Using the windows simulator x64
V9.0
Display labels on major ticks using meter object
All examples non are showing labels on ticks
label = lv_label_create(lv_scr_act());
speedMeter = lv_meter_create(lv_scr_act());
lv_obj_center(speedMeter);
lv_obj_set_size(speedMeter, 400, 400);
/*Remove the circle from the middle*/
lv_obj_remove_style(speedMeter, NULL, LV_PART_INDICATOR);
/*Add a scale first*/
lv_meter_set_scale_ticks(speedMeter, 100, 2, 10, lv_palette_main(LV_PALETTE_GREY));
lv_meter_set_scale_major_ticks(speedMeter, 10, 2, 20, lv_color_hex3(0xeee), 20);
lv_meter_set_scale_range(speedMeter, 0, 100, 270, 135);
/*Add a three arc indicator*/
lv_meter_indicator_t* indic1 = lv_meter_add_arc(speedMeter, 50, lv_palette_main(LV_PALETTE_RED), 0);
indic1->opa = LV_OPA_20;
/*Create an animation to set the value*/
lv_anim_init(&a);
lv_anim_set_exec_cb(&a, set_value);
lv_anim_set_values(&a, 0, 101);
lv_anim_set_repeat_delay(&a, 100);
lv_anim_set_playback_delay(&a, 100);
lv_anim_set_repeat_count(&a, LV_ANIM_REPEAT_INFINITE);
lv_anim_set_time(&a, 2000);
lv_anim_set_playback_time(&a, 500);
lv_anim_set_var(&a, indic1);
lv_anim_start(&a);
