`cst816s: failed reading chip id` when using lvgl, waveshare display, nrf5340dk
When pressing the button on the the Zephyr sample I am getting an error:
[00:00:01.159,332] <err> cst816s: failed reading chip id
*** Booting nRF Connect SDK v3.5.99-ncs1-1 ***
[00:00:01.163,635] <inf> app: Starting...
[00:00:42.109,527] <err> cst816s: Could not read x data
[00:00:42.609,710] <err> cst816s: Could not read x data
[00:00:43.109,863] <err> cst816s: Could not read x data
[00:00:43.130,889] <err> cst816s: Could not read x data
[00:00:45.089,874] <err> cst816s: Could not read x data
[00:00:45.589,996] <err> cst816s: Could not read x data
nrf5340 DK with nRF Connect for Visual Studio Code and Zephyr RTOS. The display is a Waveshare 1.69 inch screen.
8.3
Pressing the button. Swipe left, right, up, and down next.
Searching for similar bugs and resolution.
main.c
#include <zephyr/device.h>
#include <zephyr/devicetree.h>
#include <zephyr/drivers/display.h>
#include <zephyr/drivers/gpio.h>
#include <lvgl.h>
#include <stdio.h>
#include <string.h>
#include <zephyr/kernel.h>
#include <lvgl_input_device.h>
#define LOG_LEVEL CONFIG_LOG_DEFAULT_LEVEL
#include <zephyr/logging/log.h>
LOG_MODULE_REGISTER(app);
static uint32_t count;
#ifdef CONFIG_GPIO
static struct gpio_dt_spec button_gpio = GPIO_DT_SPEC_GET_OR(
		DT_ALIAS(sw0), gpios, {0});
static struct gpio_callback button_callback;
static void button_isr_callback(const struct device *port,
				struct gpio_callback *cb,
				uint32_t pins)
	ARG_UNUSED(port);
	ARG_UNUSED(cb);
	ARG_UNUSED(pins);
	count = 0;
#endif /* CONFIG_GPIO */
#ifdef CONFIG_LV_Z_ENCODER_INPUT
static const struct device *lvgl_encoder =
	DEVICE_DT_GET(DT_COMPAT_GET_ANY_STATUS_OKAY(zephyr_lvgl_encoder_input));
#endif /* CONFIG_LV_Z_ENCODER_INPUT */
static void lv_btn_click_callback(lv_event_t *e)
	LOG_INF("lv_btn_click_callback called");
	ARG_UNUSED(e);
	count = 0;
int main(void)
	char count_str[11] = {0};
	const struct device *display_dev;
	lv_obj_t *hello_world_label;
	lv_obj_t *count_label;
	LOG_INF("Starting...");
	display_dev = DEVICE_DT_GET(DT_CHOSEN(zephyr_display));
	if (!device_is_ready(display_dev)) {
		LOG_ERR("Device not ready, aborting test");
		return 0;
	lv_obj_set_style_bg_color(lv_scr_act(), lv_color_black(), LV_PART_MAIN);
	lv_obj_set_style_text_color(lv_scr_act(), lv_color_white(), LV_PART_MAIN);
#ifdef CONFIG_GPIO
	if (gpio_is_ready_dt(&button_gpio)) {
		int err;
		err = gpio_pin_configure_dt(&button_gpio, GPIO_INPUT);
		if (err) {
			LOG_ERR("failed to configure button gpio: %d", err);
			return 0;
		gpio_init_callback(&button_callback, button_isr_callback,
				   BIT(button_gpio.pin));
		err = gpio_add_callback(button_gpio.port, &button_callback);
		if (err) {
			LOG_ERR("failed to add button callback: %d", err);
			return 0;
		err = gpio_pin_interrupt_configure_dt(&button_gpio,
						      GPIO_INT_EDGE_TO_ACTIVE);
		if (err) {
			LOG_ERR("failed to enable button callback: %d", err);
			return 0;
	lv_obj_t *arc;
	lv_group_t *arc_group;
	arc = lv_arc_create(lv_scr_act());
	lv_obj_align(arc, LV_ALIGN_CENTER, 0, 0);
	lv_obj_set_size(arc, 150, 150);
	arc_group = lv_group_create();
	lv_group_add_obj(arc_group, arc);
	lv_indev_set_group(lvgl_input_get_indev(lvgl_encoder), arc_group);
	if (IS_ENABLED(CONFIG_LV_Z_POINTER_KSCAN) || IS_ENABLED(CONFIG_LV_Z_POINTER_INPUT)) {
		lv_obj_t *hello_world_button;
		hello_world_button = lv_btn_create(lv_scr_act());
		lv_obj_align(hello_world_button, LV_ALIGN_CENTER, 0, 0);
		lv_obj_add_event_cb(hello_world_button, lv_btn_click_callback, LV_EVENT_CLICKED,
						NULL);
		hello_world_label = lv_label_create(hello_world_button);
	} else {
		hello_world_label = lv_label_create(lv_scr_act());
	lv_label_set_text(hello_world_label, "Hello world!");
	lv_obj_align(hello_world_label, LV_ALIGN_CENTER, 0, 0);
	lv_obj_set_style_text_font(hello_world_label, &lv_font_montserrat_16, LV_PART_MAIN);
	count_label = lv_label_create(lv_scr_act());
	lv_obj_align(count_label, LV_ALIGN_BOTTOM_MID, 0, 0);
	lv_obj_set_style_text_font(count_label, &lv_font_montserrat_16, LV_PART_MAIN);
	lv_task_handler();
	display_blanking_off(display_dev);
	while (1) {
		if ((count % 100) == 0U) {
			sprintf(count_str, "%d", count/100U);
			lv_label_set_text(count_label, count_str);
		lv_task_handler();
		++count;
		k_sleep(K_MSEC(10));
prj.conf
CONFIG_LV_Z_MEM_POOL_SIZE=16384
CONFIG_LV_Z_SHELL=y
CONFIG_MAIN_STACK_SIZE=2048
CONFIG_DISPLAY=y
CONFIG_DISPLAY_LOG_LEVEL_ERR=y
CONFIG_DISPLAY_LOG_LEVEL_INF=y
CONFIG_LOG=y
CONFIG_SHELL=y
CONFIG_LVGL=y
CONFIG_LV_MEM_CUSTOM=y
CONFIG_LV_USE_LOG=y
CONFIG_LV_USE_LABEL=y
CONFIG_LV_USE_BTN=y
CONFIG_LV_USE_ARC=y
CONFIG_LV_USE_IMG=y
CONFIG_LV_USE_MONKEY=y
CONFIG_LV_FONT_MONTSERRAT_16=y
#added to get touch working
CONFIG_INPUT=y
CONFIG_LV_Z_POINTER_INPUT=y
CONFIG_LV_Z_ENCODER_INPUT=y
nrf5340dk_nrf5340_cpuapp.overlay
&pinctrl {
    spi4_default: spi4_default {
        group1 {
            psels = <NRF_PSEL(SPIM_SCK, 0, 6)>,
                <NRF_PSEL(SPIM_MOSI, 0, 25)>;
    spi4_sleep: spi4_sleep {
        group1 {
            low-power-enable;
    // Set to I2C pins that the touch screen is connected to
    i2c2_default: i2c2_default {
        group1 {
            psels = <NRF_PSEL(TWIM_SDA, 1, 2)>,
                <NRF_PSEL(TWIM_SCL, 1, 3)>;
    i2c2_sleep: i2c2_sleep {
        group1 {
            low-power-enable;
&spi4 {
	compatible = "nordic,nrf-spim";
	status = "okay";
	pinctrl-0 = <&spi4_default>;
	pinctrl-1 = <&spi4_sleep>;
    pinctrl-names = "default", "sleep";
	cs-gpios = <&gpio0 11 GPIO_ACTIVE_LOW>;
    st7789v_st7789v_tl019fqv01: st7789v@0 {
        compatible = "sitronix,st7789v";
        spi-max-frequency = <20000000>;
        reg = <0>;
        cmd-data-gpios = < &gpio1 11 GPIO_ACTIVE_LOW>;
        reset-gpios = < &gpio1 10 GPIO_ACTIVE_LOW>;
        width = <240>;
        height = <280>;
        x-offset = <0>;
        y-offset = <0>;
        vcom = <0x19>;
        gctrl = <0x35>;
        vrhs = <0x12>;
        vdvs = <0x20>;
        mdac = <0x00>;
        gamma = <0x01>;
        colmod = <0x05>;
        lcm = <0x2c>;
        porch-param = [0c 0c 00 33 33];
        cmd2en-param = [5a 69 02 01];
        pwctrl1-param = [a4 a1];
        pvgam-param = [D0 04 0D 11 13 2B 3F 54 4C 18 0D 0B 1F 23];
        nvgam-param = [D0 04 0C 11 13 2C 3F 44 51 2F 1F 1F 20 23];
        ram-param = [00 F0];
        rgb-param = [CD 08 14];
&i2c2 {
    compatible = "nordic,nrf-twim";
    status = "okay";
    clock-frequency = <I2C_BITRATE_FAST>;
    pinctrl-0 = <&i2c2_default>;
    pinctrl-1 = <&i2c2_sleep>;
    cst816s: cst816s@15 {
        compatible = "hynitron,cst816s";
        reg = <0x15>;
        irq-gpios = <&gpio1 0 GPIO_ACTIVE_LOW>;
        rst-gpios = <&gpio0 20 GPIO_ACTIVE_LOW>;
	fstab {
		compatible = "zephyr,fstab";
		lfs: lfs {
			compatible = "zephyr,fstab,littlefs";
			mount-point = "/lfs";
			partition = <&littlefs_storage>;
			automount;
            read-size = <16>;
			prog-size = <16>;
			cache-size = <64>;
			lookahead-size = <32>;
			block-cycles = <512>;
/delete-node/ &storage_partition;
&mx25r64 {
	partitions {
		compatible = "fixed-partitions";
		#address-cells = <1>;
		#size-cells = <1>;
		littlefs_storage: partition@0 {
			label = "littlefs_storage";
			reg = <0x00000000 0x00200000>;
		lvgl_raw_partition: partition@200000 {
			label = "lvgl_raw_partition";
			reg = <0x00200000 0x00200000>;
        settings_partition: partition@400000 {
            label = "settings_partition";
            reg = <0x400000 0x100000 >;
    chosen {
        nordic,pm-ext-flash = &mx25r64;
        zephyr,display = &st7789v_st7789v_tl019fqv01;
        zephyr,keyboard-scan = &cst816s;
    aliases {
        vibrator_pwm = &led0;
    lvgl_pointer_input: lvgl_pointer {
        compatible = "zephyr,lvgl-pointer-input";
        input = <&cst816s>;
        swap-xy;
        invert-x;
    aliases {
        input = &cst816s;
    vib_pwr: vib-pwr-ctrl {
        compatible = "regulator-fixed";
        regulator-name = "vib-pwr-ctrl";
        enable-gpios = <&gpio1 14 GPIO_ACTIVE_HIGH>;
did u find the solution ? I just have the same problem
