning relative_full_area_to_decode informations?
Does the decoder spiflash “line by line” work when rotation or any other transformations are on?
Thanks for any tips you’ll give me.
Best regards.
Transformations on decoded image work only if the image stays totally in memory (RAM/FLASH/SPIFLASH MEMORY MAPPED) as c-array.
Image (lv_image) | LVGL Open
Transformations need the full pixel buffer, so they don’t work on indexed (LV_COLOR_FORMAT_I1/2/4/8 ) or alpha-only formats — use ARGB, RGB or A8 for anything you plan to rotate or scale. The widget’s own get_width/height/x/y still return the untransformed values.
So I store in programFlash ( via memory mapped) the images involved in transformation and the static one in spiFlash (via my custom decoder).
Thanks.
