My hardware
Hello, I’m currently using LVGL v8 to run on my ESP32(WROOM kit) dev board. I’m trying to display an image with a custom image that I have converted to a C array bitmap through LVGL image converter.
The actual problem:
The code works and runs as I expected, however, the image shows no data, other things like buttons, labels, screen just works fine as I tested it before…
Code
lv_disp_draw_buf_init(&draw_buf, buf1, NULL, TFT_WIDTH * TFT_HEIGHT / 10); /*Initialize the display buffer.*/
disp_drv.flush_cb = my_disp_flush; /*Set your driver function*/
disp_drv.draw_buf = &draw_buf; /*Assign the buffer to the display*/
disp_drv.hor_res = TFT_WIDTH; /*Set the horizontal resolution of the display*/
disp_drv.ver_res = TFT_HEIGHT; /*Set the vertical resolution of the display*/
//LVGL registering
lv_disp_t *disp = lv_disp_drv_register(&disp_drv);
lv_indev_drv_init(&indev_drv); /*Basic initialization*/
indev_drv.type = LV_INDEV_TYPE_POINTER; /*Touch pad is a pointer-like device*/
indev_drv.read_cb = my_touchpad_read; /*Set your driver function*/
lv_indev_drv_register(&indev_drv); /*Finally register the driver*/
disp->refr_timer->period = (uint32_t)(1000 / FPS);
//Create a theme
lv_img_dsc_t image = {
LV_IMG_CF_TRUE_COLOR, // Header CF
0, // header.alwayszero
0, // Unknown
48, // Width
48, // height
2304 * LV_COLOR_SIZE / 8, // data size
testmap, // data
theme = lv_img_create(lv_scr_act());
lv_img_set_src(theme, &image);
lv_obj_set_width(theme, LV_SIZE_CONTENT); /// 1
lv_obj_set_height(theme, LV_SIZE_CONTENT);
lv_obj_set_align(theme, LV_ALIGN_CENTER);
The C array:
const LV_ATTRIBUTE_MEM_ALIGN uint8_t testmap[] = {
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x60, 0x09, 0xe0, 0x19, 0xa2, 0x2a, 0x44, 0x3b, 0x64, 0x3b, 0x64, 0x43, 0x04, 0x3b, 0xe1, 0x19, 0x40, 0x09, 0x62, 0x22, 0x64, 0x3b, 0xa5, 0x43, 0xe6, 0x4b, 0x47, 0x54, 0x47, 0x54, 0x46, 0x4c, 0x06, 0x4c, 0xc5, 0x43, 0x03, 0x33, 0x00, 0x1a, 0xe0, 0x00, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x61, 0x11, 0x02, 0x22, 0xe5, 0x3a, 0x66, 0x43, 0xe7, 0x53, 0x48, 0x5c, 0x88, 0x64, 0x88, 0x64, 0x88, 0x64, 0x69, 0x64, 0xc7, 0x4b, 0xc3, 0x32, 0x08, 0x54, 0x88, 0x5c, 0xa8, 0x5c, 0x88, 0x64, 0xa8, 0x5c, 0xa8, 0x5c, 0xa8, 0x5c, 0x87, 0x5c, 0xa8, 0x5c, 0x88, 0x5c, 0xe7, 0x53, 0x05, 0x3b, 0xc2, 0x19, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x80, 0x00, 0x20, 0x09, 0x42, 0x2a, 0xa6, 0x4b, 0x27, 0x5c, 0x68, 0x64, 0x89, 0x64, 0x88, 0x64, 0x88, 0x64, 0x87, 0x64, 0x87, 0x5c, 0x87, 0x5c, 0x88, 0x5c, 0x88, 0x5c, 0x88, 0x5c, 0xa8, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0x87, 0x5c, 0x88, 0x64, 0xa8, 0x64, 0xa8, 0x5c, 0xa8, 0x5c, 0xa8, 0x5c, 0xa8, 0x64, 0xa8, 0x64, 0x88, 0x64, 0xa6, 0x4b, 0x43, 0x2a, 0x00, 0x09, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x09, 0x84, 0x2a, 0x66, 0x43, 0x08, 0x54, 0x89, 0x64, 0x48, 0x5c, 0x07, 0x54, 0xa6, 0x4b, 0x65, 0x43, 0x44, 0x43, 0x85, 0x43, 0x27, 0x54, 0x88, 0x64, 0x87, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0x67, 0x5c, 0xc6, 0x4b, 0x86, 0x4b, 0x66, 0x4b, 0x66, 0x4b, 0x66, 0x43, 0xa6, 0x4b, 0xe7, 0x53, 0x28, 0x5c, 0x89, 0x64, 0x6a, 0x64, 0xc9, 0x5b, 0xc4, 0x21, 0xc2, 0x08, 0xc3, 0x08, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x81, 0x11, 0x05, 0x3b, 0x48, 0x5c, 0x89, 0x5c, 0x49, 0x5c, 0x05, 0x3b, 0x84, 0x32, 0x04, 0x2a, 0x6a, 0x5b, 0x6e, 0x7c, 0x8e, 0x7c, 0x0c, 0x6c, 0xe6, 0x42, 0x86, 0x4b, 0x88, 0x64, 0xa7, 0x5c, 0xc7, 0x5c, 0xa7, 0x5c, 0x68, 0x5c, 0x46, 0x43, 0xca, 0x63, 0xe8, 0x4a, 0x66, 0x3a, 0x8b, 0x63, 0xec, 0x6b, 0xec, 0x6b, 0x6a, 0x5b, 0x08, 0x4b, 0x06, 0x43, 0xca, 0x5b, 0xc7, 0x42, 0x43, 0x19, 0x03, 0x21, 0xe3, 0x18, 0xc3, 0x18, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xa2, 0x19, 0x87, 0x4b, 0x69, 0x5c, 0xa8, 0x5c, 0xa8, 0x5c, 0x27, 0x54, 0x21, 0x1a, 0x23, 0x22, 0x24, 0x2a, 0x8a, 0x5b, 0x4e, 0x7c, 0xaf, 0x7c, 0x8e, 0x7c, 0xe6, 0x3a, 0x82, 0x2a, 0x67, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa8, 0x5c, 0x07, 0x54, 0x87, 0x4b, 0x13, 0xae, 0xb0, 0x84, 0x6b, 0x5b, 0xf5, 0xb5, 0xf5, 0xb5, 0x16, 0xb6, 0xd4, 0xad, 0x51, 0x95, 0x89, 0x5b, 0x04, 0x2a, 0x63, 0x21, 0x44, 0x21, 0x24, 0x29, 0x24, 0x21, 0xe3, 0x20, 0xc3, 0x18,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xe0, 0x08, 0x47, 0x4b, 0x89, 0x64, 0x88, 0x64, 0xa8, 0x5c, 0x88, 0x5c, 0x88, 0x5c, 0x47, 0x5c, 0xe7, 0x53, 0xa7, 0x4b, 0x86, 0x4b, 0x66, 0x4b, 0x46, 0x43, 0x86, 0x4b, 0xa7, 0x4b, 0x27, 0x54, 0x88, 0x5c, 0x88, 0x5c, 0xa8, 0x5c, 0xa8, 0x5c, 0x68, 0x5c, 0xa5, 0x4b, 0x45, 0x43, 0xe5, 0x3a, 0xa4, 0x32, 0xe5, 0x3a, 0xc5, 0x3a, 0xc5, 0x3a, 0xc5, 0x3a, 0xc5, 0x3a, 0xa5, 0x3a, 0x82, 0x21, 0x23, 0x21, 0x24, 0x21, 0x24, 0x21, 0x25, 0x29, 0x24, 0x29, 0x04, 0x21,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xc0, 0x08, 0xa5, 0x42, 0xa6, 0x63, 0xc5, 0x63, 0xe5, 0x63, 0xe5, 0x63, 0xe5, 0x63, 0xe6, 0x63, 0xe6, 0x63, 0xc6, 0x63, 0xc6, 0x5b, 0xc7, 0x63, 0xc7, 0x63, 0xc7, 0x63, 0xc6, 0x63, 0xc6, 0x63, 0xc6, 0x5b, 0xa5, 0x5b, 0xa5, 0x5b, 0xa5, 0x5b, 0xe6, 0x63, 0x27, 0x6c, 0x48, 0x6c, 0x49, 0x6c, 0x49, 0x6c, 0x49, 0x6c, 0x6a, 0x6c, 0x49, 0x64, 0x6a, 0x64, 0x4a, 0x6c, 0xa9, 0x5b, 0x83, 0x21, 0x44, 0x21, 0x25, 0x29, 0x24, 0x29, 0x24, 0x29, 0x24, 0x29, 0x24, 0x29,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x20, 0x08, 0x61, 0x39, 0xc4, 0x72, 0xe3, 0x82, 0x04, 0x8b, 0x03, 0x8b, 0x24, 0x8b, 0x24, 0x8b, 0xe4, 0x7a, 0x82, 0x6a, 0x42, 0x62, 0x01, 0x5a, 0x01, 0x5a, 0x01, 0x5a, 0xe0, 0x59, 0xe0, 0x59, 0xe0, 0x51, 0xc0, 0x51, 0xc0, 0x51, 0xe0, 0x51, 0x00, 0x52, 0x00, 0x52, 0x42, 0x52, 0xa3, 0x52, 0x05, 0x53, 0x87, 0x63, 0xe8, 0x6b, 0xe8, 0x63, 0x29, 0x64, 0x4a, 0x6c, 0xe7, 0x4a, 0x43, 0x19, 0x44, 0x29, 0x25, 0x29, 0x04, 0x21, 0x24, 0x29, 0x24, 0x29, 0x24, 0x21,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x10, 0x41, 0x49, 0xa5, 0x8a, 0xe4, 0x9a, 0x04, 0xa3, 0x05, 0xab, 0x05, 0xab, 0x25, 0xab, 0x26, 0xa3, 0x06, 0x9b, 0x06, 0x9b, 0xe6, 0x92, 0xe5, 0x92, 0xe5, 0x92, 0x05, 0x9b, 0x05, 0x9b, 0x05, 0x9b, 0x05, 0x93, 0x05, 0x93, 0x26, 0x93, 0x26, 0x93, 0x05, 0x8b, 0xe4, 0x82, 0xc4, 0x7a, 0x62, 0x62, 0x62, 0x52, 0x22, 0x4a, 0x01, 0x42, 0x41, 0x42, 0x62, 0x42, 0xc2, 0x39, 0x01, 0x29, 0x24, 0x29, 0x24, 0x29, 0x04, 0x21, 0x24, 0x29, 0x24, 0x29, 0x24, 0x21,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x41, 0x81, 0x61, 0xe1, 0x79, 0x01, 0x82, 0x01, 0x82, 0x01, 0x82, 0x02, 0x82, 0x22, 0x82, 0x02, 0x7a, 0xe2, 0x79, 0xc2, 0x71, 0xa1, 0x71, 0x60, 0x61, 0xa0, 0x69, 0x01, 0x7a, 0xe1, 0x79, 0xc0, 0x79, 0xe0, 0x79, 0xe0, 0x71, 0x01, 0x7a, 0x21, 0x7a, 0x21, 0x7a, 0x83, 0x8a, 0xa3, 0x8a, 0x05, 0x9b, 0x25, 0x9b, 0x25, 0x93, 0x05, 0x93, 0xc3, 0x8a, 0x83, 0x7a, 0x22, 0x6a, 0x81, 0x51, 0xe1, 0x30, 0x03, 0x29, 0xe3, 0x20, 0x24, 0x21, 0x44, 0x29, 0x24, 0x21,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x80, 0x18, 0x24, 0x62, 0x27, 0x93, 0x06, 0x9b, 0xe5, 0x9a, 0xc5, 0x92, 0x84, 0x8a, 0x64, 0x8a, 0x63, 0x8a, 0x84, 0x8a, 0xe5, 0x9a, 0xe6, 0x9a, 0xe6, 0x9a, 0x06, 0x93, 0x06, 0x93, 0x06, 0x93, 0xe5, 0x92, 0xe5, 0x92, 0xe5, 0x92, 0x05, 0x93, 0x05, 0x93, 0x05, 0x93, 0xa3, 0x8a, 0x63, 0x82, 0x83, 0x8a, 0xa3, 0x92, 0x42, 0x82, 0x22, 0x82, 0x43, 0x8a, 0xc4, 0x9a, 0xe4, 0x9a, 0xe5, 0x92, 0x06, 0x8b, 0x66, 0x6a, 0x23, 0x31, 0xe3, 0x20, 0x24, 0x21, 0x45, 0x29, 0x25, 0x21,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x80, 0x08, 0xe2, 0x41, 0xe5, 0x72, 0x06, 0x83, 0x06, 0x8b, 0x26, 0x93, 0x47, 0x9b, 0x27, 0x9b, 0x26, 0xa3, 0x26, 0xa3, 0x25, 0xa3, 0x25, 0xa3, 0x26, 0x9b, 0x26, 0x8b, 0xe6, 0x82, 0x06, 0x83, 0x06, 0x83, 0x06, 0x7b, 0xe5, 0x7a, 0xc5, 0x72, 0xe5, 0x7a, 0xc5, 0x72, 0xc5, 0x72, 0xc4, 0x72, 0xc4, 0x7a, 0xc4, 0x7a, 0xc4, 0x7a, 0x64, 0x72, 0x03, 0x6a, 0x23, 0x72, 0x23, 0x72, 0x02, 0x72, 0x23, 0x72, 0x45, 0x72, 0x22, 0x41, 0xe3, 0x20, 0x25, 0x29, 0x25, 0x29, 0x05, 0x21,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xe0, 0x00, 0x44, 0x32, 0xe5, 0x4a, 0xa3, 0x4a, 0x82, 0x52, 0x62, 0x5a, 0x42, 0x5a, 0x21, 0x5a, 0x01, 0x5a, 0x21, 0x62, 0x41, 0x6a, 0x41, 0x6a, 0x61, 0x6a, 0x82, 0x6a, 0x62, 0x5a, 0x62, 0x52, 0x82, 0x52, 0x83, 0x52, 0x83, 0x52, 0x83, 0x52, 0x83, 0x52, 0x83, 0x52, 0x83, 0x52, 0x83, 0x52, 0x82, 0x52, 0xa3, 0x52, 0xc3, 0x5a, 0xc3, 0x5a, 0x83, 0x52, 0x22, 0x4a, 0x02, 0x4a, 0x22, 0x5a, 0x43, 0x62, 0xc6, 0x72, 0xa7, 0x72, 0x83, 0x49, 0x03, 0x29, 0x25, 0x29, 0x24, 0x29, 0x04, 0x21,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xa0, 0x00, 0xa4, 0x32, 0x48, 0x5c, 0x88, 0x64, 0x67, 0x64, 0x47, 0x64, 0x26, 0x64, 0xe6, 0x63, 0xa5, 0x5b, 0x85, 0x53, 0x65, 0x53, 0x64, 0x53, 0x84, 0x5b, 0xa5, 0x5b, 0xe5, 0x63, 0x26, 0x64, 0x47, 0x64, 0x67, 0x6c, 0x67, 0x64, 0x67, 0x64, 0x67, 0x6c, 0x67, 0x6c, 0x67, 0x6c, 0x67, 0x6c, 0x68, 0x6c, 0x67, 0x64, 0x67, 0x64, 0x67, 0x6c, 0x67, 0x6c, 0x47, 0x64, 0x26, 0x64, 0xe6, 0x5b, 0x85, 0x53, 0x04, 0x4b, 0x43, 0x3a, 0x83, 0x31, 0xe2, 0x28, 0x24, 0x29, 0x24, 0x29, 0x24, 0x21, 0x64, 0x29,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x60, 0x00, 0x23, 0x22, 0x28, 0x5c, 0xa8, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0x87, 0x5c, 0xa8, 0x64, 0xa8, 0x5c, 0x88, 0x5c, 0xa8, 0x5c, 0x88, 0x5c, 0xa8, 0x64, 0xa7, 0x5c, 0xa7, 0x5c, 0xc7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xc7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0x88, 0x64, 0x89, 0x64, 0x0a, 0x64, 0xc4, 0x31, 0x23, 0x21, 0x24, 0x29, 0x44, 0x29, 0x42, 0x19, 0xc7, 0x4a,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x61, 0x11, 0x66, 0x43, 0x88, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xc7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xc7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0x88, 0x64, 0x6a, 0x64, 0x06, 0x43, 0x42, 0x19, 0x24, 0x21, 0x44, 0x29, 0x23, 0x21, 0x23, 0x2a, 0x29, 0x64,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xc0, 0x00, 0x43, 0x22, 0x48, 0x5c, 0xa8, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xc7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa6, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa8, 0x5c, 0x67, 0x5c, 0x88, 0x5c, 0x64, 0x3b, 0xa6, 0x4b, 0xc8, 0x5b, 0x61, 0x19, 0xe1, 0x10, 0x23, 0x19, 0x43, 0x21, 0x82, 0x21, 0xa7, 0x53, 0x88, 0x64,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x41, 0x09, 0x66, 0x43, 0xa9, 0x64, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xc7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa6, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa8, 0x64, 0x48, 0x5c, 0x08, 0x5c, 0x62, 0x2a, 0x26, 0x43, 0x01, 0x22, 0x43, 0x2a, 0x03, 0x2a, 0x00, 0x11, 0x85, 0x3a, 0x81, 0x19, 0x21, 0x11, 0xa5, 0x3a, 0x69, 0x64, 0xa7, 0x5c,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xa0, 0x00, 0x23, 0x22, 0x28, 0x5c, 0xa8, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0x88, 0x64, 0xc7, 0x53, 0x43, 0x2a, 0xc2, 0x21, 0x20, 0x09, 0xc2, 0x21, 0xe2, 0x21, 0xa6, 0x3a, 0xe0, 0x08, 0x82, 0x19, 0x2a, 0x64, 0xc4, 0x3a, 0x81, 0x19, 0xe9, 0x5b, 0x88, 0x64, 0xa7, 0x5c,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x40, 0x09, 0x66, 0x43, 0x88, 0x64, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0x88, 0x64, 0xe9, 0x5b, 0xe3, 0x29, 0x42, 0x19, 0x43, 0x21, 0xe1, 0x10, 0x86, 0x3a, 0xc2, 0x21, 0xa6, 0x42, 0xa3, 0x21, 0x61, 0x19, 0x29, 0x64, 0xc7, 0x53, 0x21, 0x22, 0x08, 0x5c, 0xa8, 0x5c, 0xc7, 0x5c,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x40, 0x00, 0x43, 0x22, 0x48, 0x5c, 0xa8, 0x64, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0x87, 0x64, 0x28, 0x64, 0x03, 0x2a, 0x22, 0x19, 0x44, 0x21, 0x24, 0x29, 0xe2, 0x18, 0x66, 0x3a, 0x85, 0x3a, 0x23, 0x2a, 0x48, 0x53, 0x60, 0x09, 0x45, 0x43, 0x28, 0x5c, 0xe0, 0x19, 0xa6, 0x4b, 0xa8, 0x64, 0xa7, 0x5c,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x21, 0x11, 0x86, 0x43, 0xa8, 0x64, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xc7, 0x5c, 0xc7, 0x5c, 0xc7, 0x5c, 0xa7, 0x5c, 0x88, 0x64, 0xe5, 0x3a, 0x42, 0x19, 0x24, 0x21, 0x44, 0x29, 0x25, 0x29, 0xc2, 0x10, 0x63, 0x19, 0x88, 0x53, 0x62, 0x2a, 0xe8, 0x5b, 0xc3, 0x32, 0x20, 0x22, 0x08, 0x5c, 0x21, 0x22, 0xc6, 0x53, 0xa7, 0x5c, 0xa7, 0x5c,
0x00, 0x00, 0x00, 0x00, 0x40, 0x00, 0x03, 0x22, 0x28, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xc7, 0x5c, 0xc7, 0x5c, 0xa7, 0x5c, 0xa8, 0x5c, 0x28, 0x5c, 0xe1, 0x21, 0x43, 0x21, 0x24, 0x29, 0x25, 0x29, 0x25, 0x29, 0x04, 0x21, 0xc1, 0x08, 0x06, 0x43, 0x05, 0x43, 0x24, 0x3b, 0x08, 0x5c, 0x81, 0x2a, 0x28, 0x5c, 0xc3, 0x32, 0x07, 0x54, 0x87, 0x5c, 0xa7, 0x5c,
0x00, 0x00, 0x00, 0x00, 0xc0, 0x00, 0xe5, 0x32, 0x88, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xc7, 0x5c, 0xc7, 0x5c, 0xa7, 0x5c, 0xa8, 0x64, 0x07, 0x5c, 0xc1, 0x19, 0x23, 0x21, 0x24, 0x29, 0x24, 0x21, 0x25, 0x29, 0x24, 0x21, 0xc2, 0x10, 0x03, 0x2a, 0xe9, 0x5b, 0xc3, 0x3a, 0xe7, 0x53, 0xe5, 0x4b, 0x47, 0x5c, 0xe3, 0x32, 0xe6, 0x53, 0xa7, 0x5c, 0xa7, 0x5c,
0x00, 0x00, 0x00, 0x00, 0x81, 0x11, 0x08, 0x54, 0xa8, 0x5c, 0xa7, 0x5c, 0xc7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xc7, 0x5c, 0xc7, 0x5c, 0xc7, 0x5c, 0x87, 0x5c, 0x68, 0x64, 0xe4, 0x3a, 0x62, 0x21, 0x23, 0x21, 0x44, 0x21, 0x24, 0x21, 0x04, 0x21, 0xc1, 0x10, 0x00, 0x09, 0xe6, 0x42, 0xc7, 0x53, 0x44, 0x3b, 0x87, 0x5c, 0x87, 0x5c, 0xe3, 0x32, 0xc6, 0x4b, 0xa8, 0x5c, 0xa7, 0x5c,
0x00, 0x00, 0x60, 0x00, 0xa4, 0x32, 0x69, 0x5c, 0xa8, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xc7, 0x5c, 0xc7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0x68, 0x5c, 0x66, 0x4b, 0x23, 0x2a, 0x62, 0x19, 0x22, 0x19, 0x03, 0x19, 0x80, 0x08, 0x01, 0x11, 0x60, 0x11, 0xc8, 0x53, 0xe6, 0x53, 0x67, 0x5c, 0xa8, 0x5c, 0x03, 0x33, 0x85, 0x43, 0xa8, 0x5c, 0xc7, 0x5c,
0x00, 0x00, 0x01, 0x11, 0x87, 0x4b, 0x88, 0x5c, 0xa8, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xc7, 0x5c, 0xc7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0x88, 0x64, 0x28, 0x5c, 0x67, 0x4b, 0xa6, 0x3a, 0x45, 0x32, 0x41, 0x11, 0x65, 0x32, 0x84, 0x32, 0xa3, 0x32, 0x68, 0x64, 0xa7, 0x5c, 0x88, 0x5c, 0x24, 0x3b, 0x44, 0x3b, 0xa8, 0x5c, 0xa7, 0x5c,
0x00, 0x00, 0xa2, 0x19, 0x08, 0x54, 0x88, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa8, 0x5c, 0x88, 0x64, 0x89, 0x64, 0x49, 0x64, 0xa3, 0x32, 0x42, 0x2a, 0xe9, 0x5b, 0x82, 0x2a, 0x06, 0x54, 0xa7, 0x5c, 0xa8, 0x5c, 0x65, 0x43, 0x03, 0x33, 0xa8, 0x5c, 0xa7, 0x5c,
0x80, 0x00, 0x44, 0x2a, 0x68, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xc7, 0x5c, 0xc7, 0x5c, 0xa7, 0x5c, 0xa8, 0x5c, 0x47, 0x5c, 0x08, 0x5c, 0x45, 0x43, 0x20, 0x1a, 0x28, 0x64, 0xe3, 0x32, 0xa5, 0x4b, 0xa7, 0x5c, 0x88, 0x5c, 0x44, 0x43, 0x03, 0x33, 0xa8, 0x5c, 0xa7, 0x5c,
0x20, 0x09, 0x06, 0x3b, 0x88, 0x64, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xc7, 0x5c, 0xc7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xc7, 0x5c, 0xa8, 0x5c, 0x68, 0x5c, 0x41, 0x22, 0xa1, 0x19, 0xa1, 0x19, 0x42, 0x22, 0x49, 0x64, 0xe3, 0x32, 0xa5, 0x4b, 0xa7, 0x5c, 0x88, 0x5c, 0x44, 0x3b, 0x24, 0x3b, 0xa8, 0x5c, 0xa7, 0x5c,
0xa1, 0x11, 0x87, 0x4b, 0xa8, 0x64, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xc7, 0x5c, 0xc7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa8, 0x5c, 0x48, 0x5c, 0x42, 0x2a, 0x00, 0x09, 0xa0, 0x00, 0xa3, 0x32, 0x28, 0x5c, 0x82, 0x2a, 0x06, 0x54, 0xa7, 0x5c, 0xa8, 0x5c, 0x24, 0x3b, 0x44, 0x43, 0xa8, 0x5c, 0xa7, 0x5c,
0xc1, 0x11, 0xc8, 0x53, 0xa8, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa8, 0x5c, 0x48, 0x5c, 0xe8, 0x5b, 0x67, 0x4b, 0x22, 0x22, 0x62, 0x22, 0x86, 0x4b, 0xc2, 0x2a, 0x68, 0x5c, 0xa8, 0x64, 0x87, 0x5c, 0xc2, 0x2a, 0xa6, 0x4b, 0xa8, 0x64, 0xa7, 0x5c,
0xe1, 0x19, 0xe8, 0x53, 0xa8, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xc5, 0x4b, 0x41, 0x22, 0x83, 0x2a, 0x46, 0x4b, 0x01, 0x22, 0xc4, 0x32, 0x45, 0x3b, 0x03, 0x33, 0x88, 0x64, 0xa7, 0x5c, 0x47, 0x5c, 0xa2, 0x2a, 0xe7, 0x53, 0xa8, 0x64, 0xa7, 0x64,
0x62, 0x22, 0x48, 0x5c, 0xa8, 0x64, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0x85, 0x43, 0x40, 0x09, 0xe0, 0x00, 0x00, 0x01, 0x43, 0x2a, 0x08, 0x5c, 0xe3, 0x32, 0x64, 0x3b, 0x88, 0x5c, 0xa7, 0x5c, 0x27, 0x54, 0xa2, 0x2a, 0x28, 0x5c, 0x88, 0x64, 0xa7, 0x5c,
0x82, 0x2a, 0x68, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0x88, 0x64, 0x48, 0x5c, 0x67, 0x4b, 0xc5, 0x3a, 0x80, 0x11, 0x47, 0x4b, 0x49, 0x64, 0xa1, 0x2a, 0xe5, 0x4b, 0xa8, 0x5c, 0xa8, 0x64, 0xe5, 0x4b, 0xc2, 0x2a, 0x48, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c,
0xe3, 0x32, 0x68, 0x5c, 0xa8, 0x5c, 0xc7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xc7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xc7, 0x5c, 0xc7, 0x5c, 0x87, 0x5c, 0x07, 0x54, 0xc8, 0x53, 0x09, 0x64, 0xc9, 0x5b, 0xc1, 0x19, 0x66, 0x4b, 0x28, 0x5c, 0xa1, 0x2a, 0x47, 0x54, 0xa7, 0x5c, 0xa8, 0x5c, 0xa4, 0x43, 0xe2, 0x32, 0x68, 0x64, 0xa7, 0x5c, 0xa7, 0x5c,
0x02, 0x33, 0xa8, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xc7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xc7, 0x5c, 0xa7, 0x5c, 0x26, 0x54, 0xe0, 0x11, 0x60, 0x09, 0x80, 0x11, 0xc1, 0x19, 0x21, 0x22, 0x28, 0x5c, 0xc7, 0x53, 0xa1, 0x2a, 0x67, 0x5c, 0xa7, 0x5c, 0x88, 0x5c, 0x84, 0x43, 0xe3, 0x32, 0x88, 0x64, 0xa8, 0x5c, 0xa7, 0x5c,
0x26, 0x54, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xc7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xc7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0x67, 0x54, 0x41, 0x22, 0x60, 0x11, 0x40, 0x09, 0x40, 0x09, 0xa6, 0x4b, 0x89, 0x64, 0xa6, 0x4b, 0xc2, 0x2a, 0x87, 0x5c, 0xa7, 0x5c, 0xa8, 0x5c, 0x84, 0x43, 0xe2, 0x32, 0x68, 0x64, 0xa7, 0x5c, 0xa7, 0x5c,
0xa7, 0x5c, 0x87, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xc7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0x88, 0x64, 0x28, 0x5c, 0xa8, 0x5b, 0x48, 0x4b, 0xe1, 0x19, 0x06, 0x54, 0xa8, 0x64, 0x85, 0x43, 0x03, 0x33, 0xa7, 0x5c, 0xa7, 0x5c, 0x88, 0x64, 0x85, 0x43, 0x03, 0x33, 0x88, 0x64, 0xa8, 0x5c, 0xa7, 0x5c,
0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xc7, 0x5c, 0xc7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0x88, 0x64, 0x48, 0x5c, 0xa6, 0x4b, 0x08, 0x5c, 0x6b, 0x6c, 0x27, 0x43, 0xe1, 0x19, 0x27, 0x54, 0xa8, 0x5c, 0x44, 0x3b, 0x43, 0x3b, 0xa7, 0x5c, 0xa7, 0x64, 0x88, 0x64, 0x85, 0x43, 0x03, 0x33, 0x88, 0x64, 0xa8, 0x5c, 0xa7, 0x5c,
0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xc7, 0x5c, 0xc7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x64, 0x88, 0x64, 0xa6, 0x4b, 0x80, 0x09, 0xa0, 0x11, 0xc4, 0x32, 0xe1, 0x19, 0xe3, 0x32, 0x87, 0x5c, 0xa8, 0x64, 0x43, 0x3b, 0x44, 0x3b, 0xa7, 0x5c, 0xa7, 0x64, 0x88, 0x64, 0x85, 0x43, 0x03, 0x33, 0x88, 0x64, 0xa8, 0x64, 0xa7, 0x5c,
0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa8, 0x5c, 0x88, 0x64, 0x48, 0x5c, 0xc3, 0x32, 0x60, 0x09, 0x40, 0x09, 0xe4, 0x32, 0x47, 0x5c, 0xa8, 0x64, 0xa7, 0x5c, 0x03, 0x33, 0x64, 0x43, 0xa7, 0x5c, 0xa7, 0x64, 0xa8, 0x64, 0x85, 0x43, 0x03, 0x33, 0x88, 0x64, 0xa8, 0x64, 0xa7, 0x5c,
0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0x87, 0x5c, 0xa5, 0x4b, 0x45, 0x43, 0xe7, 0x53, 0x6a, 0x64, 0x06, 0x43, 0xe1, 0x19, 0x28, 0x5c, 0x88, 0x64, 0xa7, 0x5c, 0x87, 0x5c, 0x03, 0x33, 0x65, 0x43, 0x87, 0x64, 0xa7, 0x64, 0xa8, 0x64, 0x85, 0x43, 0x03, 0x33, 0x88, 0x64, 0xa8, 0x64, 0xa7, 0x5c,
0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xc7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0x06, 0x54, 0x80, 0x09, 0x60, 0x09, 0xc1, 0x19, 0x68, 0x53, 0x63, 0x2a, 0x42, 0x2a, 0x68, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0x87, 0x5c, 0xe2, 0x32, 0x85, 0x4b, 0x87, 0x64, 0xa7, 0x5c, 0x88, 0x64, 0x64, 0x43, 0x03, 0x33, 0x88, 0x64, 0xa7, 0x5c, 0xa7, 0x5c,
0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0x47, 0x5c, 0xa3, 0x32, 0x80, 0x11, 0x00, 0x01, 0x60, 0x11, 0x22, 0x22, 0xc6, 0x4b, 0xa8, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0x87, 0x5c, 0xc2, 0x32, 0xa6, 0x4b, 0xa8, 0x5c, 0xa7, 0x5c, 0x88, 0x64, 0x85, 0x43, 0x03, 0x33, 0x88, 0x64, 0xa8, 0x64, 0xa7, 0x5c,
0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xc7, 0x5c, 0xa7, 0x5c, 0x87, 0x5c, 0x48, 0x5c, 0x66, 0x43, 0xc0, 0x19, 0x22, 0x22, 0x27, 0x54, 0x88, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0x67, 0x5c, 0xc2, 0x2a, 0xe7, 0x53, 0xa8, 0x5c, 0xa7, 0x5c, 0x88, 0x64, 0x85, 0x43, 0xe2, 0x32, 0x88, 0x5c, 0xa8, 0x64, 0xa7, 0x5c,
0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xc7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0x87, 0x5c, 0xa7, 0x5c, 0x88, 0x64, 0xa3, 0x32, 0xa3, 0x32, 0x88, 0x64, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0xa7, 0x5c, 0x67, 0x5c, 0xa2, 0x2a, 0x07, 0x54, 0xa8, 0x5c, 0xa7, 0x64, 0xa8, 0x64, 0xa5, 0x43, 0xe2, 0x32, 0x88, 0x5c, 0xa8, 0x64, 0xa7, 0x5c };
I kindly appreciate any of your help! Thank you.
